2000 6spd trans questions - Diesel Forum - TheDieselStop.com
Old 11-03-2012, 09:23 PM   #1 (permalink)
How do you check the fluid in these trans?
I have a leak and sure that im low on fluid, also do they use an internal filter??
2000 F-250 2WD 7.3 Welding Truck Built 7.3 sleeved @.20 over, mahle pistons rods, comp springs, SS valves, Swamps 230cc hybrids, 6 Custom Swamp tunes, Garrett 38R, 4" DP to 5" straight side pipe, 4" SS intake 6637 filter, Dual nozzle adjustable Meth injection, high press adjustable fuel springs, riffraff AIH delete, turbo bpv delete, airdog 125gph fuel system with regulated return, cfm+ intake, ccv delete kit, riffraff overboost code kit, southbend 600hp clutch slipping, broken rearend gears,
1978 Lincoln SA-250 pipeliner, custom welding bed
12000lbs
smoked7.3 is offline   Reply With Quote
Old 11-03-2012, 10:14 PM   #2 (permalink)
91diesel's Avatar
Fill port on drivers side of case near the pto cover fill it to that hole
2000 F250 4x4 ZF6
91diesel is offline   Reply With Quote
Old 11-04-2012, 01:56 AM   #3 (permalink)
klhansen's Avatar
My Photos: (175)
There's no internal filter, but I believe the pickup for the pump is screened to keep out the big chunks. An excellent mod is to put a Magnefine filter in-line on the trans cooler line up by the radiator.
As was said, pull the plug on the side and stick your finger in. Fluid should be right at the hole or at a minimum, within reach of your fingertip.
Hard or no-start? Check Here
Old 11-04-2012, 09:52 AM   #4 (permalink)
I super-glued a 1/4" rare earth magnet to my drain-plug. After a 30,000 mile run on the fluid, I was amazed at the amount of gunk it collected. I truely believe these transmissions need some form of filtration, and that's one of my mods to install in the future.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump.
txgp17 is offline   Reply With Quote
Old 11-04-2012, 03:36 PM   #5 (permalink)
klhansen's Avatar
My Photos: (175)
Not a bad idea, but there's already a magnet in the bottom of the case behind the drain plug. The Magnefine filter gets pretty fuzzy after running for a while if you disassemble it.
Old 11-05-2012, 07:49 AM   #6 (permalink)
Excellent point, but based on the shear volume of gunk the drain-plug magnet collected in 30,000 miles, I have to believe that my OEM magnet is saturated and ineffective after the 260,000 miles it had before I added a magnet.
No doubt a magnefine or similar device is the ticket to keep a ZF-6's inside free of debris. I have those on the power steering return hose of almost every vehicle I own, and the transmission of my wife's Honda Pilot.
Crappy cell-phone pic my homemade magnetic drain plug:
Old 11-07-2012, 11:19 PM   #7 (permalink)
What's the best fluid to put in one and how many arta to refill once drained
12000lbs
Old 11-08-2012, 04:03 PM   #8 (permalink)
diesel site.com make filters for them. Matt
2000 F250 crew cab long box
Banks exhaust, bighead, trancommand, boost gauge trans temp, pyrometer(post turbo)
Dp-Tuner 60& 80econ 60& 80 tow
Strictly diesel overboost annihilator
jobeperformance intake
dieselsite 203 t stat, coolant filter, evans coolant
38r with bank-bighead installed, diesel site non ebv flange international up-pipes coated, diesel site engine boot-kit, non-ebv pedestal
strictly diesel regulated fuel return kit 65psi.
new fuel bowl
CMF+ intake
isspro ev2 pyrometer(pre turbo), fuel pressure, coolant temp, HPOP gauge Matt
Matthew Harris is offline   Reply With Quote
Old 11-08-2012, 04:20 PM   #9 (permalink)
klhansen's Avatar
My Photos: (175)
The ZF-6 calls for ATF, and of those, synthetic is probably best (say Mobil 1). It'll take 6 qts to refill.
