4X4 hub o-ring part # and repair procedures - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-12-2007, 01:36 AM Thread Starter
Well I tried the great search tool with no success. My hubs wont engage with the eos system. One of the hubs has an o-ring sticking out of the edge of the hub housing and the hub dial. I'm looking for the o-ring part # and a link for a write up on the proper repair procedures. Thanks for the help.
2000 F-250 LARIAT EXT CAB 4X4, AUTO, TYMAR, BTM, RANCH HAND BRUSH GUARD 125K
SOLD 94 f-250 x-cab long bed 4x4 zf-5. 200k.
gibby1 is offline
post #2 of 6 (permalink) Old 04-12-2007, 12:06 PM
Re: 4X4 hub o-ring part # and repair procedures
This ought to get you started, though it is just covering the lube of the esof system...lots of good info and part numbers:
http://guzzle.rbmicro.com/allube.html
1999 F-350 - CC/LB, gauges, 40K trans-cooler & external filtration & drain, 203 t-stat mod, Mag-Tech Trans & Diff. cover, AIS filtration, zoodad, HPO x-over, Jody Tipton 40HP tow PCM, Hutch mod and harpooned, Baldwin prepump fuel filter
"Better to be judged by 12, than carried by six!"
nlemerise is offline
post #3 of 6 (permalink) Old 04-12-2007, 01:33 PM
klhansen's Avatar
My Photos: (180)
Here's what I saved (contributed by TDS members)
Locking Hub O-ring (2) & retaining ring
4C3Z-1K106-AA
The exterior 0-ring is AS568A-152
Fractional size 3 1/4 x 3 7/16
Actual size 3.237 x 3.443
Width 3/32 (0.103)
McMaster-Carr 9452K173
The interior o-ring is AS568A-142 (the 143 size is ok also)
Fractional size 2 1/8 x 2 9/16
Actual size 2.362 x 2.568
Width 3/32 (0.103)
McMaster-Carr 9452K148
Bearings are INA #SCE248
I have manual hubs, and serviced them a while back, but wasn't able to get the knob out of the housing. I didn't try very hard, and didn't want to risk breaking them. The rest of the hub comes apart pretty easily, but I havent' messed with auto hubs. The link that 8V92TTA posted looks pretty good, also.
), AIS,
regulated return,
klhansen is offline
post #4 of 6 (permalink) Old 04-12-2007, 11:32 PM Thread Starter
Well this is great info but I still have some questions. The o-ring that is bad is the one between the hub housing and the manual turn knob. The o-ring is actually sticking out from between the housing and the knob. What I need to know is if I can remove the knob to service the o-ring. Again thanks for the help.
gibby1 is offline
post #5 of 6 (permalink) Old 04-13-2007, 02:20 AM
Kanman's Avatar
If the Oring is black and (guessing at size) 2 1/2" in diameter you are talking about the hub lock Oring. If the Oring is yellow and closer to 4" in diameter thats the hub Oring.
Sounds to me like your talking about the black Oring. On an F250 I think you can pull the hub lock out with out even removing the wheel. There is one snap ring you need to remove with a pair of needle nose pliers then the Hub Lock will pull straight out. That O ring wraps itself around the Hub Lock.
Try this link click me
Kanman is offline
post #6 of 6 (permalink) Old 04-15-2007, 05:06 PM
My Photos: (19)
I just did this, well, new hub assy actually, but it took a bit of pulling to get my hubs off. I ended up using my oil filter wrench (not the band type), it had a large enough opening to grab and I could pull. Just pull hard once that snap ring is off.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
