7.3L Power Stroke Engine and DrivetrainDiscussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
My 2002 has the press in joint bolt on yoke and the 2000 axle I picked up has a mounted yoke with the clips with 10mm bolts my queston is will my drive shaft still work on the 2000 axle?
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
They both should use the same 1350-series u-joint. Unless its an F550 axle, which might use a 1410 u-joint.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
Does the 2002 have a companion flange that bolts onto the axle flange with the large 12 mm bolts? Then I do believe the driveshafts are different.
I was told you could simply swap out the axle yoke but you would mess with the bearing preload so I wouldn't try that myself.
Not sure what year they went to the companion flange connections but I know on my current 2005 axle swappings into my 99 I will need to get the driveshaft redone to make it work.
early 99 F350 4x4 wth some upgrades
