2003 7.3 4X4 Torque Converter Lock Up Problems, at my wits ends please help - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 09-13-2012, 04:32 PM Thread Starter
Unhappy 2003 7.3 4X4 Torque Converter Lock Up Problems, at my wits ends please help
about 6 months ago i traded my tow truck for this 2003 Lariat F250 PSD 4X4, and from day one i knew there was something not quite right about the transmission.
when it started getting bad i lost my cruise control, and my TC lock up in over drive. it was a bad connection at the transmission. So i cleaned up the plug put electrical grease on it and it solved my problem for about 3 weeks.
well after the problem occurred again i couldn't fix it, meaning it wasnt a bad connection any more. so being it was my only vehicle i had to continue driving it with out the tc locking up.
shortly after that i burned up the transmission, no forward only reverse. i removed the transmission, had it rebuilt with a new heavy duty torque converter for around $1200
after installing it trans shifted great but still no tc lock up. and now after driving it for 2 weeks in its current state second gear is starting to slip and vibrating pretty bad like it dont want to slip but it kinda is.
im thinking im over heating the trans being i dont have a properly working temp gauge for it. im assuming the tc not locking up is causing my trans temp to shoot up.
further diagnosis says the pcm is not giving the command to lock up the tc when its in over drive (4th Gear)
Can some one for the love of god help me get this straightened out????
i ohmed out all the wires coming from the pcm to the trans and they all check out. no shorts, no broken wires. but i did fine that 3 grounds going to the pcm are not finding a ground. those 3 grounds are supposed to ground out on the fire wall i tested the grounds and they are grounding out but i dont think they are grounding out the pcm..
thanks in advance
Tommy_PGT is offline
post #2 of 19 (permalink) Old 09-13-2012, 05:58 PM
Bill1013's Avatar
Does the PCM have a chip installed.? Has the PCM been reprogrammed? Did the PO install the TC lockup mod? Is there a switch on the dash that you don't know what it's for? Just info. The TC should lockup at about 27MPH when upshifting into 3rd, it's possible to shift into OD at 36 to 40 MPH depending how fast the accelleration is.
If no up shift 2 to 3, S1 solenoid could be defective, also check connector plug on pass side of trans.
This is what I don't understand. If the TC didn't lockup, then your still driving around in 2nd gear, that's why the tranny burned up again. You must of had awful high RPM's to go anyplace, or your not stating it right.
"trans shifted great but" Did it up shift 1st to 2nd @ 12-15 MPH--2nd to 3rd @ 26-27 MPH ---3rd to OD @ 36 to 40 MPH as said before? You cannot go into OD if the TC is not locked up.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #3 of 19 (permalink) Old 09-13-2012, 06:56 PM
Mark Kovalsky's Avatar
Of course you can. Overdrive and lockup are separate. The transmission will shift into overdrive without the torque converter locking.
The way to fix this is to get a scan tool that can read live data. Then you'll need to monitor the inputs that the PCM uses to determine what is preventing lockup.
One thing you can check is the brake lights. If one of the three brake lights is not working it can keep the converter from locking.
Mark
Mark Kovalsky is online now
post #4 of 19 (permalink) Old 09-13-2012, 09:06 PM
Bill1013's Avatar
Thanks for that info Mark. I was under the impression that was how it worked. Wouldn't that create a tremendous amount of heat in the TC tho?
Bill1013 is offline
post #5 of 19 (permalink) Old 09-13-2012, 09:18 PM
It could, yes, but it even when operating correctly the torque converter can be unlocked in fourth gear.
Mark
post #6 of 19 (permalink) Old 09-18-2012, 09:53 AM Thread Starter
Like I Said before the snap on scanner said the pcm is not even sending the command to lock up the converter, everything that was mentioned about checking has been checked several times. this is why im screwed looks like i will be ripping this trans mission out every 2 weeks for a rebuild because my tc wont lock up lol
post #7 of 19 (permalink) Old 09-18-2012, 09:55 AM Thread Starter
yes i run an edge programmer on a stage 2 but i have had the truck un programmed and i get the same results, no tc lock up mod but looks like im going to have to do it. tc only locks up in 4th gear well should any ways.
post #8 of 19 (permalink) Old 09-18-2012, 01:34 PM
You can throw a new trans in every day and you won't fix this. Something is telling the PCM not to lock the converter. You will need to monitor data to see what it is. The parameters that I can think of include brake lights, throttle position, engine speed, turbine speed, vehicle speed ,engine temp, and trans temp. There are probably a few more, too.
Mark
post #9 of 19 (permalink) Old 09-18-2012, 01:36 PM
The torque converter can lock in all four forward gears if the conditions are right.
Mark
post #10 of 19 (permalink) Old 09-21-2012, 01:50 PM Thread Starter
do you guys think the tc is burning my tranny up??
post #11 of 19 (permalink) Old 09-21-2012, 02:49 PM
No.
Did you read this?
Mark
post #12 of 19 (permalink) Old 09-21-2012, 09:00 PM
Rich D's Avatar
Why don't you spend a $100 or so and have Ford or a shop run a tool on it, to see why it's not locking up, could be a PCM issue or something cheaper than that.
You can also try to swap in a used PCM and see what happens.
Early 99 F250 XLT,White/Silver,4x4,SC,SB,A/T,PMT1,ARE LSII tonneau,Amp Research power steps,MB Razor's,295-60-20 Nitto Trail Grapplers,Rhino Liner,Rancho9000's,Bushwacker Street Flares,DP-Tuner F5,True-Cool Max,AFE modified-W.D.RamAir,5"Hypermax exhaust,Hypermax DP,Firestone Ride-Rites,2.5" front leveling leafs,AutoMeter-ProComps/triple pillar,heated TTT mirrors,DEI remote start,Amsoil enhanced.
Rich D is offline
post #13 of 19 (permalink) Old 09-22-2012, 10:32 AM Thread Starter
its honestly getting to complicated for me to figure out it will probably have to be dropped off at ford so they can figure it out. problem is im broke as **** so my options our limited.
I just dread taking it to ford being they are going to just throw a bunch of parts at it and charge me for it while i still have the same problem thats the dealer for you.
post #14 of 19 (permalink) Old 09-22-2012, 11:36 AM
A good independent shop would probably cost a lot less and do at least as well.
ASA Shop Locator
Mark
post #15 of 19 (permalink) Old 09-22-2012, 12:02 PM
Bill1013's Avatar
Don't know why people don't put there location in there profile. If they have a problem, I'd be more than willing to scan for them, providing there close to me, or if they want to come to me. Just PM me. I think this guy is gonna spend more money than an AE scanner would cost.
Bill1013 is offline
Gear in this thread - Powered by O'Reilly Auto Parts
