2001 7.3 Oil in Coolant, Coolant in Oil - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 06-03-2012, 10:48 PM Thread Starter
01Stroker4x4's Avatar
Hello All,
I rebuilt my engine last year and have put roughly 10k miles on it at this point. Over the winter the icp O-ring blew and was leaking in a similar fashion to the HP System End Plugs. So in the giant puddle of oil on the ground I noticed little red drops of coolant. Ever since the rebuild I had not noticed any oil in the degas bottle, but now with a closer look there is some residue.
Over the course of time I had been driving the truck I noticed really no coolant loss or raise in oil level during service intervals
So.. What could this mean from my research I found a few things.
Oil Cooler O-rings- Replaced during rebuild (Ford)
Oil Cooler- Was cleaned but not replaced
Injector Cups- All 8 replaced by machine shop and flow tested (Dorman)
Head Gasket- Heads were cut, and put back in with studs not bolts(Victor-Reinz HG)
Front engine cover- Checked for plumb, was straight no cavitation noticed on housing(Victor Reinz Gaskets)
Injector O-ring- Stock cores rebuild to 238 cc, installed with new o-rings
Given what others have said the cooler is the first place to look, I just took out a faulty injector so While things were removed I took the cooler off to inspect it again. I was just going to replace it but for 240 dollars I am just going to assume it may be a waste of time and money, given my luck I am probably just going to have to look at the heads or the cups....
Any info or help would be appreciated kinda at a wall here with what to do, given each system is contaminated.
Thanks Everyone,
Chris
01Stroker4x4 is offline
post #2 of 3 (permalink) Old 06-04-2012, 11:40 PM
Wrencher's Avatar
Depending on how well the cooler was cleaned there could still be residue that would eventually make it to the bottle. You could do a coolant system pressure check.
2002 F-350 CC Shortbed, Rebuilt 7.3 Powerstroke, 200K, head studs, Adrenalin HPOP, DIY BHAF, EBV brake mod, New motor, New trans both @ 170K, 4" Lift, 35" BFG KM2, GEAR HEAD 6 Position, Banks Big Head Wastegate, 4" Duals, Superlift Air Bags, B&W Hide a ball W/ 5th Wheel Companion, Marinco mod, '15 steps,'12 tailgate,'15 mirrors,'12 seat belts and jump seat. no more lap belts
LOCAL 3 OPERATORS UNION UTAH
LOCAL 140 PIPE WELDERS/ FITTERS UNION UTAH
Wrencher is offline
post #3 of 3 (permalink) Old 06-06-2012, 08:40 AM
SmokeyWren's Avatar
My Photos: (45)
If you actually have new coolant in the oil, and not just leftover from previous repairs, then the most likely culprit is the mating surface between the engine oil cooler and the engine. IOW, a leaking gasket, similar to a leaking head gasket.
If that's the problem, then the fix is to drain the coolant, remove the engine oil cooler, clean it up squeeky clean, then install it right with a new gasket and the correct torque.
I wouldn't worry about oil in the coolant. That won't hurt anything other than act as a warning that you may have coolant in the oil. But even a small amount of coolant in the motor oil can ruin the engine in a heartbeat.
SmokeyWren is offline
