4r100 transmission problem - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-24-2006, 08:58 PM Thread Starter
99 ford f-250 powerstroke with 7.3L diesel, 4r100 automatic transmission, has problem, shutters when it shifts into overdrive. Just had overhaul kit installed with new torque converter. Problem still exists
striper1 is offline
post #2 of 9 (permalink) Old 05-24-2006, 09:00 PM
Re: 4r100 transmission problem
You need all the help you can get
bjschutz is offline
post #3 of 9 (permalink) Old 05-24-2006, 09:03 PM
My Photos: (5)
who put the kit in and what did it consist of?
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
post #4 of 9 (permalink) Old 05-24-2006, 09:06 PM Thread Starter
standard overhaul kit purchased from ford, and a torque converter, put in by the ford place mechanic
striper1 is offline
post #5 of 9 (permalink) Old 05-24-2006, 09:12 PM
My Photos: (5)
prolly a generic build by a generic tech. I would take it back and make them fix it. Sorry for being to the point but if it left my dealership it would work flawless and then some. Might give us some info on the truck as to what mods it has as well.
1999.5 cc dually
post #6 of 9 (permalink) Old 05-24-2006, 09:22 PM
Kanman's Avatar
Why was the trans rebuilt? Have codes ever been pulled? Was the EEC ruled out as a problem?
Kanman is offline
post #7 of 9 (permalink) Old 05-25-2006, 02:21 PM Thread Starter
There are no modificatins to the truck or transmission. The transmission slips or shudders when it shifts into overdrive sometimes. Doesn't do it all the time. There were no codes when it was scanned. We ordered a overhaul kit from ford and installed it, new torque convertor and solenoid also. Still does the same thing as before.
striper1 is offline
post #8 of 9 (permalink) Old 05-25-2006, 05:36 PM
Did you replace the pump and check line pressures? I'll bet you arent getting enough pressure to the TC lockup.
Or maybe too much?
DD 2013 Ford Fusion Hybrid Titanium
Sold due to neglect
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline
post #9 of 9 (permalink) Old 05-25-2006, 06:53 PM
Mine has just started doing this exact thing when towing my 8k lb trailer with the Edge Evo tow program. I'll be watchiung this thread.....
Cheers,
Chris
2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
