Originally Posted by Scott52575
1. This is an F250 4WD shortbed supercab with 60,000 miles
2.I just rebuilt the tranny 2K miles ago due to the DIODE SPRAuGE FORD screw up.
3. I removed the muffler and replaced with a 3.5 inch striaght pipe to match stock exhuast there was no CAT CNVRT on the system.
First issue ....Feels like the truck has lost maybe 35 % of it's get up and go have done regular maintenance and towed 5 trailers in 6 yrs of owning.
Fuel Efficiency seems to be around 15 MPG but fuel sending unit is goofy and reads empty when you have 5 or 6 gallons left is this normal? for both fuel economy and guage reading that way?
SECOND issue... I noticed in cold weather last few years the wastegate is hanging open and hissing out the tailpipe until truck warms up is my wastegate worn out or the actuator leaking or sluggish ??? Is this why I have lost power IE the boost is getting shunt out thru the tailpipe ???
Finally I love this truck and have heard there are chips that will improve economy and power , can I do this without hurting my truck since the weak tranny parts have been fixed??? and should I install boost/exhuast temp/oil temp guages/ tranny temp... if I do this first and who makes the best chip for the lowest cost that will improve MPG and power if I want it? and is this a good way to go ???
Just needed some guidance I love this truck she is just about paid off ......I almost totalled it 2 weeks ago in the snow don't drive with bald tires in 2 wd leson learned as I went sideways down I-75 looking at a new dodge charger thru my windshield in the other lane he wasn't impressed lol.
Personally, I don't recommend the chip, because I feel that it will shorten the life of the engine and transmission and other components, but a lot of people like the chips. Go to the modifications section of this website for more discussion.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,00 miles when purchased, now has 149,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
