2001 f250 psd rear end problem - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 02-18-2010, 04:00 PM Thread Starter
spongebob915's Avatar
Not sure what the problem is but here are the symptoms. When you give it alittle gas it feels like the rear end has same play in it .I took it somewhere for some unrelated issues and they took a look at it and said the problem may be in the rear . He could see the drive shaft spin maybe a little less than 1/2 revolution before it would engage the wheels . It does not appear to make any noises when I drive just when you start to take off you can feel the slake ..
ANT IDEAS
spongebob915 is offline
post #2 of 12 (permalink) Old 02-18-2010, 08:06 PM
klhansen's Avatar
My Photos: (180)
I think I'd steel myself and take the rear cover off. Probably be ready to catch chunks of steel in the drain pan.
At least after that you'd have a much better idea what was wrong. If everything looked good inside the axle, then you could button it back up, fill with fresh gear oil, and be happy about it.
), AIS,
regulated return,
klhansen is offline
post #3 of 12 (permalink) Old 02-19-2010, 04:32 PM
Do you have a Limited Slip??? I recently experienced some problems with Drive Train and it turned out to be a fluid problem in the rear end.
Ford recommends 4oz of Abrasive Additive but I've been told by a buddy to put in 8oz. Fixed my problem.
If not a Limited Slip, never mind...........
2001 F250, 4X4, ext Cab, LWB, ATS Trans..
jpjohnson is offline
post #4 of 12 (permalink) Old 02-19-2010, 07:24 PM
Flywheel's Avatar
What the above posters said.
But I might also put the truck in neutral and see for myself how much "free" rotation the DS has. In my experience it should be about 10-20 degrees.
If it is more, I would say that you have a problem with your pinion bearings.
I had a similar problem with the ranch truck I got and the driveshaft slipjoint was rusted solid. This put a lot of pressure on the pinion when the truck was loaded down and the pinion could move in and out (after I removed the DS) and also side to side. Showed similar symptoms to what you are seeing. This was a pretty bad neglected case, maybe yours is a bit less severe.
Keep us posted.
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #5 of 12 (permalink) Old 02-19-2010, 08:05 PM Thread Starter
Was it costly to repair it ??
post #6 of 12 (permalink) Old 02-19-2010, 08:15 PM
Flywheel's Avatar
$400 for a used rear end - ended up doing it a couple of times - but I can swap a rear end in about an hour!!
Autoenginuity
Flywheel is offline
post #7 of 12 (permalink) Old 02-19-2010, 08:35 PM Thread Starter
So you changed the whole axle ?? Or just the internal parts
post #8 of 12 (permalink) Old 02-19-2010, 08:47 PM
Flywheel's Avatar
Yes - cheaper knowing the amount of damage there was - had chipped teeth so new ring and pinion for $250 then bearings and labor would have been pricey. It had some problems - gotta catch these things fast like you have done.
Autoenginuity
Flywheel is offline
post #9 of 12 (permalink) Old 02-19-2010, 08:50 PM Thread Starter
So I guess I should not really be driving it until I repair or it may do a lot more damage .
post #10 of 12 (permalink) Old 02-19-2010, 10:08 PM
I have first hand knowledge on the cost of rear end repair. I had three teeth chipped on the ring gear as well as some burs on some of the teeth. It was $2000 for a ring and pinion, bearings , seals and labor to repair. I decided since I was going that far I would get a real rear end. I also had them install a Detroit Locker for another $500 in parts. But I am a happy camper now.
handsome is offline
post #11 of 12 (permalink) Old 03-02-2010, 06:01 PM Thread Starter
Update
Took my truck to two different shops . The first shop said it looks like you need to replace your gears in the rear .. $920 . I did not like there answer or confidence so I took it to a different shop. The second shop had it and after about one hour they told me it was the drive shaft slip joint where the two drive shafts come together . They pulled it apart and it had what looked like plenty of grease so they put some more in it . Put everything back together and now the noise and the bump is all gone . Total repair $56 ..
post #12 of 12 (permalink) Old 03-02-2010, 09:51 PM
My Photos: (19)
Ah, the old 'grease up the slip shaft' trick! that used to be suggested quite a bit here, times have changed. Glad you got the problem fixed. Some guys have drilled and installed zerk fittings in their slip shaft so they can keep it lubed up without having to remove it again.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
