7.3L Power Stroke Engine and DrivetrainDiscussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Today as I was driving it felt as though someone had applied the brakes. It would do this for a few seconds and then be fine for a few seconds and repeat. Trans has never been hot and seems to work ok in 2nd.
1) Ideas?
2) Should I take it to the dealer or look for a trans specialist in the D/FW Texas area?
'01 F350 DRW Stock
ISSPRO gauges
Automatic trans
1) Ideas?
Do a search on Mechanical Diode. It's a rebuild.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum. Winter Operation (How I Do It) Hard/No Start? Check here first
Ford is offering its rebuilt trannies for your truck with a 3 year 100K mile warranty. Just put one in the SRW and paid $2K for it. The previous rebuild had a measly 3 year 36K mile warranty but ran for 167K miles.
Did the OD light on the shifter flicker at all? You could bring it to Ford and they could check it out for you. I had them check out the SRW a few years ago when the original tranny failed and they charged me something like $50 to check it out.
The 01's were notorious for the mechanical diode failure like C.C. said.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl
69 GTO 400 4sp
86 GLHS Shelby
99 Neon R/T
04 PJ 15k dump trailer 04 H&H 9K tilt bed
As others have indicated, your tranny is probably dead and needs a good funeral.
You have three basic choices.
1] If you're a big gambler, then take it to a local tranny shop and hope for the best.
2] Last I heard, the Ford factory rebuilt warranty was 2 years - provided you haven't hot-rodded the engine with a chip or programmer and you haven't installed an exhaust brake, or any other reason Ford would void the warranty. So that's a good deal. You can buy the tranny and torque converter for less than $2,000, then have it installed by either a Ford dealer or almost any decent tranny shop - whoever gives you the best deal on the R&R cost. (If you go this route, be certain to replace the torque converter and the oil-to-air (OTA) tranny cooler, as well as install a Magnefine in-line tranny filter in the cooler return line - all per Ford procedures.)
3] If two years of probable worry-free tranny service is not good enough, or if you have hot-rodded the engine, then do what I did. A bulletproof BTS tranny and torque converter will cost you over $4,000, but then your tranny worries are over for a lot longer than two years. The BTS written warranty is two years, but Brian has proved he will take care of you if it dies after the two year period is up. And you will love how the BTS performs, whether unloaded, loaded, or overloaded. Stock engine, or a super-powerful hot-rodded engine, or anything in between like my mild towing tune. Brian doesn't care - he guarantees you can't break a BTS tranny. If you can't drive to Arkansas to have BTS install the new tranny and torque converter, then find a local tranny shop that will follow the BTS install procedures and do the R&R at a decent price. Maybe ask Brian if he knows of a tranny shop he will recommend in the D-FW area. Brians Truck Shop
Others will argue that BTS is not the only premium-performance bulletproof 4R100 tranny available. There is also Suncoast in Florida and John Wood on the left coast and BD in northwest Washington state (and BC Canada), and maybe a coupla others. But most agree that BTS is the cream of the crop. There might even be one in the D-FW Metroplex, but I haven't heard of them if they're there.
A quick check on Suncoast indicates the total cost of tranny, torque converter and big OTA tranny cooler will be about $4,300 plus shipping and R&R. So they're about the same price as BTS. Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; TurboRamAir intake and 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and TTM; AIC. I special-ordered it new and plan to drive it until it quits.
1) Ideas?
That's the diode. I know it because that is what I had before. Your trans is TOAST. I'd recommend you can 1-870-422-3673 and they will ship it to where you want and your trans problems will be over.
Ford has a trans if you are not going to modify the truck otherwise, the warranty is void at the worst case scenario
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system and Van Turbo. Bilstein Shocks with U code front and A code Rear.
I agree with Smokey. The best cure is a BTS tranny. I presume you are going to keep your truck for several years, if so, the BTS is the least expensive in the long run, if not, and you keep your truck stock, a ford reman would probably be the cheapest short term fix.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 724,240 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
