Zero power on cold starts - Diesel Forum - TheDieselStop.com
Old 05-16-2005, 10:10 PM   #1 (permalink)
I'm looking for anyone that may have had or heard of this problem. On a fisrt start in the morning my engine acts like it has trouble idling it hovers about 250 to 400 rpm and stumbles like crazy. I can put in reverse and the thing nearly dies. When I put it in drive I can give it full throttle and the thing barely even moves. It won't even rev to 1000 rpm. After about 4 or 5 seconds it start to slowly accelerate and once it finally revs a bit the problem clears up completely and runs perfect the rest of the day. This happens about once of three morning starts.
Thanks for any help!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mike
04' F-250 Lariat Crew Cab Short Bed 4x4, MBRP turbo back exhaust, AFE Stage II intake, SCT Xcal 2, Replaced TorqueShift with 4R100 done by John Woods (2 stock TorqueShifts and 8 from ATS in less than 40,000 miles will make you want it gone also! That's right, this is the 11th trans that has been put in this truck.), H-11 Head Studs & Fire Ring Kit, Aurora 5000 turbo, now a 3000 and that is soon to go also, ATS 275cc injectors, ATS Stage III fuel system, Banks Intercooler, 4" Pro Comp Lift, Toyo 35-12.5-20 Mudders for pulling & Toyo Proxies 305/60/18 for racing, plus a nice sound system.
MK60L is offline
Old 05-17-2005, 01:04 AM   #2 (permalink)
Re: Zero power on cold starts
This happened to my buddy's '03, head gasket shot, coolant leaks into cylinders overnight, truck has to blow all the contamination out so runs like sh!t and smokes white to beat hell. He has to wait 10 min before it runs well. Major fix on its way for you!
1987 F250 White Custom 6.9L 5-gear, Dual 2.5" exhaust, K&N intake, 285,000km
1991 F250 Red XLT 4x4 7.3L 5-gear, 465,000km
1994 F450 White XL Dually 7.3L 5-gear IDI Turbo, 180,000km
1999 F250 Red XLT 4x4 7.3L 6-gear, 4" lift, 35"s, 4" turbo-back, AFe, Evolution, Alpine tunes, 360,000km
2004 F350 Burgundy King Ranch 6.0L Torqueshift, FX4, 4" lift, twens (20") w/34.5s, Suncoast tranny and TQ, MBRP turbo back delete, AFE Stage 2, SCT Extreme, Pioneer AVIC-1N, Epicenter, JL W7 - 35,000km
PourinTheCoal is offline
Old 05-17-2005, 01:14 AM   #3 (permalink)
That bites. Well so far no white smoke but I have definitely puked coolant when ran hard. I kinda had a gut feeling I had head gaskets going out though. It sucks I only have 16000 miles on it but I'm sure I'm gonna have to pay, since both the ford dealers in the area are pretty strick about chips. You play you pay. I guess it's my turn to pay. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
MK60L is offline
Old 05-17-2005, 09:51 AM   #4 (permalink)
This winter my 2003 had problems until it warmed up, the motor felt like it was running on less then eight cylinders.
Took it in, the dealer was able to diagnos the motor while cold, immediatly found two bad injectors. After installing the new injectors, they diagnos again and found three addtional injector failures, plus a bad MAP sensor, plus fuel pressure sensor.
The motor now starts with a roar and has never run better! 100,000 mile warranty on the motor, use it!
2000 F250 V10 CC 4x4
Photos
Havasu6 is offline
Old 05-17-2005, 02:01 PM   #5 (permalink)
Get the latest flash. You'll like it much better.
BE
2003 Lariat 6.0 Arizona Beige/Med Parchment Crew Cab 4wd Auto 3.73 born on 5/9/03
bedwards is offline
