won't start and dealer can't find the problem - Diesel Forum - TheDieselStop.com
Old 07-01-2009, 06:42 AM   #1 (permalink)
F-350 2006 6 liter diesel built in 05, 56,000 miles and this start about 5 weeks ago. 1st thing in the morning drove the 5 blocks from home and stop at the store to buy a paper on the way to work. Came out it would not start. Cranks over fine. Call the dealer had it towed. They could not get to it until the following day. It started for them. They could not pull any codes. They keep it for 2 more days nothing. I get it back drive it for 2 weeks and it does it again. Have towed once more to same dealer. Still can't find problem. I get it back and head across start with trailer in tow for week family trip. Stop for a few mins and will not start again. Now I am trying to find a dealer out of town and a tow and some place to drop the trailer and the family. Two hours later I have 2 tow truck show up and the dam thing starts. I pay both driver and we head off on our trip. Truck starts all weekend. Drive home and it does it again. Towed to same dealer and again it starts for him. I take it home and stop at my brother. Does same thing there but this time he gets in and floor its. It starts....dealer is clueless.. Please help
bluetruckguy is offline
Old 07-01-2009, 08:33 AM   #2 (permalink)
69cj's Avatar
Classic symptoms of HPOP/STC failure. Starts cold, no start warm/hot.
69cj is offline
Old 07-01-2009, 08:41 AM   #3 (permalink)
so what is the test and how do I explain this to the dealer that does not seam to care
Old 07-01-2009, 08:55 AM   #4 (permalink)
Another dealer who cares, like 69cj said.
Ljutic SS is offline
Old 07-01-2009, 09:06 AM   #5 (permalink)
so how much should I take a load out for to get this fixed and how long should it be in the shop, look like camping for the 4th is out
Old 07-01-2009, 02:00 PM   #6 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Either a stc or a bad ficm..... The ficm can be intermittant and if it coughs and sputters that could also be the issue.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 07-01-2009, 03:26 PM   #7 (permalink)
OT
OT's Avatar
Blue..yeah, disturbing for sure. As mentioned, one possibility is HPOP leak listed here 6.0 PowerStroke bulletins You need to find out if tec. checked for hpop leak? It should be covered under p/t warr. Good luck!
btw..A classic play on words "If no
DTC found/set = could be "SOL until code shows"? Meantime..tsb says code may NOT be set. Definitely classic play on words.."Find another dealer/tech." JMO!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 07-03-2009, 07:08 PM   #8 (permalink)
Hey bluetruckguy:
I'm having the same problems. Same year truck and it just started for me too. Go study HPOP (high pressure oil pump). If I understand it correctly, it's the seals, not the pump. When it's hot, the oil bleeds by and won't build pressure. When it's cold, the oil is thick enough it will start. They say it's common in 2005 trucks. Still under warranty? Get it fixed before you are out of warranty.
doccrow
doccrow is offline
