Y-Pipe Cracked..........FUMES.....Best Fix? - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 12-01-2009, 02:27 PM Thread Starter
Question Y-Pipe Cracked..........FUMES.....Best Fix?
My 2004 with 65,000 miles has some bad fumes in the cab, I thought it was just the wind. Sitting in traffic with vent/defroster on is the worst, once moving, no problems. After researching this site and crawling under truck seems the Y-Pipe is leaking. I am a fair mechanic and do a lot myself, but this looks like a PITA. How much would a dealer charge, and how good would the replacement pipe be? Can any exhaust shop do this? I've seen some aftermarket y-pipes on line. Also, would this leak explain a power lag on take off? No other issues, the truck runs fine and is all stock except for muffler delete.
So many questions, I've only had this 6.0 a few months and I want to like it.
Thanks for any help................................hparm
hparm Raleigh NC.......2011 F350 6.7 CC LWB Lariat, 4x4, 20" Michelins, 3.55 EL rear, FX4, Factory Reese 25K 5th Wheel, White with Adobe, Tinted Windows, Line X Bedliner............
SOLD
2004 (early) F350 Lariat 6.0 Auto, FX4, 78,000 miles, CC, DRW 4x4, Tinted windows,,.......Amsoil in Motor, Trans, power steering, rear end....Dieselsite coolant filter.................White
2011 Jeep Wrangler Unlimited
2008 3612 Raptor,
1997 FLSTF
hparm is offline
post #2 of 16 (permalink) Old 12-02-2009, 12:00 AM
Got the same type smell in my cab as well. I have not checked my Y pipe yet but will now. My dealer could not find the cause of the smell two weeks ago. Anybodys input would be helpful.
scbrown74 is offline
post #3 of 16 (permalink) Old 12-02-2009, 06:40 AM
It's not that big of a job. The worst part is getting the front of the truck jacked up high enough off the ground to get the downpipe out.....if it's the factory one. Remove the trans x-member, and jack up the trans and truck about 2 feet high. The downpipe will snake out. Take your time, it will come out. Loosen the y-pipe from the turbo and both sides. Slide it over to the right side, and it will come down behind the engine and out the bottom where the downpipe did.
2005 F250 XLT Super Duty Crew 4WD. White/Silver. K&N intake. Hypertech programmer. No muffler. Stock everything else. Other trucks: 1979 Kenworth W900A, 1982 Kenworth Cabover (BJ and the Bear) 1997, 1998, and 2000 Kenworth W900's. All Caterpillar Power. 1979A model just got marine application 2-piece pistons, nozzles, and ATAAC. Sure is sweet!!! 500 to the ground, and no smoke!
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
ericjack is offline
post #4 of 16 (permalink) Old 12-02-2009, 06:50 AM
MelloMike's Avatar
My Photos: (13)
I just had a cracked Y-pipe repaired two weeks ago. About $700 to repair at the Ford Dealership. And, yes, this problem will not only cause fumes in the cab but also lack of power/boost at takeoff.
2003 Eddie Bauer Excursion (born 8 Apr 03), 6.0L PSD (Oxford White & Arizona Beige), 117k miles and going strong, C95 Fuel Injectors, 4x4, 5-spd Torqshift, 3.73 Rear, Heated two-tone leather seats, Hellwig Rear Sway Bar, Bilstein Shocks, PSD Badges, Tekonsha Prodigy Brake Controller. Engine Repairs: 2009-ICP and ICP Harness & Exhaust Y-Pipe. 1972 Airstream Sovereign Travel Trailer.
US Navy Retired
MelloMike is offline
post #5 of 16 (permalink) Old 12-02-2009, 07:12 AM
Same thing here - turned out to be loose clamp on turbo exhaust and loose exhaust manifold bolts - mostly gone now - but there's still some remnant - so I will have to check it further.
2011 F350 SRW King Ranch
rcgreg is offline
post #6 of 16 (permalink) Old 12-02-2009, 05:42 PM
my03psd's Avatar
Where do the pipes usually crack at?
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
58v FICM Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Blue Spring Mod, 08 Diff Cover,
Banjo Bolt Mod, Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
post #7 of 16 (permalink) Old 12-02-2009, 10:09 PM
teamroper60's Avatar
The flex joint..
#43
President and Webmaster
teamroper60 is offline
post #8 of 16 (permalink) Old 12-07-2009, 07:35 PM
my03psd's Avatar
Originally Posted by teamroper60 View Post
The flex joint..
Are there any gaskets that need to be replaced when you R&I the Y-pipe?
my03psd is offline
post #9 of 16 (permalink) Old 12-08-2009, 06:52 PM
my03psd's Avatar
Anybody??
my03psd is offline
post #10 of 16 (permalink) Old 12-08-2009, 08:42 PM Thread Starter
I did some research ($750-$875) and decided to have it replaced at a local Ford dealer who helped me out on the price ($700 parts, labor, tax) The tech has done many of these and after I fiqured the cost of parts the cold weather and a chance of screwing it up, I let him have it. My wife has too many things for me to finish on our home at the moment and I didn't want to hear the b**ching about laying under my truck for hours.
SOLD
2008 3612 Raptor,
1997 FLSTF
hparm is offline
post #11 of 16 (permalink) Old 12-09-2009, 11:11 AM
MelloMike's Avatar
My Photos: (13)
Let us know how it turns out.
US Navy Retired
post #12 of 16 (permalink) Old 12-16-2009, 08:30 PM Thread Starter
Got my truck back tonight, so far so good, no smell..........wallet is $700 lighter.......But we can breathe, for now..........Thanks for the replys
SOLD
2008 3612 Raptor,
1997 FLSTF
hparm is offline
post #13 of 16 (permalink) Old 12-16-2009, 08:44 PM
TousleyParts's Avatar
If anyone decides to fix one themselves, give us a call. I can help you out a bit on parts. We sell quite a few of these; I usually have them on the shelf.
TousleyParts is offline
post #14 of 16 (permalink) Old 12-16-2009, 09:11 PM
How to video on exhaust replacement.
Good video regarding the removal and upgrade of exhaust on 6 and 7.3 Exhaust. Have fun.
http://www.youtube.com/watch?v=01wEKrjwnVE
F-250 2000 4x2 SC SD Long Bed, 6-speed, American Racing 'Kong Wheels, Glasstite Camper Shell & Vintage Airstream gone...! Replaced with vintage Pop-up Sunlight Truck camper that fits in garage.
klutz1 is offline
post #15 of 16 (permalink) Old 11-10-2015, 02:40 PM
Does anyone have any good tips on removing the y pipe from a 06 250. It's cracked on the right side and I have more time than money so I m taking it on my self. Any help is good help thanks for everything.
F250turbodeez is offline
