2000 F-250 Famous Steering Wander - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 29 (permalink) Old 10-28-2005, 05:32 PM
elkkiller's Avatar
Re: 2000 F-250 Famous Steering Wander
Wayne B, I was referring to what I did, nothing more. it does seem though that everyones advice is to look past the steering gear which is what I did and that was wrong. there would not be shops that specifically rebuilt them if they never went out that's all. ~Aaron
2000 F-250 S\C 4X4, rebuilt engine \ DP Tuned \ 3 Gauge cluster \ "cackle cure"- FX cross over fuel return \ shimmed fuel reg. 69 psi. \ new rear-end \ rebuilt tranny \ transgo tugger shift kit w\ non-modulated T\C lock up \6.0 trans. cooler \ wicked wheel \ \ open element intake \ magnaflow muffler \ ccv mod \ HX mod.\ Redhead steering gear \ Head light harness and lenz up grade \ Bilstien shocks \ in tank and pre-pump mods.\ and a HOLE in my wallet so big I can park my truck in it!
elkkiller is offline
post #17 of 29 (permalink) Old 10-28-2005, 07:31 PM
Also adjustable camber sleeves are a good idea if you don't have them and are already in there.
'05 single cab f-450,10ft stake bed
'00,SprCb,DRW,6spd. 190k Garrett BB Turbo, AFE stage II, LUK clutch w/kevlar bearing, intake heater delete, acetone badges...
I10haulR is offline
post #18 of 29 (permalink) Old 10-28-2005, 08:15 PM
This problem is not related to just 99-02, my 03 had the same problem. It was not as noticeable at low speeds, but freeway driving was damn tricky. There was so much slop in the steering wheel and the wander was terrible. So at 32K I took it in, Ford said it needed new ball joints and the steering box needed adjusted. Took it, worked better, but problem not fixed. Took it to another Ford dealer, replaced the steering box, problem fixed. This was about a year ago and I now have 65K on it and it is fine. Now if I could only figure out the thumping in the drivers side floor board when I go over seams in the road??!!
2003 F-250 Extended Cab; Red; Soft Tonneau; Spray-in-liner; Lund Cold Weather Screen; Edge Evolution; AFE Stage1 Intake; Muffler Delete; Autometer 3 Gauge Pillar Mount;AIH Delete
Darrell13 is offline
post #19 of 29 (permalink) Old 10-28-2005, 10:34 PM
i work for ford and we have had problems with the right lower ball joint seizing
jpb620 is offline
post #20 of 29 (permalink) Old 10-28-2005, 11:12 PM
MarvinVR's Avatar
My Photos: (14)
Mine has had the entire front end replaced and still wanders. Its like the toe isnt correct---goes left then right then left. Pain in the butt to keep straight. Had it to Ford and a private front end shop and both say nothings wrong.
2001 F-350 Lariat,CC,LB,SRW,4X4,Auto,7.3,2"lift,KYBs, 3.73, steel oil x-over, aFe Stage II Pro 7, AirCond mod, Fumoto, DP 60,80,100. AIH Delete, hi-lite/fog-lite on mod. CNC HPOP hoses. 360 degree illumination six light LED system for backup, fog and sides. Dead bird in grill. Part of finger in new ball joint nut. (really!)
MarvinVR is offline
post #21 of 29 (permalink) Old 10-29-2005, 05:20 PM
sqidget's Avatar
Darrell,
I have had two different bumps from the floor. 1 was bad sway bar links. the ones from the bar to the chassis. 2 was the inner wheelwell was loose on the push clips. I would be interested in how this turns out because I have never been happy with the wandering.
Dave
2012 F350CC, Lariat, 6.7
2006 Yamaha FJR1300AE
2000 kawasaki ZRX1100ELR
sqidget is offline
post #22 of 29 (permalink) Old 10-30-2005, 12:38 PM
I just changed most of the front end, balljoints, tie rods, stabilizer, and she still wanders. Put the woman in the drivers seat, and while she turned the wheel, I watched the sector shaft. Lots of play. Time for a steering box at 110k. Seems like I have been replacing a lot of parts right around 100k. Wheel bearings and brakes were at 90k. Hmmm. Am I too hard on the truck?
2000 F250SD SCLB Lariat 4x4
450 cubes, fully studded, modified.
4R100 built by me with Suncoast/Transgo/Sonnax/Ford parts.
325/65/18 BFG A/Ts on Ultra rims, custom 4" lift with rear shackle flip(no blocks), Rancho 9000Xs, Homemade bypass fuel system, bypass oil filter, Racor CCV filter, 3.5/4/5 custom exhaust, 8 yr old DI 4 pos chip, and some other stuff.
22 year US Navy vet (retired)
ASE Master Auto Tech
stangrcr1 is offline
post #23 of 29 (permalink) Old 10-30-2005, 04:29 PM
ReefBlue's Avatar
What you describe sounds like tramlining. Control arm bushings can also be a culprit. This is a big issue with Mustang suspension when they get old or modified. Don't know if it happens to Ford trucks also, but they symptoms are the same.
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #24 of 29 (permalink) Old 10-30-2005, 06:46 PM
The steering box doesn't work for me.
2000 F-450,Crew Cab,4x4,Flatbed,4.88 diffs
Sumitomo 245/70R19.5--Centramatic balancers--AIS with Fender Sleeve--Chrome Simulators/Dieselsite--Coolant Filter/Dieselsite--Trans Filter/Dieselsite-- A-C valve/Dieselsite --Oil Gaurd bypass filter--Fumoto valve/Dieselsite--SkyJacker Steering Stabilizer-- 4 Gauge A Piller Pod(pyro,boost,trans,volt)--Muffler delete--AIH delete--Gas Magnum shocks--ITP HX mod--Wolverine Engine Oil Heater--GOLD coolant---CCV mod---ITP Pre pump/tank Kit---WIX prepump Filter/Separator---FIA grill cover---Zoodad Mod---REDHEAD steering box---ROTELLA 5-40 Synthetic---MOBIL 1 syn PS fluid---Magnefine PS filter---STACK single/chrome/5"---
ON THE FLATBED>-- Miller Trailblazer 302-- Suitcase MIG 12vs x-treme-- 2 60" boxes/ 2 36" boxes-- and all the necessities
SKEET298 is offline
post #25 of 29 (permalink) Old 10-30-2005, 07:31 PM
elkkiller's Avatar
[/ QUOTE ]What do you mean? [img]/ubbthreads/images/graemlins/shrug.gif[/img] ~Aaron
post #26 of 29 (permalink) Old 10-31-2005, 11:47 AM
I just wanted to throw my $.02 worth out to chew on. It may be that the rear axle could have some looseness, causing some road wander. I used to have a Chevy pickup that had some wore out stabilizer bar bushings on the rear end, and it wandered because of it. Hey, My F250 is a 2WD and has twin I-Beam front suspension, and it doesn't track as good as I would like it to. A twin I-beam does not have ball joints like the 4WD do, so if I have front end suspension / steering looseness, it sure ain't ball joints. [img]/ubbthreads/images/graemlins/eek.gif[/img]
tjc1989 is offline
post #27 of 29 (permalink) Old 10-31-2005, 01:46 PM
been down this road with a 00 excursion which i bought brand new---was all over the road from the get go. I had all the standard fixes performed, front steer stabilizeer, fmc did the ball joint replace, adj steer box, align. all that did nothing to correct the problem. i them took a lesson from mercedes benz(whose vehicles track beautifully) and decided to increase caster and yes, possibly increse ride harshness. first i replaced front springs with heavier duty ones and caster went from 2degree to about 4 1/2 then i installed 2 degree shims between the front axle and springs and got the caster up to about 7 degrees positeve. VIOLA! steered and stayed straight. Granted, it did ride a bit (and only a bit) harsher.
this all occured about 5 years ago and i've since sold the beast, but it did work then and i belive i'm remembering this correctly.
i presently own a 00 f250 superduty and have contemplated putting the 2 degree shims in the front, but i must say, this girl tracks pretty well.
back in 00' this was a very big issue on the excusrsion board and i got the positive caster idea from a ford mechanic somewhere in michigan or indiana (or similar) who had posted great results with improving caster
sorry bout the long post and hope this helps
rich
richieracket is offline
post #28 of 29 (permalink) Old 10-31-2005, 09:19 PM
Steering box " LINK", skiped a word Doooh, my bad
SKEET298 is offline
post #29 of 29 (permalink) Old 11-01-2005, 09:05 AM
elkkiller's Avatar
Here is Redheads number (206) 364-3333 they must be having troubles with there website because it worked when I put it up there.?.? ~Aaron
