2003 f250 trans temp gauge readings how hot - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 08-26-2010, 11:28 PM Thread Starter
I have a 2003 7.3auto 4r100 trans 4x4 f250. Does anyone know how hot it is when the factory trans temp gauge hits the yellow area? It got real close last weekend on my way to the Rubicon Trail. The trans is just rebuilt w/billet converter and deep aluminum pan. Still stock cooler though. Last summer the same section of hills got it in the red zone before i noticed it.
JOHNNYWEB is offline
post #2 of 17 (permalink) Old 08-27-2010, 05:00 AM
Mark Kovalsky's Avatar
My Photos: (6)
As was said in the other thread where you asked this question, it goes to yellow at 230°F.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 17 (permalink) Old 08-27-2010, 08:06 AM
woodnthings8's Avatar
Here is a reference for Stock Gauge temperatures. Obviously it shows yellow at 250 not 230, but I would go with what Mark says.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #4 of 17 (permalink) Old 08-27-2010, 08:41 AM
RT
RT's Avatar
Why don't you just bite the bullet and get the 6.0 cooler? It is an easy upgrade. Last week, I towed a 10,000 pound trailer 250 miles, including downtown Houston traffic, in 100° plus weather and my transmission temp never went over 170° F. (and, I will add - with Jody's tow tune - it was actually pretty fun )
RT is offline
post #5 of 17 (permalink) Old 08-27-2010, 09:00 AM
My Photos: (6)
That's possible. I'm going from memory from no later than 2004. Testing shows otherwise.
Mark
Former
post #6 of 17 (permalink) Old 08-27-2010, 09:08 AM Thread Starter
Ya I looked into the 6.0 cooler. It's a little pricey but if it keeps it cool it is money well spent. The diagrams showed where they gor a 2003 model? 230 is do able for a short period but 250 I will want to pull over. Is there different 6.0 coolers or they all the same through 07? I see you mention 26 & 31 row cooler mentioned?
post #7 of 17 (permalink) Old 08-27-2010, 09:23 AM
RT
RT's Avatar
Tousley Ford has good prices. There were apparently three sizes at one time, but only the two available now. Either will be a dramatic improvement over what you have now. It is a minimal investement for the return. If you take off the front bumper and grille, installation is a breeze. You do need to acquire two 3/8" to 1/2" barbed hose fittings and you'll need about a foot of 1/2" hose. I was able to get what I needed at Home Depot, although there are some simpler pre-fabs available on-line.
RT is offline
post #8 of 17 (permalink) Old 08-27-2010, 01:24 PM
As I wrote on another subject, I had the 26 tubes 6.0L cooler installed yesterday on my 99 PSD, but with 1 quart of the wrong tranny fluid to top off.
Afterward, I drove home 10 miles at low speed on a secondary winding road, not towing) and the tranny temperature gauge went up to 160 F. I think it is rather high, considering than when pulling my 15k lbs fiver with the 7.3L tranny cooler through the Adirondack Mountains the maximum temperature was about 178 F.
Note: don't ask me what the gauge read when I had the 7.3L and drove on the same road. But, is 160F too high or normal. No OTW cooler.
Petanqueur99
petanqueur99 is offline
post #9 of 17 (permalink) Old 08-27-2010, 02:27 PM
My Photos: (6)
Normal temps are about 170-180F.
There were two sizes of 6.0L coolers. The original was 31 rows, later ones were 26 rows. The 26 row cooler is a bit more efficient so you will get the same cooling from either.
Mark
Former
post #10 of 17 (permalink) Old 08-27-2010, 02:42 PM
With my 25 row cooler (yes 25) I normally see about 125-135 empty. When I tow 150-160 is normal. You can expect 65-80 degrees over ambient for your temps. When it is 100 degrees out you will see 160-180 degrees, especially with no OTW cooler. When you are driving below 45 mph (give or take) your torque converter is unlocked and dumping more hot fluid through the cooler, than when it is locked. So a low speed secondary road will cause the temps to be higher.
Edit: I see Mark typed a response while I was doing mine. I bought my 5C3Z-7A095-CB off of ebay BNIB for something like $80 shipped.
Here are the 6.0 cooler options
5C3Z-7A095-CA 26 row cooler
5C3Z-7A095-CB 25 Row Cooler (Part number 5C3Z7A095CB was superseded by part number 5C3Z7A095CA.) From TousleyFord.com.
5C3Z-7A095-B 31 row cooler
Ken
post #11 of 17 (permalink) Old 08-31-2010, 09:29 PM Thread Starter
Thanks for the info guys. Pulling the front end apart is a breeze ( I own a auto body collision repair shop) I am in need of a new a/c cond too as it if full of sand and crap for many desert wind storm miles. I am planning to do both at ones. Also I would ad I would not buy any hose from home depot? I will use hydraulic style high heat hose in my installation with double clamps on any barbs. Thanks again!
post #12 of 17 (permalink) Old 08-31-2010, 09:45 PM
Why not use transmission cooler line hose from your local auto parts store.
444-4D is offline
post #13 of 17 (permalink) Old 08-31-2010, 09:47 PM
RT
RT's Avatar
Yeah - I doubt anyone bought the hose at HomeDepot - I got mine at NAPA. I got the barbed hose fittings at Home Depot. I wouldn't worry about double clamping - you're not dealing with high pressure here.
RT is offline
post #14 of 17 (permalink) Old 09-09-2010, 06:10 PM
"As I wrote on another subject, I had the 26 tubes 6.0L cooler installed yesterday on my 99 PSD, but with 1 quart of the wrong tranny fluid to top off.
Afterward, I drove home 10 miles at low speed on a secondary winding road, not towing) and the tranny temperature gauge went up to 160 F. I think it is rather high, considering than when pulling my 15k lbs fiver with the 7.3L tranny cooler through the Adirondack Mountains the maximum temperature was about 178 F."
Well, I drove twice the same 10 miles on the same road yesterday and today, before and after replacing the ATF. After each trips, the tranny gauge read below 140F, rather then 160F!!!!
Do you think the sender or the gauge or both are bad?
1999 F350 Superduty Lariat PSD.
6.0L tranny cooler
2004 Jayco Legacy 3710 5 wheel
post #15 of 17 (permalink) Old 09-10-2010, 07:17 PM
I have to add that the reading of about 138F (below 140F) is with synyhetic ATF, while the previous readings of 160F were with standard ATF.
If I am not mistaken, I think I read that with synthetic ATF, the ATF temperature could be 30F less than with standard ATF, when towing, I would guess.
Do you think this could be true?
Petanqueur99
6.0L tranny cooler
