2001 F250 missing - Diesel Forum - TheDieselStop.com
Old 11-05-2009, 09:12 PM   #1 (permalink)
2001 F250 missing
Asking the question for a friend, not the truck in the signature.
2001 F250 no aftermarket parts. 150K miles.
He said that it started missing occasionally while driving and slowly has gotten worse. Now it will start and sometimes drive for a mile or so (sometimes not) before starting to miss so bad that it isn't drivable. Shakes back and forth and almost stalls. It gets worse when you hit the gas and he said that he can't even build up any RPM's. Mechanic said that the injectors were bad and that happens on all the 7.3's at this mileage. But with all the work the mechanic wants to do, he was given a quote of $4K. Sounds unreasonable to me. And I don't even know if that is the problem. Does this sound like any problem anyone else has faced? And hopefully beaten for cheaper...
Thanks for any help or suggestions.
2006 F250 PSD CC, SB FX4. Skyjacker 4" lift, 325/60 BF Goodrich tires on 20" Pro Comp Rims, Amp Research Electric Step bars, Harley Bars, Banks 6-gun w/ speed loader, Banks IC, Air Raid intake, Banks Monster exhaust, Viper 5900 remote start, Pioneer Avic-Z1 GPS, DVD, and Stereo head unit, Infinity door speakers, Rockford Fosgate Amps under the back seat, and Rockford Fosgate Sub in the front center seat. I think that is all so far...
The Truck --- Pics
BigPDiesel is offline
Old 11-05-2009, 10:29 PM   #2 (permalink)
tomjon's Avatar
That does not sound right at all to me. Unless he has been abusing those injectors , I would think they are fine.
What is this mechanics diesel experience?
01 f250 7.3 diesel ,x-cab,xlt,170k,...stocker , powerslots and hawks , Rotella ELC , Dieselsite coolant filter
69 Bronco 302 np435 , not enough tires, lift ,time or money.
tomjon is offline
Old 11-05-2009, 10:34 PM   #3 (permalink)
The so called mechanic is full of crap. I would not let him do anything. Injectors do not go bad at 150K, and 4K is way too much money. I would take it to someone that knows PSD's. It could be as simple as an injector wiring harness clip, UVC. Has the PCM been scanned for codes, fuel filter been serviced recently, etc. What diagnostics have been done? Your friend definately needs to get to an honest, and good PSD mechanic. Hopefully, someone knows of somebody close by. A call to Bob Riley at dieselsite.com, may be a good source.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 11-07-2009, 10:58 PM   #4 (permalink)
jroller's Avatar
check UVCH, then AE to find the dead hole, replace inj if need be for about $200 doing it yourself, end of story.
2001 PSD 7.3 auto DP Tuner, 4" TBE, KNN Intake (with filter charger), CCV Mod, DB Starter, Stancore GPR, ITP Overboost, John Wood installed valve body. External coolant filter. International Up Pipes.
1994 RAM 4x4 Cummins KNN, 3GSK, AFC Spring, #10 Plate, BD Valve Body, KDP, SCHWITZER S300 turbo 4" TBE.
jroller is offline
