2003 7.3 no power at fuel pump or fuse # 30 - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 01-06-2010, 08:08 PM Thread Starter
I have a 2003 F250 and dont have power at fuel pump, or fuse #30. I put power directly to fuel pump and it worked and truck fired right up.
Can anyone please help?
dustys7.3psd is offline
post #2 of 12 (permalink) Old 01-06-2010, 08:13 PM
RT
RT's Avatar
You don't have power to either side of fuse 30? The diagram would seem to indicate one side should be powered all of the time:
http://www.justanswer.com/view_image..._184109_30.gif
You might want to unplug your the heater plug in the fuel filter bowl to make sure you don't have a grounded circuit if it is blowing fuses.
RT is online now
post #3 of 12 (permalink) Old 01-06-2010, 08:35 PM Thread Starter
Fuse # 30 is high beam headlights thats why IT has no power. Fuel heater is fuse # 105 a big square 30 amp fuse. My fuel pump is fuse # 40 and i have power to both sides of it.
I do have a TS performance chip. Last night It fired up and ran really rough and felt like only running on like 2 cylinders. I would try to give it throttle and rpms would not change at all. I barely got out of my neighborhood going like 10 mph is all it would do. I then pulled over on the side of the road and it started running even rougher and then died. I tried to crank it and it would spin over and over and over and it would never crank.
I towed it home and thought it might have been a clogged fuel filter so i changed it this morning and still it didnt do anything. I finally went and got a can of Ether and sprayed it very carefully and got it to crank. I could keep it running as long as i get spraying a fine mist into the intake. But as soon as i stopped spraying it would die.
So that is were i am at now. Put power to the fuel pump and ran great.
But not getting power to the fuel pump is my problem right now.
And i did check the reset button on kick panel.
post #4 of 12 (permalink) Old 01-06-2010, 09:17 PM
losfinch's Avatar
Uh, not sure what year truck you have and all but I'd try what he said...unplug the fuel bowl heater wire and make sure you've got a good fuse in the #30 fuse position...regardless, just try it. The fuel bowl heaters are notorious for shorting out and causing the #30 fuse to blow. Just try it...won't cost you anything.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #5 of 12 (permalink) Old 01-06-2010, 09:19 PM Thread Starter
Its a 2003 f250 and all my fuses check good. none of them are blown.
post #6 of 12 (permalink) Old 01-06-2010, 09:19 PM
RT
RT's Avatar
Wow. Guess the guy who drew the diagram was wrong. Sorry for the misinformation....
RT is online now
post #7 of 12 (permalink) Old 01-06-2010, 09:25 PM Thread Starter
I verified that fuse # 30 is headlights because when i turned the headlights on i got power on the fuse and when i turned them off i lost power.
But i have been reading on the older model trucks that fuse # 30 is the fuel bowl heater.
post #8 of 12 (permalink) Old 01-06-2010, 09:31 PM Thread Starter
Where is the fuel pump relay on a 2003 f250 7.3?
post #9 of 12 (permalink) Old 01-06-2010, 09:43 PM Thread Starter
I took the radio out hopeing that the fuel pump relay was behind it like i have been reading but no luck.
Still looking for it.
post #10 of 12 (permalink) Old 01-06-2010, 10:05 PM
greasyf250's Avatar
The relay , I think is built into the central junction box with the fuse box . Its not serviceable. Check out this thead on powerstroke.org
Fuel pump not getting power - Ford Powerstroke Diesel Forum
Western New York Biodiesel co-op
greasyf250 is offline
post #11 of 12 (permalink) Old 01-08-2010, 08:29 PM Thread Starter
I have found the problem.
I have forgotten to share one of the main add ons on my truck. I have a veggistroke kit.
The reason for the fuel pump not getting power was because the power for the fuel pump runs through my veggie kit and my veggie kit tells my diesel pump when to turn on. And a RELAY in the veggie system was the cause.
They say its not common for the relay to go out but i am lucky number two that it has happened to.
Other then the relay, the veggistroke kit is bullet proof and its the best thing i ever installed on my truck. And i have already put easily 50,000 miles on the system and this is the first problem.
post #12 of 12 (permalink) Old 02-17-2010, 05:15 PM
vandiesel's Avatar
Was this a greasecar system? I'm having the same problem
vandiesel is offline
