'01 7.3L turbo issue - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-27-2017, 07:01 PM Thread Starter
So I'm new to the forum. I've been using forums for years to troubleshoot problems and figured I'd try it since I can't find the issue anywhere. So I had my engine rebuild and the shop finally got 90% of the issues resolved they are stuck again on the turbo. The turbo compressor output seal keeps blowing for some reason that they can't find. They say they have rebuilt it, fixed all the exhaust leaks, and adjusted the wastegate. The truck runs fine but as little to no boost and the said they test the turbo and it tested out fine. Any help would be appreciated.
Ed.wisdom is offline
post #2 of 3 (permalink) Old 04-27-2017, 10:08 PM
RT
RT's Avatar
Forget the exhaust / intake / boost - all that stuff. The seal is going to blow due to oil pressure. My guess is your oil return is plugged. Have you put a gauge on your engine to see what kind of oil pressure you are producing? There is a remote possibility your bypass is blocked creating an overpressure situation to the whole block and overwhelming the turbo oil return, but I'd bet on the former over the latter. Still, putting a gauge on it is the cheapest first test. You should be looking at 75 psi cold oil pressure at 2000 RPM, 50 psi at idle. That will drop to 50 psi hot oil pressure at 2000 RPM and 25 psi at idle. If you are seeing anything higher than that, you'll need to drop the rear oil cooler header and find out what's wrong with the bypass.
RT is offline
post #3 of 3 (permalink) Old 04-28-2017, 07:29 AM Thread Starter
That makes sense. I'm nowhere near an expert on turbos but I'll let the technician know. I haven't had my truck in 9 months because issues with the rebuild and the shop. They are probably tired of me telling them how to fix the issues that they can't figure out. Thanks for the assist
