7.3L Power Stroke Engine and DrivetrainDiscussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Having problems with truck running. Got stranded on side of road, THINK IT IS RELATED TO A 10K MODIFICATION GONE WRONG.
Truck ran thismorning, then shut off while driving. water was around 10k resister, cleaned out dried wires put back together and unplugged battery to reset computer. truck started and ran. Later in day truck stalled on me and would not start up. Getting a P1000 code (P1000 Check of all OBDII Systems Not Complete).
I think it is due to this mod but not shure, can anyone help?
I'm not cheap - I'm just BROKE!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, LSD, 4.10's NAPA 6637, zoodad, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, Mobil 1 in trans, t-case & diffs, LUK clutch, Swamps single-shots!!! Vegistroke-inspired WVO system w/over 65,000 miles so far! (deadheaded, 70psi VO, looped VO return, cheap (PSD) fuel pump, 190 deg VO BEFORE the heads!), DP-Tuner F5 - stock-high idle-40t-60t-80e-100 - Lovin' it!! 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness with 100/80 watt bulbs and aircraft landing lights for driving lights!
2000 Excursion 4x4 Limited - Frybrid/V3 SVO conversion install in progress! (exclusive 38 gal aluminum under-truck VO tank )
Pull the mod and see if it works better. If it does, then it is the mod. If not, it is something else...
'99.5 PSD 6 SPD 4x4 Extended Cab long Box F-350
AFe Stage 1 intake, Marinco Block Htr Plug Mod., Hutch in-Tank Pickup Mod, $10 AIC, Walker BTM, Edge Juice with Attitude, and that is all, FOR NOW!!! Next mod = Regulated Return???
Old Truck - '95 PSD 5 spd 4x4
Haulin' a 11.5' camper, an '85 Bayliner Capri 20' boat w/ Chevy 350, and a flatbed w/ two big quads.
2004 Grizzly 660 Yamaha (For Me)
2004 Polaris 500 HO (For the Wife)
Spokane, WA
"I don't ride bulls, but I have fought some men" Hank Williams, Jr.
"Sie vie pacem, para bellum" (if you want peace, first prepare for war...)
Its possible. If the computer sees a short on the ICP sensor, it will kill the truck.
However, random death could also be a CPS sensor going bad.
Remove the mod, clean the connection, squeeze the female connectors closed so they have a good snug fit on the male pins and see if the truck still dies. If so, you may want to start looking at the CPS.
??????? Where is the water from?
OK, thanks to my friend John for entering this post for me earlier while I was on the side of the road...
THE WHOLE STORY:
I have a 10k/15k mod on a switch w/22gauge wires to harness. I just did this last week (thanks Forgotten and others). Last nite I sprayed engine off w/ garden hose. 2 miles from house this AM, truck began to idle VERY bad at a lite, and progressed to 300-1100 rpm romping as I coasted into a parking lot and shut it down. Of course I suspected my cheap mod and unplugged harness to look. Apparently I did not get a good seal around the (mod) wires, because the sensor was full of water. I removed the mod, dried out sensor/harness by blowing in it and dabbing it w/paper towels. Truck did not start. Unhooked batteries for awhile and truck started and ran fine 30 miles to job. At job I borrowed superchips tuner and got the following DTC's: P0603 (and P0541-I deleted AIH) cleared the codes and 9 hours later, 20 miles toward home while running slow in heavy traffic it began to "romp" again, and I pulled over. This time I got P0541, P1211 and P1000. There was still some water in the damn connector too... Truck will start, rev up and die. I added a litle throttle and it "romped" wildly. Unhooked batts again, a couple times, and called the tow truck.
I don't blame the MOD, I really like it, and intend to re-install it when I get thru this. I will just look for a better seal next time, maybe di-electric grease or something.
What should I do next??? [img]/ubbthreads/images/graemlins/confused.gif[/img]
-Jason
I kiled my IPR and something else when I had the 10K mod. I washed the engine, and water got in where the leads of the 10K resistor were and fried it. I have since removed the 10k and added a 4 pos chip. Not saying the 10K Mod is not any good, but I have heard of several people having IPR failures after installing the 10K.
-Bandit
2000 F250 XLT 4X4 Extra Cab Automatic, CCV Mod, Pyro Boost and Tranny Guages, 4 Position (Fuel 7 OMG) Chip, 4" Turbo back with 5" Chrome tip exhaust, and now no tread on tires due to mods!
Now that your connector got wet, In a couple of weeks the connection will corrode and it will knock your ICP pressure input to the PCM out of whack...I had to replace the whole connector and wire terminals..
I wont tell you how I know this, but since then I have slowed down on washing my engine, and I stay away from the ICP with water..As there is enough moisture in the air to cause problems as it is...
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
The ROMP ROMP is *exactly* what happened with my truck because I did not get a good enough connection on my ICP plug. Truck would run GREAT and then for no reason would get a case of the romps and die.
As soon as I removed the ICP and gave the female pins a little squeeze to make them fit the male pins tighter, all my probs went away!!
Im going to PM you some info too on where to find the DTC codes and some other good stuff.
OK, I tightened connectors this AM and truck ran fine in driveway and a short test ride... When I looked up the codes I found initial problem appeared to be ICP high pressure condition, seems this could be consistent w/a short at the sensor(water in connector). Later (when I got towed) I had a ICP low condition, maybe the bad connection? Anyway, thanks again for the help here. Hope it keeps runnin'...
WOW! I looked at my connectors and they have ALREADY changed color!! There must be enhanced corrosion from the DC current. I assume the plating stuff has now been comprimised, and now its just a matter of time before whats left sacrifices itself in the holy name of galvanic corrosion to the point where the corrosion product insulates the connection and the problems begin again [img]/ubbthreads/images/graemlins/shocked.gif[/img] - {breathe}
So seriously, should I get the connector now and replace it??
Yes, the metal contacts are different colors, Talk about Galvanic Corrosion...Yes, seriously you will need to get a new connector, solder it on...One of the venders on this site has them for sale...I think SP diesel may have them...
It will only get worse from here..Believe me, I talk out of experience...
All Diesels
__________________ 02' F250 SWB CC 4x4 Lariat 7.3/Auto 2-Tone Grey/Black, Stainless Nerfs, Westin Grill & Stainless Brush Guard, KC Highlighters, 285/16 BF Goodrich AT/KO's on American Racing Rims. TRI light bar on rear, Silverstars, High 5 Cab lights, InTank / PrePump Mods, Prodigy, C-bet'r mirrors & 18K REESE Signature slider.
70' Stang Fastback 351W - Auto / White deluxe interior /Fold down rear Pics 00' Chrysler Town & Country Limited AWD 03' Cougar 281 EFS with all the fixins.. 06' Kubota BX2350 FEL, 60"MMM
Take a look at your wrist, see the that's right there's a little FORD Blue blood in all of us... Even the JAP Diesel lovers....
