2002 4x4 Excursion Transmission question - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-22-2006, 03:22 PM Thread Starter
I have used this truck to tow a 34' 9600 lb TT. Currently has 118k on it. Towing probably constitutes 15% of the mileage. I have towed the last 2 weekends with strange results. 1st weekend was to the mountains in NC but I was only towing a utility trailer with a four wheeler on it. I never noticed any problems until we stopped to drop the four wheeler off on the return trip. I had towed about 200 miles when we stopped. After dropping off the four wheeler the truck would not drop into 1st gear. (it is an automatic BTW) I tried to manually move it into first and second and it wouldn't go into either (IE, the lever moved correctly, but the transmission acted as if it was in high still.) I turned the truck off and back on and the problem went away. The transmission temp gauge was reading in the middle like always.(I do not have an aftermarket gauge)
This past weekend I hooked up the camper to go to the beach. As soon as I started down the drive way the I noticed the truck wasn't in low. Went through the routine again (shifted to 1st and 2nd then turned the truck off.) Same results. Shifted fine after that. Worked fine the rest of the weekend. BUT, I have a 2 week trip to Florida planned for this June. So, I am wondering if there is something I should be doing now, to try to find a potential problem.
The last time I changed the transmission fluid (at 90k miles BTW) I used Mobil1 ATF. We do NOT put a whole lot of miles on this truck. (Been almost a year since I changed the fluid and we took a long trip right after I changed the fluid last spring)
Any suggestions or ideas? I am thinking I may do another transmission fluid change IF I can find the right transmission fluid (I read a post somewhere that Mobil1 has changed their ATF to be Mercon V) Past that I am not sure what else to try.
Thanks in advance for any suggestions,
greg
GregW is offline
post #2 of 8 (permalink) Old 03-22-2006, 03:26 PM
Banned
My Photos: (38)
Re: 2002 4x4 Excursion Transmission question
I would have the codes pulled and see what they say.
gregrob is offline
post #3 of 8 (permalink) Old 03-22-2006, 03:28 PM Thread Starter
Even though there were no flashing lights or anything (O/D light not flashing or any other indicators that I could see) ? You think it may have some sensor going bad in the transmission?
greg
GregW is offline
post #4 of 8 (permalink) Old 03-22-2006, 03:33 PM
Banned
My Photos: (38)
Could be the shift solenoids. It doesn't always have to turn on the warning lights to have a code.
gregrob is offline
post #5 of 8 (permalink) Old 03-22-2006, 04:02 PM
Add 1 can of TRANS-X and it will take care of that sticking valve.
1999 F350 XLT DRW CC auto 373 gears 4x4.
cold air intake
4" strait SS exhaust
ATS housing
W Wheel
Turbo Timer
manual waste gate
boost pop off
dual tranmission cooler
no exhaust valve
tripple phantom gauges
dieselsite 6 position chip
oil cross over line
transmission valve body
Billit Torque converter
crowhater is offline
post #6 of 8 (permalink) Old 03-22-2006, 05:32 PM
fordmastertech's Avatar
[/ QUOTE ] And the rest of the transmission along with it. Transmission over haul in a can never takes care of the real issue with the transmission.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #7 of 8 (permalink) Old 03-24-2006, 12:46 AM
[/ QUOTE ]take it to a reputable transmission shop ( not aamco or cottmans ) and they will probably put it on the scanner for free. ( we do )Most of the time it is the solinoid pack in late model E4OD and 4R100. I have also seen the ignition switch cause the same prob but that usually affects the lockup on the torque converter causing it to slip while trying to lock. this mostly happens on GM 4L60E and 4L80e but some fords to. hope you catch it soon or you may be looking at some$$$$$$$ [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 f-250 crewcab lwb 7.3powerstroke.32" BF goodrich A/T. A.R.E. bedcover. edge attitude chip. seatback DVD player installed.Westin nerf bars and sportsman brushguard with 8" 800 wt IPF lights and stone guards
ray1976 is offline
post #8 of 8 (permalink) Old 03-24-2006, 12:52 AM
clamgulch's Avatar
That's my guess. I think you can get that done for under $400. Time to start thinking about your new BTS tranny.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
