2002 Powerstroke Turbo Seal Leaking - Diesel Forum - TheDieselStop.com
Old 11-13-2010, 01:02 PM   #1 (permalink)
I have a 2002 Ford Excursion with a 7.3 Powerstroke and the turbo oil seals seem to be leaking. I have inspected the HPOP to make sure both plugs and hoses are not the source of the leak and I can't see any cracks in the turbo sleaves. So I think the oil o-rings on the turbo seem to be the source.
Can anyone give me an idea of how hard it would be to replace the turbo o-rings? Do I just need to completely remove the turbo and re-install it with a new gasket and o-ring set?
Any help and/or web resources that you can pass along are appreciated.
bthorman is offline   Reply With Quote
Old 11-13-2010, 01:24 PM   #2 (permalink)
RT
RT's Avatar
The turbo has to come off. If you are talking about internal seals, it has to be rebuilt. If you are talking about an external leak, it is the turbo pedestal that has the o-rings that leak. Here is the best place to buy them. Also, about halfway down the page is a link to a .pdf instruction sheet.
http://www.dieselorings.com/index.ph...&cat=9&group=6 for just the o-rings
Replacement O-rings for Ford Diesel Engines for the whole kit
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 11-13-2010, 07:13 PM   #3 (permalink)
Thanks dray8165 for the information. I'll post the experience/results of my work on this problem.
Old 11-13-2010, 07:39 PM   #4 (permalink)
I found this article that I'm going to try to use to remove the turbo and pedistal for the o-ring replacement.
99-03 Turbo Removal & Wicked Wheel Installation .: Articles
Old 11-13-2010, 07:43 PM   #5 (permalink)
RT
RT's Avatar
It looks like the one I referenced above. In case you didn't see it (its buried in the page on the whole kit of o-rings), here is the direct link:
http://www.dieselorings.com/docs/Pow...structions.pdf
Old 11-29-2010, 01:08 PM   #6 (permalink)
Muddinf2501999's Avatar
The guys have given you good info! Nice write up! Its not a tough job at all, just a little time consuming to do it right. Well worth it though!
'99, 7.3L PSD F250 4x4 SRW
Mods: BTS Tranny!!!!, Rockwell 2 1/2 ton axles, Goodyear MVT 395/85R20's and Schaeffer's Oil
'02, 7.3L PSD 6spd F350 4x4 DRW CC
Mods: IH Bellowed Up-pipes, 4" MBRP Turbo Back Exh, B&W Gooseneck Hitch, Michelin LTX A/T2 235/85R16's and Schaeffer's Oil
Muddinf2501999 is offline   Reply With Quote
