2001 E350 7.3 Powerstroke Ran out of fuel wont start - Now What? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 12-12-2011, 07:50 AM Thread Starter
I have a 2001 Ford E350 van with a 7.3 L powerstroke. It ran out of fuel. Put about 5 gallons of diesel in it but it wont start. Do I need to manually fill the fuel canister up with fuel? I thought they filled up automatically when you turned the key on.
Thanks for help.
davis422 is offline
post #2 of 11 (permalink) Old 12-12-2011, 09:25 AM
RT
RT's Avatar
Your pump may have lost prime. Easiest way to do this is to pressurize the tank - preferably while someone cycles the key. You could open your fuel drain on the bowl to serve as an indicator as to when you have pushed fuel into the bowl.
Different ways to pressurize the tank would be to use an air compressor set on a relatively low pressure (20-30 psi) and place a rag around the nozzle as you pressurize the tank. You could also use a shop vac with the hose on the outlet.
Either way, once you get fuel to the bowl - close off the drain and try to start it. Might still take a little cranking as you have to move the trapped air in the fuel rails through. In the future, try really hard not to run out of fuel - low fuel pressure is really hard on the injectors.
RT is offline
post #3 of 11 (permalink) Old 12-22-2011, 08:49 AM
Thumbs up
You will need about a half tank of fuel to be able to build enough liquid pressure to remove the air from trhe lines. Take off air breather to get to water seperator. Open cap on separater and cycle the key untill fuel is steady spewing everywhere. Fill up the bowl with diesel the close cap. turn key to on postion for 15 sec and let pressure build up in lines. then it should crank right up... took me a while to figures all this out.. PHEW
spidamike is offline
post #4 of 11 (permalink) Old 12-22-2011, 09:03 AM
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
Why would he pull the air filter off to get to the fuel bowl? Just pressurize the tank.easiest fastest cleanest way to do it
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #5 of 11 (permalink) Old 12-22-2011, 10:35 AM
the bowl has to be filled with fuel.. if not it will act as a bubble and not let fuel get to the injectors... in order to get to the bowl the filter housing must be taken off to remove the lid on the water separator housing.
post #6 of 11 (permalink) Old 12-22-2011, 10:49 AM
Bill1013's Avatar
The electric fuel pump only runs for 20 seconds on each key ON cycle. The fuel pump runs continuous after the oil pressure comes up. To fill the filter, it takes several key ON cycles, best done with the filter drain open until you see fuel. DO NOT try to start until this is done, very hard on the injectors. Two 10mm nuts to remove on the plastic cover and the dilter is there, drain valve is on the back side.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #7 of 11 (permalink) Old 12-22-2011, 11:10 AM
RT
RT's Avatar
The OP is working on a van. The fuel drain is opened with a cable that goes to the drain lever - that cable is right under the hood. Spidamike - what are you driving that the fuel bowl is under the air filter?
RT is offline
post #8 of 11 (permalink) Old 12-22-2011, 11:28 AM
01 e-350 7.3 powerstroke... The water sep. bowl is in front of the breather box. the filter housing and first segment of the breather must be taken off to crack the lid on the water separater. I tried the drain first with no response several times.. so I pulled out the whole breather. Good idea anyway Because I found the brather box in several pieces..cleaned alot of gunk from the breather at the L connected to the turbo...Then I had to put a 1/2 tank of fuel to get enough LIQUID pressure to clear the lines..then filled the bowl with fuel, put the lid back on and it cranked right up....
post #9 of 11 (permalink) Old 12-22-2011, 10:36 PM
Just cycle the key a few times with the valve open. No need to open anything up. The fuel bowl returns to the tank so it will not create a bubble.
Current: 2014 F-250 SWB CC lariat FX4
6" lift 37x12x20's
2012 F-250 CC SWB 4x4 8"lift 37x14r22's
Past:
2002 F 250 XC SWB XLT
Early 99 PSD CC, LWB Standard
Late 99 CC LWB 4x4 XLT
02Sleeper is offline
post #10 of 11 (permalink) Old 12-26-2011, 10:34 PM
Im just speakg what worked for me on the specific vehical.... THATS ALL
post #11 of 11 (permalink) Old 12-27-2011, 04:32 AM
I used to believe that cycling the key was all that was needed, and had proven true countless times until last week. A friend ran out of fuel in his 7.3 Excursion, and by the time we were done we had disconnected the fuel pump, removed it, put it inlet side up with a hose full of fuel attached to the inlet and hooked it up to the battery to manually prime it ad get the air out. I then put caps on it to keep the fuel in it, reinstalled it and then slipped the caps off an hooked up the lines. It couldn't push the air in the pump out to let the fuel in even with the discharge side unhooked and open to the atmosphere. I had no access to a compressor where he was at.
2003 F-350 CC 7.3L PSD 6-speed
DIY Tymar, Walker BTM, Stage 1.5 single shots, Hydra 6 position tuner, Autometer EGT
[B]2003 Excursion 6.0L 4x4[B]
Staying stock as long as it survives...
We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything, with nothing, in no time at all.
smokum is offline
