2000 7.3 stalled, no start - Diesel Forum - TheDieselStop.com
Old 11-21-2012, 11:24 AM   #1 (permalink)
Exclamation 2000 7.3 stalled, no start
Hi, I have a 2000 7.3 auto. Last week ran out of fuel and low on oil. Got it back up after some fuel than stalled again, added oil then started up, filled up and she was fine. Over the weekend hauling 10 times heavy loads, on the highway at 45-50mph she would hiccup here or there, not a ton but a few times randomly and then not do it at all.
Yesterday afternoon coming home from work she stalled, just under the 1/4 tank pin mark, on a flat road. Added 5 gallons of fresh diesel nothing, towed home. Tried new CPS, checked fuel bowl, flows fuel, etc. Slight leak at fuel filter cap o-ring (its wet). Batteries ran low been charging them and have been above 10.5volts.
I got no smoke/fumes out the exhaust. Got fuel to the bowl/pump etc. Fairly clean fuel filter. Hooked AE and ran it. Buzz test x5 checks out very good. ICP 0psi. Unhooked ICP 2300psi+ spike on crank. over 100rpms, 10.5v+, etc. Check for loose wires, connectors, fuses all check out. Not that cold out.
Oh, oil leak, very slight, I haven't found yet, had oil in the valley earlier this year but even since my new stealth pump, none in valley.
There is oil in the Hpop, just around an inch from top.
marcomjl is offline   Reply With Quote
Old 11-21-2012, 12:31 PM   #2 (permalink)
tinman13kup's Avatar
If you unplugged the icp, the data you saw was assumed data. Plug the icp back in and monitor icp pressure and ipr duty cycle. Also check the plug and coil nut on the ipr
Sent from my DROID X2 using AutoGuide.Com Free App
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
tinman13kup is offline   Reply With Quote
Old 11-21-2012, 01:14 PM   #3 (permalink)
There is no psi data if I plug in the ICP. Plug and tin/coil nut are nice and tight. I'm going to throw in a new IPR, I thinks its stuck.
Old 11-21-2012, 05:31 PM   #4 (permalink)
New IPR and ICP unplugged now I have a "Service engine soon" light at start. Cranked over and read
2313psi at 33% duty cycle
RPM around 130-150
Plenty of battery power
What else could it be?
Old 11-21-2012, 06:44 PM   #5 (permalink)
The ICP is what gives REAL readings of the oil pressure. When it is unplugged, the pcm has no idea what the pressure is, it takes an educated guess based on IPR duty cycle and that everything is working correctly. When the ICP is unplugged, it will immediately set the SES light.
Are you getting any readings with the ICP plugged in? If not, there is an issue with the ICP or the connector.
Tom
Old 11-21-2012, 06:55 PM   #6 (permalink)
Let me clarify my post a little more. If there is no reading, there is an issue with the ICP, the connector, or there really ISN'T any pressure. I find that hard to believe though. My hpop had one piston pump totally crumble and jammed 2 more and it would hit 300psi-ish.
Did your truck START, or just crank over?
Tom
Old 11-23-2012, 05:32 PM   #7 (permalink)
I didn't get a chance to work on the truck today, was going to get a new ICP but was thinking. If I try starting with it plugged I get no reading, with it unplugged I get a of 2300psi but that's it. It should have started with it unplugged. If that's the case, it isn't the ICP then?
Old 11-23-2012, 06:17 PM   #8 (permalink)
klhansen's Avatar
My Photos: (175)
Normally the PCM will use a default signal to control the IPR if the ICP sensor is unplugged. You should be able to get it started with the ICP unplugged, but if there's a problem with the IPR signal, then it may not.
If you're getting 33% IPR duty cycle when you're cranking, that just means the PCM is sending that signal to the IPR, not that it's actually operating at that duty cycle. But if the IPR circuit were open or the coil burnt out, you should get a code for that.
Your voltage is a touch low at 10.5V. It's possible that the PCM isn't seeing that much and isn't operating. I'd be dang sure the batteries are fully charged and try again.
It could also be that your IDM has died. Are you getting any codes at all?
Hard or no-start? Check Here
Old 11-23-2012, 07:36 PM   #9 (permalink)
I got:
B1318
B1932
P1280
P1690
P1212
P1247
P1280 wasn't there two days ago
I got two float chargers on both batteries and I've checked they are fully charged. I learned my lesson with batteries years ago
Old 11-23-2012, 10:32 PM   #10 (permalink)
klhansen's Avatar
My Photos: (175)
Here's some info for you from the service manual.
DTC P1280 indicates injector control signal circuit out of range low was detected during KOEO Self Test or during continuous diagnostic monitoring.
Possible causes:
  • biased ICP sensor/PCM
  • open ICP sensor circuit
  • short to SIG RTN or PWR GND on ICP sensor circuit
  • open in VREF circuit
DTC P1690 indicates that the PCM has detected a failure on the WGC (Waste Gate Control) circuit.
Possible causes:
  • short to ground
  • open in harness
  • damaged connection
  • damaged WGC solenoid
  • damaged PCM
  • blown fuse
Continuous DTC P1212 indicates that there was no ICP detected during crank (long crank time).
Possible causes:
  • high-pressure oil system repair
  • empty/low oil reservoir at crank
  • low engine oil level or incorrect viscosity
  • IPR circuit fault
  • damaged low-pressure oil pump
  • damaged IPR valve
  • damaged ICP sensor
  • damaged high-pressure oil pump
DTC P1247 or P1248 indicate turbo boost pressure was low or not detected.
Possible causes:
  • damaged MAP hose
  • low turbo boost
  • intake manifold or crossover tube hose leaks
  • damaged MAP sensor
  • damaged PCM
Maybe there's a common thread in there.
The B codes are GEM codes and won't cause starting problems, so you can ignore them for now.
on edit: B1318 is Battery voltage low and B1932 is Driver Airbag Circuit open.
You should clear the codes, try cranking it with everything hooked up and see what comes back.
Old 11-24-2012, 09:49 AM   #11 (permalink)
Ok, cleared the codes and now got P1690 and P1212.
Old 11-24-2012, 02:05 PM   #12 (permalink)
klhansen's Avatar
My Photos: (175)
Your next step is to run down the possible causes listed above for those codes. It's possible that if it's a circuit problem, it could be the same for both codes, as they share some common circuits.
If you need specifics, I could send you the troubleshooting chart for those codes.
Old 11-24-2012, 03:39 PM   #13 (permalink)
If you are cranking with the icp unhooked, you should expect the p1212 to set. If you have it plugged in, there is an open somewhere. If you plug it in and get the 1280 code, i would start looking at the hp oil
Tom
Old 11-25-2012, 03:11 PM   #14 (permalink)
Hey, thanks Kevin for the docs. This is what I've found for P1690 Chart:
KH1 Yes
KH2 Yes
KH3 ? I get no reading on WGC Harness Pin 1 to ground. But Pin 2 to ground gave me 650ohms.
KH4 ? No reading on WGC harness Pin 1 to Pin 2.
Also I have no continuity on Pin1+Pin2 at the WGC Solenoid. I assume its no good if so?
Other than a bad PCM, can someone explain how the P1690 can stall/prevent no start if its mainly related to the Wastegate?
Old 11-25-2012, 07:52 PM   #15 (permalink)
If you are getting infinite resistance on the WG solenoid, then it's bad. Still, the WGC solenoid will not prevent a start.
I think your no start/stall is still related to the hp oil system. Since you already replaced the IPR, and the truck will not start with the ICP unplugged, I would look at a wire/connector issue. The fact that you are getting the P1212 with the ICP unplugged tells me the circuit is good and the PCM recognizes the ICP isn't there. You might want to check to make sure the IPR inputs are there.
Tom
