2000 7.3L long crank/ hard start - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-31-2012, 09:04 PM Thread Starter
sdraves's Avatar
I need help have a 2000 7.3L. I found fuel in coolant tank. did some research and found out it could be injector cups. found a sweet deal on new cups and o-ring with tools to do the job for under $400. the job went well i think not to hard to do. found 3 of the o-ring shot. on 3 different injector. put truck back together and turn key to let the gp warm up. I SEEN THE FAN MOVE LIKE THE CRANK TURNED but I DIDN'T START THE TRUCK YET. what was that? now i have a long crank . act like its winter. but it 90 outside. the hpop is full see no leaks acts like fuel bleeding off. even if u try to start 30 sec later it still long crank. if u try right after shutting it off and try again starts right back up . any longer then its long cranking . when running runs strong lot better then before the work i did but i dont understand why i have a long crank now. IF ANY ONE CAN HELP IT WOULD BE GREAT
sdraves is offline
post #2 of 6 (permalink) Old 08-31-2012, 10:16 PM
klhansen's Avatar
My Photos: (180)
How many miles have you put on it since you did the injector work? There's probably still air in the oil rails. What you need to do is take it out and run the snot out of it for 40-50 miles. That should cure it.
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 08-31-2012, 10:40 PM Thread Starter
sdraves's Avatar
Have not drove yet. still doing coolant flush to get the fuel out of the coolant tank and lines. i will try that. then post back if that help or not.
sdraves is offline
post #4 of 6 (permalink) Old 08-31-2012, 11:58 PM
tinman13kup's Avatar
The crank moving might have been due to the glowplugs lighting up some diesel. It shouldnt have moved a lot though.
Sent from my DROID X2 using AutoGuide.Com Free App
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
tinman13kup is offline
post #5 of 6 (permalink) Old 09-02-2012, 03:40 PM Thread Starter
sdraves's Avatar
that did the trick. taking it out and running the snot out of it .the long crank is gone. the job went well . thanks for the info .
sdraves is offline
post #6 of 6 (permalink) Old 09-02-2012, 08:22 PM
klhansen's Avatar
My Photos: (180)
Glad to help.
In the immortal words of Col. Hannibal Smith, "I love it when a plan comes together".
), AIS,
regulated return,
klhansen is offline
