100,000 Maintenance - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 03-06-2007, 07:49 AM Thread Starter
100,000 Maintenance
The PSD in my sig is a about 5k from turning over 100,000 miles--I change the oil, and service the tranny every 20,000, and fuel filter every 15K--but at 100K--what are other suggested maintenance items--my initial list is coolant and powersteering--anything else?
Thanks [img]/ubbthreads/images/graemlins/cool.gif[/img]
03' 7.3L 4X4 Crew Cab F-350, SRW, Lariat, Automatic, Fumoto, Ford AIS, Front Grilleguard, Rhino Liner, Sirius Sat Radio
07' Aluminum Cimarron 3 horse Gooseneck with 10 ft Short Wall LQ--Double Duty Conversion
03' Chevy 2500 HD 6.0l Ex Cab, Sirius Sat Radio--236,000 miles and counting
russm1208 is offline
post #2 of 18 (permalink) Old 03-06-2007, 08:16 AM
Re: 100,000 Maintenance
Might want to consider flushing the brake fluid also.
slc10844 is offline
post #3 of 18 (permalink) Old 03-06-2007, 10:30 AM
ELLIOT02's Avatar
Differential fluid.Transfer case fluid.How does your serpentine belt look???Ball joints???Check your brakes,u-joints,hoses,tie rods,axle shaft joints. [img]/ubbthreads/images/graemlins/wink.gif[/img]Spark plugs [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. BTS tranny with 6.0 cooler,coated TN bb1.00 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P Tuner.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,PML pan,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods. Hawks and Powerslot cryo's
ELLIOT02 is offline
post #4 of 18 (permalink) Old 03-07-2007, 04:22 AM
Points and distributer cap
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #5 of 18 (permalink) Old 03-07-2007, 10:37 AM
ELLIOT02's Avatar
He has the newer 03 diesel with the coil-packs on the plugs.No cap and rotor.DUH!! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
ELLIOT02 is offline
post #6 of 18 (permalink) Old 03-07-2007, 02:51 PM
Excellent reply although you are dating yourself...how many folks on here know what points are, have replaced them, and set the gap on them? [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
If you are going to replace the points and distributor cap then you might want to do the muffler bearing at the same time just to make the job easier.
2000 F350 7.3L CC/LB 4X4 XLT/6-speed/DP-Tuner/Bean's 1.0 with WW/4" turbo-back exhaust/AIS/Isspro EV's/285-75-16 Goodyear Wrangler PRO-GRADE/LS monotube shocks/Prodigy trailer brake controller/zoodad/leveling kit/All red - what other color would a firefighter have?
2002 F250 7.3L CC/LB 4X4 Lariat/4R100/DP-Tuner/Bean's Van Turbo with WW/Isspro EV's/4 inch lift/285-75-16 Goodyear Wrangler PRO-GRADE/LS monotube shocks/AIS/4" turbo-back exhaust/zoodad/ALL Black - wife's truck
Just because you can, doesn't mean you should!
FireHunter is offline
post #7 of 18 (permalink) Old 03-07-2007, 03:13 PM
Send a message via Yahoo to treytroxell
I'm only 19 and i know what points are, have replaced them and also set the gap on them. But i also love old cars and trucks. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
1999.5 Ford F-250 7.3l 4x4 PSD With some extras
treytroxell is offline
post #8 of 18 (permalink) Old 03-07-2007, 03:18 PM
I've found that using a brass magnet works best when ever you have to deal with muffler bearings.
Early 99 (11/25/98 Build) F350 XLT Crew Cab 2WD 7.3 PSD, Auto, FORD AIS Severe Duty Intake, Long Bed, Colonel Bed Liner, 3.73 Limited Slip, 155,000 Miles, White/Gray, Tinted Windows, Centerline Wheels / BFG All Terrain T/A K.O. LT295/75/16
" target="_blank">http://<a href="http://photos.thedie...hoto=31714</a>
1973 VW Super Beetle, bone stock
DaPittBoss is offline
post #9 of 18 (permalink) Old 03-07-2007, 03:32 PM
Don't forget to change the headlight fluid, too!
Early 1999 (2/98) Cali-spec F-250 XLT SD CC 7.3 2WD Short Bed Auto - Triple Gauges - Ford AIS with Fender Sleeve mod - Banks BHA - NCHornet CCV mod - BTM - '06 seats - John Wood trans - 6.0 trans cooler - DP-Tuner F5 chip 40T/60T/80E/120 - ITP Overboost Annihilator - DI Regulated Return - Terminator dual HPOP - Airdog
wwalkersd is offline
post #10 of 18 (permalink) Old 03-07-2007, 05:40 PM
RussM, I was hoping the sages on this forum would have some good advice for you, as my 02 is close to 100K.
All you got was a bunch of smart_azz comments - 3000 out of work comedians and these guys are looking for a job:-)
The brake fluid flush seems real, how about power steering as well?
CH [img]/ubbthreads/images/graemlins/cool.gif[/img]
2001 F250 SC LWB 4WD 7.3L Auto - 143K - 17 to 19 MPG
2006 F350 CC LB 4WD 6.0L Lariat G/N Hitch 4285mi - 1 Turbo Trashed 1600mi, MetaL in Oil, Bad instrument cluster - significant oil leak - Sold at a Loss!
1979 Ford F250 4WD 460 4 Spd BW T18 Dana 60's Motor Not Stock
7 MPG....
Too Many other Ford Trucks to List but My First was a 1958 F100 2WD 3spd 240 cid Six....
Coolhand is offline
post #11 of 18 (permalink) Old 03-07-2007, 06:19 PM
Good time for general checkover, as you intended; consider inspection/replacement of --
all belts
all hoses
brakes, including parking brake
all fluids you have not already covered in recent maintenance
thorough engine compartment cleaning
remove all accumulated clutter from glove box, etc.
new floor mats
take this dependable servant out for a beer
Lake Norman at Denver NC 1999 250 PSD (built Sept 98) Lariat XLE7 CC Auto LWB 4WD ESOF ABS 3.73LS X-Caliber cap BFG 285E AT/KOs Jayco-TT 31BHS
David C is offline
post #12 of 18 (permalink) Old 03-07-2007, 08:49 PM
Nothing really special about 100k. If things are running good keep going with the schedual you use. Everybody worries about that magic 100k, just another number. NOW, if you have some oil leaks, waterpump leaks or other actual warranty stuff get those things taken care of under warranty, otherwise don't worry and just keep doing your routine on maintenance. Maybe give your PSD a 100k present and change ALL fluids and give it a good wash and enjoy.....
JMHO.......
Paul B
2001 Excursion Limited PSD,2wd,Auto.,BTS-10/2014, Toreador Red,10/2000,4.5 Racor,unTAGed,
,6.0 cooler,Cat ELC,Underdash Lunar Gauges,Hadley Air Horn,
,Fumoto
2006 31' Flagstaff TT 8.0K,Prodigy
2015 Subaru Forrester
pabrannan is offline
post #13 of 18 (permalink) Old 03-07-2007, 09:01 PM
whiskyrunner's Avatar
The big thing to really do at 100,000 is to make sure the air in the tires is rotated, probably hasnt been done since the factory done it when put in new, hehehehe.
No, really, just follow whats in the owners manual, it has the things that should be done at different intervals.
2000 F250 PSD Supercab 4x short box midnight blue off road/camper package,firestone airbags w/compressor
2004 Terry Quantum 365FLTS Fifth wheel 4 slides
464 International diesel tractor w/loader
Work ride 2013 Kenworth T370
whiskyrunner is offline
post #14 of 18 (permalink) Old 03-08-2007, 09:31 AM Thread Starter
I agree--at least I can sort out the wheat from the chaff!
post #15 of 18 (permalink) Old 03-08-2007, 10:04 AM
ELLIOT02's Avatar
[/ QUOTE ]I did leave a serious response pertaining to Russm128's ?..I do have a job and am a HILARIOUS comedian....just ask me!.Like Paul B stated change ALL of the fluids and inspect belt,hoses,leaks.Especially on motor since you have a 100 k mile warranty that is still in effect.
ELLIOT02 is offline
