Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-06-2008, 12:23 PM   #1 (permalink)
4x not working
Looking for suggestions.
My 4x doesn't work. I can flip the switch and nothing. Besides that I now notice that the switch is not lit (related?) and neither is the headlight switch.
I have checked the fuses and put dielectric grease in the plugs. Is there someway to check the switch and motor? What else could it be?
02 F-250, CC/SB, Lariat, 7.3L, 4x4, Auto, Compustart, AIS Air Intake, Edge Juice w/ Attitude, Leer Cab High Shell, 265/75/16 BFG ATs,
41 1/2ton (Wife's)
jpmueller is offline
Old 10-06-2008, 05:43 PM   #2 (permalink)
scrapin's Avatar
Maybe your hubs are shot....
1999.5 F350 Lariat 4x4 7.3 PSD tymar air intake, moog ball joints, rhino liner, 8 ft. min. mt. fisher plow ----- 3/04' 6.0 F350XL PSD 4x4 dually dump, moog ball joints, 9' min. mt.2 fisher plow----- 2001 F250 5.4 liter gasser 4x4
scrapin is offline
Old 10-06-2008, 07:44 PM   #3 (permalink)
alramsay's Avatar
If you haven't had the hubs apart I would guess it's the inner seals that are shot.
Bad seal=no vacuum=no 4X4.
Good luck.
2001 4X4 Excursion LTD 7.3PSD. Gets the job done and is still family friendly.
IAFF Local 1496
alramsay is offline
Old 10-06-2008, 09:21 PM   #4 (permalink)
My truck has a similar problem. I am assuming that the light on the dash does not light up when you turn the switch, regardless of the hubs. I have asked several people including taking mine to the ford garage. The only answer I get is "we have never had a truck do this before." and they just wanted to throw expensive parts at it. After pluging and unpluging every connection I could find I found that taking out the relays on the firewall directly in front of the driver would make it go into 4wd if the key was on regardless of the position of the 4wd switch.
To make a long story short if i disconnect my batteries for ten minutes then reconnect my 4wd will work for a month or two depending on how much I use it. The more I use it the longer it lasts. Just something to try. I do not know why this works, but it does and it is cheaper than replacing parts that obviously work even if for only a while.
If anyone has any other ideas I would like to hear them. It would be great to not have to remove the battery cables this often. But it does keep them clean.
Hope this helps.
99 F-250 lariat PS ext. cab short bed, 6 speed. 4" intake and exhaust, autometer gauges.
97 PS SD 5 speed
Phil Metz is offline
Old 11-13-2008, 03:24 PM   #5 (permalink)
Sorry it took so long to say thanks, but disconnecting my batteries for awhile worked. The people on this sight are great!
41 1/2ton (Wife's)
Old 11-13-2008, 03:39 PM   #6 (permalink)
Hope this helps.
I had same problem, It is called the GEM and you can just pull the fuse going to it and put it back in and it works fine. I think it was # 15 but not sure. They had a problem with that GEM and a recall on 99 models.
Charles Murphy
Bessemer City NC
1999 f-350 4x4
BTS transmission BTS Tune 6.0 cooler Issopro gauges
MBRP 4" 304 stainless exhaust K&N FIPK air intake.
reddgz is offline
