2 piece vs 1 piece drive shaft - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 11-13-2007, 01:51 PM Thread Starter
strobes110's Avatar
if i replace my drive shaft would it matter if i just had a one piece made up rather than the 2 piece and the carrier bearing?
2000 ford f-250 turbo diesel 7.3 lariat crew cab, lifted 8" w/37x12.50 cooper tires, 4" dual after market exhaust, 4" downpipe, tymar intake, tony wildman 4 pos chip, tripple under dash gauges egt,boost,trans temp 200k and counting
1997 f250 7.3 XLT ext cab long bed 4x2 bone stock 167k and counting
strobes110 is offline
post #2 of 13 (permalink) Old 11-13-2007, 02:47 PM
LvnALoLife's Avatar
My Photos: (12)
Re: 2 piece vs 1 piece drive shaft
If you have to replace it anyway go ahead as long as you have a short bed. If you have a long bed don't do a one piece! The driveline in a longbed has to be too long and the driveline itself will wobble. If you do have a shortbed get one made with a CV in it and a new slip and stub joint. Should be around $800-$900 at a good driveline shop. I have a one piece in mine.
White 1999.5 F250 4x4, 10" Lift, 20"x12" Weld Dune 8's on 38/15.5 R20 Toyo Open Country MT's, Edlebrock External Resi shocks, 4:56 gears, Powerslot rotors w/ Hawk Performance Pads, Alum larger rear diff cover, Color matched fender flairs & bumpers, AEM Brute force intake, DP-Tuner 5 Position chip, 3 guage A pillar, 4" exhaust w/ hi-flow muffler, 5" Chrome Tip, 4" down pipe, bestoppowerstep.com full length power step, Pioneer in dash DVD player, Arc Audio 6.5" Components front and rear with tweets custom mounted in rear headliner, 3 JL 10's, and still more to go...
Its not "all show and no go"! I use it to tow my 34' Sierra Sport T34SP toy hauler to get the family, long travel buggy and three quads to the dunes.
LvnALoLife is offline
post #3 of 13 (permalink) Old 11-13-2007, 04:37 PM
SmokeyWren's Avatar
My Photos: (45)
Ford SuperDuties come with either a one-piece, two-piece, or three-piece driveshaft, depending on the wheelbase. If your truck came with a two-piece driveshaft, that's because the Ford driveline engineers determined a one-piece driveshaft would be too long between U-joints for your needs, a 3-piece driveshaft was overkill for your needs, and a two-piece drive shaft was just right.
Trying to be a driveline engineer when you're not qualified can lead to some real heartaches, headaches, and driveline vibration. But it's your truck and your money, so if you want to be an amateur driveline engineer, go ahead. [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img]
SmokeyWren is offline
post #4 of 13 (permalink) Old 11-13-2007, 11:55 PM
i have heard mixed opinions on this before, i'd like to hear some more comments, this is something i have thought about before as well.
2001 F-250 7.3 PSD Crew Cab 4x4
Air Raid Intake
True 4" Exhaust
Edge Juice with Attitude
tfdrooke24 is offline
post #5 of 13 (permalink) Old 11-14-2007, 11:48 AM
Not being a driveline engineer, I have determined the guy who did the SD's was not either. Take a look at what your center bearing is mounted on. A flimsy support that holds you fuel tank that can cause funky hamonics. I have fought with with truck to get the vibrations out and finally went to a one piece shaft and have not looked back. The two piece is a nightmare, especially when you go to rebuild. Find a good driveline shop and let them build one for you. It will be cheaper than rebuiling the stock one and balancing.
2000 Ford F-250 SD Lariat, Crew Cab, White/Harvest Gold, 156 WB, ESOF 4X4 Off-Road w/ X-Springs, 7.3L PSD, 3.73 LS, 4 SPD Auto, Leather Capts. Chairs, Trailer tow, HD Suspension, TT Mirrors, Roof Lights, Autometer Guages, Banks Monster Exhaust, Tinted Windows, Tool Box, Smittybilt Outland Stainless Steel Cow Catcher w/ three KC Stainless Daylighters running aircraft landing lights with [color:"blue"] [/color]
, two 12" Eclipse subs, 2200 watts of DEI power!
ChrisP is offline
post #6 of 13 (permalink) Old 11-14-2007, 02:25 PM
lakebound4ever's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: tfdrooke24</div><div class="ubbcode-body">i have heard mixed opinions on this before, i'd like to hear some more comments, this is something i have thought about before as well. </div></div>
Rook,
Take your truck over to Drive Shafts Inc or Drive Train Specialists , both are in Tulsa and either shop will take good care of ya! To save you some money, when/if you swing by have em measure it up and give you a quote. Then at home you can pull the drive shaft(s), drop it off with them and pick it up/re-install when its done. Might be cheaper that way and pulling the drive line is purdy darn easy.... [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
2000
F250 PSD 7.3 4x4 CC Lariat Auto, 4" Pro-Comp Lift, 315/75/16 Toyo Open Country M/T's on 16x10 American Eagles, AFE Stage 2, DIY AIC, CCV Mod, Manual T/C Control, HX-Mod, Dieselsite 203* Thermostat, AIH Delete, Hood Insulation & Foil Delete, Flowmaster side exit.....sounds niiiice.
lakebound4ever is offline
post #7 of 13 (permalink) Old 11-16-2007, 02:35 PM Thread Starter
strobes110's Avatar
chrisP, I had talked to a driveshaft place and the guy said alot of people switch to one pieces. I know you said that you like the one piece and you would never go back. Thats good and gives me a good feeling about that because my truck and your truck are exactly the same execpt mine has the lift. 156 wheel base is the same and everything. Im not going to be pulling heavy loads if I pull at all. Im leaning more towards getting it made, it'll be alot cheaper. thanks for the info
post #8 of 13 (permalink) Old 11-17-2007, 02:40 PM
looks like be having a one piece shaft after thanksgiving, should i reuse my flanges? or get everything new
2002 F250 CC 4x4 Lariat (SRW),
20" KMC Monsters,
37" Toyo M/T's
8" Full Spring Skyjacker
4in Turbo Back (no muffler)
Some kind of programmer/chip?,
RanchHand Frt/Rear,
AFE Stage 2 intake,
Banks Intercooler Pipes,
DieselSite Boots
New tranny(30K),
Banks TransCommand,
Mag Hytec Tranny Pan & Diff Cover,
Quad A-pillar(ISSPRO trans,boost,pyro,water)
About to be DynaTrac'd
My heart belongs to the Mustang and Windsor Motor, so you;ll have to forgive me until I get up to speed with thesee diesels
Steve_USMC is offline
post #9 of 13 (permalink) Old 11-17-2007, 03:26 PM
Oilfield_Digger's Avatar
Mine has a 2 piece and if you plan on doing any kind of lifting of the truck that is the way to go, due to the fact all you have to do is put a drop bracket in the carrier bearing to keep stock drive shaft angle. Just my .02 CDN cents
03 F-350 Lariat CC 4x4 LB
TN BB Turbo, AFE II w/ Progaurd 7, Quad Pod, Home made CCV.
Oilfield_Digger is offline
post #10 of 13 (permalink) Old 11-18-2007, 03:42 PM Thread Starter
strobes110's Avatar
yes you can add a carrier drop bracket but you have to make sure its shimmed correct because of the angle in the shaft might be off. thats why im going with the one piece. the angle in mine was off and it tore itself up from the vibration. ford told me $950 for the drive shaft. im getting a one piece made for $250.
post #11 of 13 (permalink) Old 11-20-2007, 05:47 PM
LvnALoLife's Avatar
My Photos: (12)
I have a one piece in mine and do tow heavy. Have had it in there towing for over three years. I have just switched the rear yoke to be a flange instead of the straps due to snapping a bolt from hot-rodding. Should never have another problem. My friend that lifted his that had a 2 piece had to install a CV joint instead of a U-joint to get rid of the vibration.
post #12 of 13 (permalink) Old 11-20-2007, 08:55 PM Thread Starter
strobes110's Avatar
just got my driveshaft and put it in an love it so far. no more vibration. i dont know why but my front shaft has alot of play in the slip yoke. i can wiggle it back and forth. love the drve shaft so far though.
post #13 of 13 (permalink) Old 11-20-2007, 09:55 PM
F350_6's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ChrisP</div><div class="ubbcode-body">Not being a driveline engineer, I have determined the guy who did the SD's was not either. </div></div> [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
While it's true you shouldn't try and redesign the truck yourself a quality driveline shop should be able to figure something out for you.
I don't think the above quote can be limited to only the driveline engineers.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 500,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
