Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 06-25-2008, 03:30 PM   #1 (permalink)
2002 250 Super Duty will not start
My fuel gauge is off and apparently getting worse. The other day I pulled out of the driveway with what I thought was 1/4 tank but soon (about 50 feet) the truck started acting like it was out of diesel. I keep a fuel tank in the bed just for this occasion but after refilling, the truck started, but was running very rough. Then it stalled and I have not been able to get it to start again. It has signs of live but never fully started. Can anyone suggest a fix?
adkinsbj is offline
Old 06-25-2008, 03:41 PM   #2 (permalink)
klhansen's Avatar
My Photos: (85)
Welcome to TheDieselStop.com
Maybe your fuel pump has lost it's prime. The suction side of the pump is notorious for leaking at the quick connectors and drawing air into the system.
Have you checked to see if there's fuel in the filter cannister?
You might try pressureizing your fuel tank with a shop vac on "blow" and see if you can get it to go.
Also your batteries may have drained far enough that your electroonics (PCM & IDM) have quit working. Try putting a good charge on the batteries.
Good luck.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 06-25-2008, 08:20 PM   #3 (permalink)
99 STROKER's Avatar
Had the same problem once I pressurized the fuel tank with an air hose and ti fired right up.
Early 99 F-350 superduty, 4x4, ext. cab, dually,pillar pod,boost,pyro,trans temp gauges, straight piped, open air intake,waste gate removed and welded shut, X6TC triple disc billet torque converter, HD2 tugger kit,TransGo convertor lockup valve,Red eagle cluches with kolene steels. other that that pretty stock.
99 STROKER is offline
Old 07-04-2008, 01:50 PM   #4 (permalink)
Of course, it MIGHT be the infamous CPS issue. Only $15 plus 10 minutes of your time. Let us know what it turned out to be.
Tailgate
2000 X PSD Ltd, 4x2, 3.73 LS, DP Tuner 16 position chip, Autometer gauges, AIS intake w/ Zoodad, Tymar H/X, Walker BTM, Dahl 100 fuel filter, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil all-around, PSD Badging, Extra Tint, Bridgestone Dueler Revo A/T tires
Tailgate is offline
Old 07-04-2008, 04:16 PM   #5 (permalink)
Mad Max's Avatar
Sounds like it time for this mod... ITP 7.3L Fuel Tank / Pre-Pump Kit
If you live in AZ come join us at Arizona Powerstroke Group... Click here...
http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 PSD Lariat, 4x4 Off Road, CC, SB, 3.73's, NVK2, BTS Trans and T/C, V-10 and Tru-Cool Max Trans Cooler, Evans NPG Coolant, BTS 100 HP Chip, ART Cryogenically Treated & Slotted Rotors with Performance Friction Brake Pads, Dynatrac Spin Free HD Front Hubs, TAG I & II, Ford AIS Intake, 4 inch Stainless Exhaust from turbo to 5 inch chrome tip. Auto Meter Ultra Cobalt Gauges. 35X12.5 BFG KO's on 16x10 Rims, Bilstein Shocks.
Mad Max is offline
