2001 F250 SD Transmission Shifting Issues and Codes - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 06-16-2009, 08:32 PM Thread Starter
Hi All,
I have a 2001 F250 4WD with the 4R100 automatic transmission with 69,000 miles. I run the Diablo Predator 85HP tune with firm shift points. In April I noticed the truck shifting rough from 1-2 and 2-3, slipping, having a rough high idle, and the Overdrive light flashing. The truck also completely shut off in traffic.
It threw the following codes:
P0238 - Turbo/Supercharger Boost Sensor A Circuit high
P0603 - Powertrain Control Module Keep Alive Memory Error
P0478 - Exhaust Pressure Control Valve High Input
P0470 - Exhaust Pressure Sensor
I reset the codes and did not have a problem for a month, but I also rarely drive the truck.
Today I experienced the same problems shifting, slipping, and overdrive flashing. In addition to the codes above, I also have
P0720 Output Shaft Speed Sensor Circuit.
I have a call in to the Ford Dealer, but am interested to see if anyone can help diagnose and provide recommendations. The Ford dealer wants $735 in labor alone and recommends an overhaul or rebuild, but will get back to me with better estimates.
If I need to put in a new transmission, what are the thoughts about the ATS or other? Any recommendations for a good transmission shop in Northern Virginia?
Thanks!
chigl is offline
post #2 of 15 (permalink) Old 06-16-2009, 09:34 PM
MonteC's Avatar
Youve got the answer right in your post.
My finger is pointed squarely at the OSS. Look to see if the wiring is ok, if so, id suspect a fautly OSS.
MonteC is offline
post #3 of 15 (permalink) Old 06-20-2009, 07:47 PM Thread Starter
Thanks Monte - Any idea what the part # is for the OSS? I checked the wires and cleaned the contacts and still have the error code and flashing overdrive.
chigl is offline
post #4 of 15 (permalink) Old 06-20-2009, 11:52 PM
woodnthings8's Avatar
Here is some info from my manual. It may help you but most likely the only thing you can do without a OEM scanner or an AE is to check the connectors and do the ohm check at the end
PINPOINT TEST F: TURBINE SHAFT SPEED (TSS) AND OUTPUT SHAFT SPEED (OSS) SENSORS
CONDITIONS DETAILS/RESULTS/ACTIONS
NOTE: Refer to the Output Shaft Speed (OSS) Sensor Connector illustration preceding these pinpoint tests.
F1 ELECTRONIC DIAGNOSTICS
Check to make sure the transmission harness connector is fully seated, terminals are fully engaged in connector and in good condition before proceeding.
Scan Tool
Diagnostic Data Link
PCM
Select PID/Data Monitor and Record.
Select the following PIDs: TSS, OSS.
Does vehicle enter PID/Data Monitor and Record?
Yes
REMAIN in PID/Data. GO to F2 .
No
REPEAT procedure to ENTER PID. If vehicle did not enter PID, REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual ( OBDII Early release , OBDII-Diesel , OBDII-Bi-Fuel ) for diagnosis of PCM.
F2 DRIVE CYCLE TEST
While monitoring the appropriate sensor PID, drive the vehicle so that the transmission upshifts and downshifts through all gears.
Does the TSS, or OSS Speed PID increase and decrease with engine and vehicle speed or is the sensor signal erratic (drop to zero or near zero and return to normal operation)?
Yes
If the TSS or OSS Speed PID increase and decrease with engine and vehicle speed, CLEAR all DTCs. ROAD TEST to verify if concern is still present. If concern is still present, REFER to Diagnosis By Symptom in this section for diagnosis.
If the sensor signal is erratic, INSPECT for intermittent concern in the internal/external harness, sensor or connector.
No
If the TSS, or OSS Speed PID does not increase and decrease with engine and vehicle speed, INSPECT for open or short in vehicle harness, sensor, a PCM concern, or internal hardware concern.
If the sensor signal is steady, GO to F3 .
F3 CHECK RESISTANCE OF TSS OR OSS SENSOR
Disconnect the appropriate vehicle harness connector from the TSS and or OSS sensor.
For TSS or OSS: Measure the resistance between pin 1 and pin 2 at the sensor.
Record the resistance. Resistance should be as follows:
Sensor Resistance (ohms)
TSS — PTO Only Applications 496-1,244
TSS — Non-PTO Applications 781-1,979
OSS — All Applications 781-1,979
Is the resistance within specification for the appropriate sensor?
Yes
REFER to Diagnosis By Symptom in this section for concern diagnosis.
No
For TSS and OSS, INSTALL a new sensor.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #5 of 15 (permalink) Old 07-13-2009, 12:50 PM Thread Starter
Scan Tool
PCM
Yes
No
F2 DRIVE CYCLE TEST
Yes
No
Yes
No
Thanks - I cleared all the codes and drove the truck again this weekend. and the same thing happened. I am getting the VSS and OSS trouble codes. Does anyone have the part # for the OSS? I'll check the resistance on both sensors and see what I find out.
chigl is offline
post #6 of 15 (permalink) Old 07-13-2009, 02:15 PM
Call the Ford dealer, I'm sure they have a number, When you get one post it here for others. I looked and do not have it in my list of numbers.
Ken
post #7 of 15 (permalink) Old 07-14-2009, 06:39 PM Thread Starter
Thanks Woodnthings - I'll post when I get the part #.
chigl is offline
post #8 of 15 (permalink) Old 07-15-2009, 09:01 AM Thread Starter
Ford Transmission Part #'s and Pictures
The attached pdf has pictures and part #'s for the E4OD and 4R100. It might be of use to someone else out there too. I think the VSS/OSS part # is F81Z-7M101-AA
File Type: pdf Ford Transmission Parts Info E4OD and 4R100.pdf (687.8 KB, 2597 views)
chigl is offline
post #9 of 15 (permalink) Old 09-28-2009, 10:27 AM Thread Starter
Alternator was bad!
Update: I ended up having the alternator replaced. When they ran a diagnostic check on the truck, the computer indicated the truck was going 30-70 MPH while sitting still. While I did replace the OSS, that was not the culprit. There was some sort of RF interference from the alternator.
chigl is offline
post #10 of 15 (permalink) Old 02-06-2012, 08:28 AM
Having a similar problem... How did you come to the conclusion the alternator was bad? I'd like to test all I can before I settle on a rebuild
Sent from my Autoguide iPhone app
01 F250 Lariat CCSB, BTS, ICON 4", 35" Toyo MT on 18" Fuel Hostage, DP F6 Tuner, 6637, 5" pipe-muffler, Recon lights all around, 35W Retro HIDS, Custom LED interior
HEROS NEVER FALL.... THEY EARN THEIR WINGS.... RIP LCPL JASON D. HILL - IRONMAN, YOU WILL NEVER BE FORGOTTEN. SEP 18 1990 -JUNE 11 2011
PBGUY420 is offline
post #11 of 15 (permalink) Old 02-06-2012, 08:59 AM
Mark Kovalsky's Avatar
My Photos: (6)
An oscilloscope is needed to diagnose an alternator that has an RF problem.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #12 of 15 (permalink) Old 02-06-2012, 03:40 PM
Ok do autozone or advance usually have those and know how to use them
PBGUY420 is offline
post #13 of 15 (permalink) Old 02-06-2012, 07:48 PM
My Photos: (6)
They probably don't have them and I'd be VERY surprised if they did and had any clue how to use them. They sell parts, they don't diagnose, even though they think they do.
Mark
Former
post #14 of 15 (permalink) Old 02-14-2012, 02:50 PM Thread Starter
Disconnect the alternator and drive the truck. If the code still presents, the alternator is fine. Iultimately replaced the trucks PCM computer.
chigl is offline
post #15 of 15 (permalink) Old 10-16-2012, 10:44 PM Thread Starter
Problem Resolution
While I replaced the alternator, this did not solve the poroblem. I eventually isolated the problem to a loose solenoid connection on the passenger side fender well. It was loose and after I tightened it I have had absolutley no issues.
chigl is offline
