2001 4WD won't start - Diesel Forum - TheDieselStop.com
Old 07-21-2007, 01:49 AM   #1 (permalink)
First timer so here goes. The probem is my 2001 F-250 wont start. It has been in my driveway for because I have not needed to drive it. It ran fine before. Had a real heavey rain this morning. Got in it this afternoon and it cranked fine but would not start. I thought the batteries were good but after reading these forum post I have decided to remove them and have a load check done on both of them. I have also decide to replace the Cam Position Switch (CPS)and get a spare. I had not change the fuel filer in a while and I did that this evening, did not help. Does anyone have any other suggestions. I have a superchip diagnostic tuner that came with the programmer and thought I would run it in the morning. I am just looking for WISDOM.
bholt0 is offline
Old 07-21-2007, 08:41 AM   #2 (permalink)
Re: 2001 4WD won't start
When you had your batteries checked did you charge them really good?
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 07-21-2007, 10:33 AM   #3 (permalink)
Have not done that yet, this all just started last night. To answer your question though although the truck seems to be cranking with plenty of power the batteries are about 3 years old.
bholt0 is offline
Old 07-21-2007, 01:46 PM   #4 (permalink)
Changed the cam switch after 135,000 miles life is GOOD it started right up. Thanks for all the valuble information. Plan on ordering a spare, that along with the 10mm socket and so forth ar now in my tool box in the truck waiting on the spare switch. Thanks again folks, saved my bacon. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
bholt0 is offline
