2000 7.3 Powestroke - Diesel Forum - TheDieselStop.com
Old 08-02-2009, 10:23 AM   #1 (permalink)
2000 7.3 Powestroke
200,000 miles 7.3 powerstroke automatic trans. the truck cuts out at low rpm. you can mash the pedal the stuttering clears up and the truck accelerates fine. once you let off the pedal and the rpms drop back the stutter comes right back. I changed the oil and filter and I replaced the fuel filter today also. I took it to a diesel mechanic he put it on the computer. NO CODES. The computer ran a series of test on the engine. Didn't come up with anything. I don't have a idea what to do now. The mechanic didn't either. Any ideas anyone? Could it be my oil is foaming? I put 15/40 rotella in it.
kyguy076 is offline
Old 08-02-2009, 10:29 AM   #2 (permalink)
Runs great on startup. as it warms up it gets worse
kyguy076 is offline
Old 08-02-2009, 11:48 AM   #3 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Welcome to TheDieselStop!!!
I also have a 2000 7.3 but with less than 114k miles....
have you checked the EBV valve(exhaust back pressure)? could be closing up on you.....
Tell us more about the truck, is it all stock??
What have you done to it recently besides the fuel filter,oil etc..
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 08-02-2009, 04:44 PM   #4 (permalink)
The truck is completely stock. I have only owned the truck a week. It was doin this when I bought it. (GOT A GOOD DEAL ON IT). Anway how do I check the exhaust pressure switch? The computer I ran on the truck flagged the exhaust pressure. The mechanic told me 9 out of 10 trucks have the same code not to worry about it. I also would like to know where to check the fuel pressure? Thanks
kyguy076 is offline
Old 08-02-2009, 07:05 PM   #5 (permalink)
Can you scan tool check high pressure oil? You could also have low oil psi from the high psi oil pump. Then when you rev the engine the high psi oil pumps puts out enough psi to work the injectors. You could also have low oil psi from the main oil psi pump. The main oil pump supplies low psi oil to the high oil psi resevoir. The high psi oil pump could be sucking the oil out of the res. before the main oil pump can fill it.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline
Old 08-03-2009, 04:14 PM   #6 (permalink)
fuel pressure is fine. Buzz test on injectors is fine. Contribution test was bad on #8 cylinder. internal control module rom error is what the computer said. CODE p0605. We reset it and it came right back. Snap on scanner suggested to replace the pcm. Hope this fixes it.
kyguy076 is offline
Old 08-03-2009, 04:27 PM   #7 (permalink)
klhansen's Avatar
My Photos: (169)
Are you sure the truck is stock? Maybe someone has had a chip or programmer installed on the PCM. My truck (programmed PCM) occaisionally comes up with a P0605, but don't have problems with it.
If you got a great deal on it, maybe dropping the $$ needed for a replacement PCM won't hurt that much. Check with Jody at DP Tuner on a replacement PCM if that's really what it turns out needing.
Hard or no-start? Check Here
klhansen is offline
Old 08-03-2009, 05:41 PM   #8 (permalink)
My Photos: (23)
if you know a buddy that has a SCT or Superchips handheld programmer you could find out if it already has a performance tune installed, it will not let you install any tunes if it already has one in there.
You could unplug the EBV wire, found underneath the exhaust flange right after the turbo before the downpipe.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 08-03-2009, 08:26 PM   #9 (permalink)
unhooked ebv wire didn't make a difference. I did find a couple wires runnin to the pcm. I think it has some type of chip in it. 3 way toggle switch connected. It was tucked under the dash. Gonna take pcm out tomorrow and see if there is a chip in it. Thanks for the help.
kyguy076 is offline
Old 08-04-2009, 04:03 PM   #10 (permalink)
There was chip in pcm. Removed it and the only thing showing now is #8 cylinder fails contribution test. Truck doesn't smoke. I don't think it would have a cylinder down. Is there any way to check #8 fuel injector?
kyguy076 is offline
Old 08-04-2009, 07:29 PM   #11 (permalink)
My truck had same codes, none ,feel your fuel line if it feels like it is bubbling check fuel sending unit in tank,it has a screen on bottom and inside it has two screens.There is three tabs on bottom with care it comes apart and screens come out they can be cleaned with solvent or brake kleen upon doing this my truck was like a different truck. three shops couldnt figure it out after changing fuel filter,fuel pump and fuel regulator (ouch it was expensive) i read about these screens plugging and pulled my tank myself and this fixed my problem for no cost but time.
haneydave is offline
Old 08-04-2009, 09:46 PM   #12 (permalink)
thanks for the info I will try to clean the screens tomorrow. HOPE IT WORKS
kyguy076 is offline
Old 08-07-2009, 04:31 PM   #13 (permalink)
cleaned the screens. No dice. I guess I will take it to ford and let them put their breakout box on it..$$$$$$
kyguy076 is offline
Old 08-07-2009, 10:49 PM   #14 (permalink)
dieseldude73's Avatar
200k mi on a 9 yr old truck... the cheap fix would be a set of o-rings for #8 injector, but I'm guessin because you didn't have a code for "ICP < or > than desired", or "unable to build ICP @ crank", its just going to be a dead injector. Maybe the solenoid still works for the buzz test but the nozzle tip is plugged? These engines are fascinating (and frustrating)
'96 E350 7.3 Powerstroke powered extended cargo van, aka Vanna White, 363k miles, 20.8 avg mpg on my last road trip
'88 F250HD XLT Lariat 7.3 IDI Supercab longbed, mileage unknown (but it's ALOT), aka Brownie, the epitome of reliability
'06 Dodge Charger Daytona R/T, for my doppelganger, 60k miles
dieseldude73 is offline
Old 08-07-2009, 10:58 PM   #15 (permalink)
that would be great if it was the o-ring. my luck its a dead injector.
kyguy076 is offline
