2000 7.3L WONT START IN THE COLD - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 12-05-2010, 08:05 PM Thread Starter
I have a 2000 F350 super duty with 164,000. The truck wont start unplugged below 30F, if it does start it runs really rough , i even have to put my foot on the pedal to keep it running then all of a sudden it runs fine. I have replaced glow plugs and relay. I cajn even hear the cyclinders come on line and fire when i'm cranking it over. Its been a problem for going on 5 years and everybody has an oppinion, i need people that know what they are talking about. Thanks for your time
jabbers is offline
post #2 of 19 (permalink) Old 12-05-2010, 08:44 PM
RT
RT's Avatar
After you replaced the glow plugs and relay, have you done the testing to make sure they are actually working?
RT is offline
post #3 of 19 (permalink) Old 12-05-2010, 08:45 PM
tinman13kup's Avatar
Your post follows so many others with the same issues. First things you should check are the condition of the batteries and connections, along with a checkup on the starter. Most autoparts stores will do this for free if they think you'll buy the stuff there. Next is the regular maintenance items, fuel filter, air filter, oil filter with oil. Many people have been using 5w-40 oil, which would help with cranking and building the necessary HP oil pressure of 500psi to fire the truck. You might also re-examine the GP system, ensuring the relay is in fact putting 12VDC to the GPs and ohming out the GPs to make sure they're good. I'm going to take a stab and say you get loads of smoke out for a few minutes.
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
tinman13kup is offline
post #4 of 19 (permalink) Old 12-05-2010, 10:20 PM
SlickDog's Avatar
Check the elec connectors going into the valve cover; hence, it is common for the pins to burn up. If the glow plugs systems works, then you might have injector problems. Have a buzz test preformed.
99 F250 SD SC 4x4 XLT Long Bed 7.3 Power Stroke
6 spd, 203 Thermostat; DIY Tymar; ZooDad; DIY Big Boost; 4" Stainless Steel MBRP turbo back exhaust; Harpoon MOD; Triple Pillar Gauges(Fuel pres, Pyro, Boost); TS 6 Position w/ SWAMP'S Tunes;
Want more?
Expect More?
DO MORE!
SlickDog is offline
post #5 of 19 (permalink) Old 12-06-2010, 09:08 AM
You might also try pulling the IPR and cleaning it out, also making sure the nut is tight on it when re-installing. If you have access to a scanner that can read the ICP readings, it will show if the IPR is functioning.
Tom
post #6 of 19 (permalink) Old 12-06-2010, 11:51 AM Thread Starter
thanks guys, last year i had all new glow plugs and new realay installed, all the electricall conections were good and still hard to start. Im in the process of checking everything again. My truck runs good, could it be injector seals. Whats the best option for new injectors?
jabbers is offline
post #7 of 19 (permalink) Old 12-06-2010, 08:06 PM
Not to replace them unless they ARE bad, lest you want to be broke and disappointed
The seals do occasionally go out. Are you using a lot of oil? It could be the lower o-rings. The uppers can be checked by removing the valvecovers and starting it up. If oil is coming UP from the bottom of the injecter, then the upper seal is bad. You can purchase o-ring kits, and with modest mechanical abilities can change them out in a day and save big bucks over the shop. I cannot stress enough the importance of having some sort of way to monitor readings and codes instead of throwing parts at it. You can easily blow a grand or two and not solve the issue.
Tom
post #8 of 19 (permalink) Old 12-09-2010, 12:19 AM
My 2001 (built in Jan 01) been like this for 5-6 yrs as well. Now with 234,000miles its wont hardly start if its 45* outside without being plugged up foe atleast several hrs. Took to Ford dealer, had one battery bad (they are 2 yr old Motorcrafts), changed that, then doing cold start test ( I have checked GPR & GP's twice in 3 yrs and showed good both times) said the IPR was bad, changes that said it was about 50% better but still not perfect. Wondering myself if its time for Inj. O-rings? I noticed on this last oil change, or actually just before was about 3qts low. if needs new inj o-rings or even injectors.
2011 F350 CC Lariat FX4 DRW-Dark Blue Pearl met./Ebony leather interior~ B&W turnover G.N.
sam2 is offline
post #9 of 19 (permalink) Old 12-09-2010, 02:15 AM
westvandude's Avatar
Could be a combination of weak HPOP and low fuel pressure and slow starter motor and weak batteries.
What a run on sentence... LOL.... anyway, that's where I'd start. My starter went out about 3 months ago. The new one spins the motor at least twice as fast as the old one used to. Huge difference. If you got weak batteries and/or weak starter motor then it won't spin the engine fast enough to get it started.
You can buy an adapter to put a fuel gauge on the fuel bowl. Maybe $40 all in if that. Nice to have anyhow. Places like www.princessauto.com sell gauges dirt cheap.
What happens when you shoot a small pffft of WD40 into the turbo intake (air filter box removed) when you start it stone cold? Don't freak out, I'm talking a very small shot of spray. If it fires up instantly maybe it's a fuel side problem. If it doesn't make a difference then glow plug issue?
In any case, don't throw parts at it. Find somebody with that Autoenginuity or whatever scanner to check IPR and ICP function. Post up and ask here if anybody in your local area can help you out.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #10 of 19 (permalink) Old 12-09-2010, 08:01 AM
Think you are replying to me. I didnt think w/ batteries two yrs old one would be bad, my fault for not checking them first, but this has been an on going problem for years only progressively getting worse even w/ new batteries wasnt any better. THey said after installing a new IPR that the pump pressure was fine, but wasnt up to par on down the line. So that would lead me to belive inj. o-rings leaking and/or bad injectors.
I have a race, build my own engines ,etc. so pretty good with mechanical stuff. And this Ford dealer, BF Evans Ford, will scan my stuff for $69 figure isnt too bad for a dealership, and wasnt sure if a Snap On scanner would show al the stuff a diesel has going on.
sam2 is offline
post #11 of 19 (permalink) Old 12-09-2010, 08:34 AM
Hi,
I just bought a 00' 7.3 with 90k on it and im having the same issue with cold weather starts. I am second owner and i bought it from a good friend whom has a detailed record of maintenance. Not saying everything is perfect under the hood but is it possible this could be typical for a diesel under freezing levels? What I've been doing is turning key to run until start light goes out twice then I crank it over and she still starts hard but not as bad.
Just my thoughts.
Red7.3L is offline
post #12 of 19 (permalink) Old 12-10-2010, 07:45 AM Thread Starter
I have had my truck scanned and nothing comes up. If its cold It will take 10 to 15 glow plug cycles to start the engine with a jump and new batteries. Its like I crank and crank and suddenly i hear 1 cyclinder kick in and crank then 2 and so on. I do get some smoke not a ton and i put my foot on the pedal that makes a difference when it starts it runs real rough and i have to put my foot on the pedal or it will stall. I don't want to throw money at the truck either but i need it to start. I have a friend with a 2002 ford 7.3L truck and hes got 230,000 miles on it the thing starts all the time.
jabbers is offline
post #13 of 19 (permalink) Old 12-10-2010, 08:57 AM
Is your truck tuned? When I bought mine the guy told me when he bought it he had the ford garage add a power chip but he did not get a tuner. Either way the point I'm getting at is if you do have a chip of some sort that may be an issue? I'm still new to diesels so it's just my thoughts.
Red7.3L is offline
post #14 of 19 (permalink) Old 12-10-2010, 09:21 AM
squarehead's Avatar
the starter checked out okay......slow cranking wont help in cold weather
squarehead is offline
post #15 of 19 (permalink) Old 12-10-2010, 10:06 AM
Excavator's Avatar
My Photos: (11)
If you are 100% sure glow plugs and relay are good then it's time to think that your injectors are having poppet valve problems.
This can be checked with valve covers off and using a feeler gauge to measure the armature plate clearance when cold. The solenoid needs to come off to measure. The spec is minimum of .002 inch.
Anything less than that and the injectors need to be rebuilt or replaced.
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
