2003 f250 7.3 transmission problems - Diesel Forum - TheDieselStop.com
Old 08-30-2012, 08:58 AM   #1 (permalink)
I got a 2003 f250 7.3 diesel pick up. I been having allot of transmission problems with it. Since i have had it been threw 4 transmissions 2 of them being under warranty and 2 in the last 2 years. Has a 6 inch lift with 37 inch tires it. Last two times brought it to the dealer ship n they put a new one in. first time told me to get a programmer n set the tire size and said that was the problem. I did that and just had to bring it to ford because the over drive light started flashing and had to get a new trany put in. they said the planetary gear was shot. so i just got a new trany under warranty but i need to figure this problem out. i dont know if it could be the drive shaft or rear or what. need help.
thanks
football74 is offline   Reply With Quote Quick reply to this message
Old 08-30-2012, 09:09 AM   #2 (permalink)
RT
RT's Avatar
First - get a transmission temperature gauge. The gauge on the dash is a glorified idiot light and won't let you know what is going on until too late. Second, get extra cooling. An upgrade to a 6.0 cooler is a good option. Third, clean your radiator fins. The oil to water cooler is in the bottom of the radiator and if the radiator gets gunked up, you'll cook transmissions. Fourth, get appropriate gearing for your tire size. Stock gears are 3.73 - that's good for stock tires. One of the gearing gurus that has all the tire size dimensions memorized can tell you which gears would be best but basically you need to know the difference in diameters between stock and your monsters and get a ratio the equivalent difference.
RT is offline   Reply With Quote Quick reply to this message
Old 08-30-2012, 09:20 AM   #3 (permalink)
thanks
Old 09-01-2012, 09:29 PM   #4 (permalink)
Wobblin-Goblin's Avatar
Re: the 6.0L oil cooler...is that a complicated job or something owners can do on their own?
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1994 Dodge 3500 SLT Dually 5.9L Cummins NV4500 5spd US Gear "splitter" Exhaust brake 4x4
RETIRED: 1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
NRA Life member
Wobblin-Goblin is offline   Reply With Quote Quick reply to this message
Old 09-01-2012, 09:50 PM   #5 (permalink)
RT
RT's Avatar
Its so easy a third grader can do it. Here's how: 6.0 Transmission Cooler Write up.pdf
Old 09-02-2012, 12:23 PM   #6 (permalink)
Rich D's Avatar
We'll having a 6.0L cooloer is a great addition, has burnt fluid be the cause of any the failures?? Are you towing alot or a bunch of weight ?
The dealer reprogrammed my truck for my upgraded 33" tires for like $60, I believe it was a 1/2 hours labor charge. I had it done to put the trans shifting back in the correct times.
Early 99 F250 XLT,White/Silver,4x4,SC,SB,A/T,PMT1,ARE LSII tonneau,Amp Research power steps,MB Razor's,295-60-20 Nitto Trail Grapplers,Rhino Liner,Rancho9000's,Bushwacker Street Flares,DP-Tuner F5,True-Cool Max,AFE modified-W.D.RamAir,5"Hypermax exhaust,Hypermax DP,Firestone Ride-Rites,2.5" front leveling leafs,AutoMeter-ProComps/triple pillar,heated TTT mirrors,DEI remote start,Amsoil enhanced.
Rich D is offline   Reply With Quote Quick reply to this message
Old 09-02-2012, 06:36 PM   #7 (permalink)
jmmybuckles's Avatar
Send a message via Yahoo to jmmybuckles
Where is a good place to buy the 6.0 cooler?
02 f250 7.3 psd, diablo, 4in. turbo back, airaid intake, 05-07 conversion - sold
02 x 5.4l bought wreck, did 05-07 conversion.- sold
99 F350 7.3psd, 4dr dually, 4x4, tymar intake, 4'turbo back, Dp tuner stock 40 t, 80 e, 120 race, 140 aggressive, 3 car Big Tex wedge.
jmmybuckles is offline   Reply With Quote Quick reply to this message
Old 09-02-2012, 07:10 PM   #8 (permalink)
RT
RT's Avatar
Tousley Ford - best prices around. You can get the part number in the how to posted above.
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
