2003 F250 4x4 Wheel Hub - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 01-30-2006, 03:20 PM Thread Starter
I just got off the phone with the local parts store and found out that I needed to replace the whole hub as I have a bearing gone bad. Does anyone know of a good source for these? And is the R and R fairly simple.
CFTH
centralfloridatrophyhunts.com
2003 4x4 CC 7.3
cfth is offline
post #2 of 17 (permalink) Old 01-30-2006, 04:09 PM
klhansen's Avatar
My Photos: (180)
Re: 2003 F250 4x4 Wheel Hub
You should be able to pick up a hub/bearing assembly for a bit less than $300 at a driveline shop or major parts store. You could go to the dealer, but you'd be charged a lot more for the same part.
Replacement is straightforward. Remove wheel, remove brake caliper and set out of the way, remove hub snap ring and hub, remove axle snap ring and washers, unbolt hub from inside knuckle and remove. Put everything back the way it was, paying attention to the way all the parts came out. You'll need a decent torque wrench, as the hub nuts need 133 ft-lb, and caliper bolts are 166 ft-lb.
You should also change the large o-ring at the inboard end of the hub/bearing assembly and the o-ring on the locking hub so you don't have a vacuum leak. That would cause your ESOF hubs to fail to work.
If you need more info, ask.
Hope that helps.
), AIS,
regulated return,
klhansen is offline
post #3 of 17 (permalink) Old 01-30-2006, 06:16 PM
Flywheel's Avatar
In Addition to Kevin's post - I have had good luck going to Ford and buying the 4 studs that mount to the hub and then you bolt to the knuckle. The Studs were stubborn to remove from the original hub - they are $12 or soo..
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #4 of 17 (permalink) Old 02-01-2006, 04:00 PM
I can't find a parts store in central florida for less than 375.
2003 F-350 Diesel
2001 Sand Drag Yamaha Banshee (sold)
2004 LE Grizzly
Autometer NV Gauges, Overboost regulator, AIH delete plug, AFE I intake, 4" turbo back exhaust system, HX Line, Transgo Tugger Kit, DP F5 Tuner, No start, Stock, 60 HP tow, 80 HP econo, 120 HP Race, High Idle.
Big Thanks to DP Tuner and ITP Diesel!!
smoknbanshee is offline
post #5 of 17 (permalink) Old 02-01-2006, 08:01 PM Thread Starter
I replaced the hub last night. The hub from NAPA in Cocoa, FL was $285 plus tax. Thanks for all of the input was a very simple R and R. (Except the part they gave me had the course thread wheel studs).
CFTH
2003 4x4 CC 7.3
cfth is offline
post #6 of 17 (permalink) Old 02-06-2006, 12:14 PM
You should be able to pick up a hub/bearing assembly for a bit less than $300 at a driveline shop or major parts store. You could go to the dealer, but you'd be charged a lot more for the same part. . . . .
. . . If you need more info, ask.
Hope that helps.
Got that far. ON mine the needle bearing for the short shaft seems to be bad. Do you know if there is a readily accessible replacement for this, if the rest of the hub and the larger hub bearing aren't damanged?
'01 F250 CC PSD 4x4 Lariat, auto, ESOF, 3.73s; born on 5-01; Ranch Hand front and back; Weatherguard box; Optima reds; Bilsteins, Powerstops and Hawks at 80k; Rotella T and Motocraft filters; 95k miles as of 8/06; 275/65/20 Goodyear Wranglers
BPUs: Zoodad mod (where's his royalty check), AFE II, MBRP 4", DI 6 position, Autometer Phantoms on A-pillar and under the dash
Plans: heavier front leaf springs, F350 rear blocks, more power . . .
3 back surgeries and one rear-end accident later - screw the other guy, I'm in the big truck this time!
backpain is offline
post #7 of 17 (permalink) Old 02-06-2006, 12:15 PM
griffy71's Avatar
NAPA. It is called a spindle bearing.
Griffy71
Necessity is the mother of invention.
If it jams, force it. If it breaks it needed fixing anyway.
01 F-250 PSD 4x4 Extended Cab, Bully Dog Chip, Homemade Tymar, AIH delete, Fumoto Drain Valve, Wicked Wheel.
griffy71 is offline
post #8 of 17 (permalink) Old 02-06-2006, 12:28 PM
My closest NAPA only had the hub assembly listed. Will call again and talk to someone else or try a few other locations.
backpain is offline
post #9 of 17 (permalink) Old 02-06-2006, 12:28 PM
Are the "spindle" bearings replaceable without replacing the entire hub ? If so are any special tools required ? I see that the are inside the hub with a strange looking four sided nut or whatever it's called holding them in. Does this just come off or what ?
'99 F-250 HD diesel EC 4x4 George West, TX
Kwik filter, ELC, Ranch Hand bumper guard, Warn hubs, SS HPX, 6.0 tranny cooler, Bilsten shocks
RobertJohn is offline
post #10 of 17 (permalink) Old 02-06-2006, 12:29 PM
griffy71's Avatar
Can talk to my NAPA and have it sent to your napa
Griffy71
griffy71 is offline
post #11 of 17 (permalink) Old 02-06-2006, 01:49 PM
Ford P#C6TZ3123A. Thanks Chris at Powerstroke shop.
backpain is offline
post #12 of 17 (permalink) Old 02-06-2006, 01:51 PM
I think it's a special tool to remove that big lock ring, and the bearing, hopefully, is pressed into its seat underneath. Hopefully I find out before end of day. . .
(EDIT) see below. It does just press right in. Once I bought the part, it was obvious. (EDIT)
backpain is offline
post #13 of 17 (permalink) Old 02-06-2006, 02:05 PM
I'd appreciate your letting me know what you find out.
My hubs are good it's just the spindle bearing thats bad.
post #14 of 17 (permalink) Old 02-06-2006, 02:38 PM
griffy71's Avatar
I'm pretty sure that the bearing is pressed directly into the hub assembly. No removal of the lock ring should be necessary. It may take a puller and some patience. As I understand from other posts, that ring is torqued on as part of the unserviceable hub assembly. If you remove it, you may prematurely trash your hub.
Griffy71
griffy71 is offline
post #15 of 17 (permalink) Old 02-06-2006, 03:41 PM
If it's part of the unserviceable hub unit then why would they sell the spindle bearing seperate ?
