4r100 2nd Gear - Diesel Forum - TheDieselStop.com
 5Likes
  • 1 Post By Mark Kovalsky
  • 1 Post By blue99stroker
  • 1 Post By RT
post #1 of 10 (permalink) Old 04-29-2017, 05:43 PM Thread Starter
4r100 2nd Gear
I have a 2001 Ford F250 4x4.7.3 Stock. I am having a issue were it has a occasional slip in 2nd, not all the time but becoming more often, do I need to rebuild the transmission or is there something else i can check
2001 Ford F250 4x4 CrewCab 7.3 Automatic, 4 inch MBRP exhaust, Diablosport Predator, Edge evolution (monitor only), Cold Air intake,
Andrew Hubert is offline
post #2 of 10 (permalink) Old 04-29-2017, 08:59 PM
Mark Kovalsky's Avatar
My Photos: (6)
You need to rebuild it. The 2001 diesels had a new type one way clutch that was prone to failure. You have the symptoms.
Andrew Hubert likes this.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 10 (permalink) Old 04-29-2017, 10:48 PM
blue99stroker's Avatar
The dreaded mechanical diode.
Make sure the convert it to the other style.
Don't have them put in another new mech diode
blue99stroker is offline
post #4 of 10 (permalink) Old 04-30-2017, 01:33 AM Thread Starter
Can I pull the guts out of a 4r100 off a 5.4 and put them all in my 7.3 4r100???
post #5 of 10 (permalink) Old 04-30-2017, 07:49 PM
My Photos: (6)
You can't even get a new mechanical diode for this trans.
Yes, you can. It will all fit. It won't last long at all, though. The 5.4L parts are nowhere near strong enough to last behind a 7.3L.
Mark
Former
post #6 of 10 (permalink) Old 05-02-2017, 01:59 PM Thread Starter
Will the guts out a E40d work inside the 4r100????
post #7 of 10 (permalink) Old 05-02-2017, 02:14 PM
My Photos: (6)
Yes, they should. I've never heard of anyone doing this, usually it's putting the guts of a 4R100 into an E4OD, but I don't know of any reason it shouldn't work.
Mark
Former
post #8 of 10 (permalink) Old 05-02-2017, 02:15 PM
RT
RT's Avatar
Most of the internals are the same, but not all. There are some sensors on the 4R100 that aren't on the E4OD, so it would follow that the tone rings or whatever the sensor feeds off of wouldn't be there in the earlier transmission. PLUS, a lot of components in the E4OD were aluminum that were upgraded to steel in the later 4R100s. I wouldn't want to go backwards on reliability by putting in the weaker components.
RT is offline
post #9 of 10 (permalink) Old 05-02-2017, 02:17 PM Thread Starter
Thankyou guys for all of your help,
post #10 of 10 (permalink) Old 05-02-2017, 09:41 PM
My Photos: (6)
Oops! I forgot about that. E4OD internals will NOT work in a 4R100.
Yep, that's true, too.
Mark
Former
