Might as well do a flush to be sure. You don't want to be mixing coolant. I used Zerex G05 in my truck when I did a coolant flush, and installed an aftermarket coolant filter. If I had to do it over again, would have gone with the Ford Gold coolant but that wasn't available when needed.
Mixing antifreeze types runs the risk of building up sludge, have heard. No reason to risk it.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
I did the flush with the gold coolant. Wish I'd known the G-05 was the equivalent.
The G-05 was $6.00 per gallon cheaper.
Anyway, didn't get any sediment from the flush. Is this a good thing?
Gary
PS
Your gonna ask me how I did it.....
Drained all the coolant I could from the radiator drain then disconnected the hose
from the bottom of the coolant fill tank. Attached an improvised fitting then fed water
there til the radiator drain flowed clear. Filled the system with water then did the same
thing again. Added 50/50 coolant then went for a drive,
03 F250 6.0 4X4 Lariat with 66K miles
Zerex is available as a 50/50 and a concentrate in 1 gallon jugs. But I'm safe because I won't be pouring any of either strength in my truck.
You could all it would take is a flush but since we also have to monitor nitrates just like you do, it would be worthless unless you want a change in color under the hood....
Premium Gold, the maintenance free coolant that requires maintenance....
Carquest here has it full strength,they are the only local place that carries it. I tried NAPA, Oreilly's, Auto Value, Auto Zone and Advanced. Good luck.
__________________ 2001 Crew PMT1 PCM,
Short Box Lariat,Auto,4X4,F350
Black with Tan Leather,Updated 2003 headlights and corners,Walker BTM, B&W Turnover Ball and Companion Fifth wheel hitch pulling a 2007 Pilgrim Legends,
also you should make suer when you finish the flush to flush any tap water out with distilled water. A bad tap water can cause build up in the engine and radiator over time. When I flush mine all I use is distilled water. You can get it from wally world for a dollar a gallon or less.
Ford f350 6.0 4x4. 4" silverline turbo back, cold air intake, six speed manual tranny, sct x3, 373 rear end, running full synthetic in every part that takes oil.
