4x4 not switching on - Diesel Forum - TheDieselStop.com
Old 11-09-2009, 06:37 AM   #1 (permalink)
I turn on the switch for 4x4 high or low. Nothing happens. tried manually switching at the wheels, nothing. I checked fuses under steering column, changed 1 fuse. nothing. Could it be another one under the hood? For truck in sig. I don't have a owners manual so, I don't know what fuses control what components. Thanks in advance.
2000 F-350 7.3L SD CC SWT
4" S.S. pipe
177,000 miles
BTS trans, AFE Stg 2, Fass 150/180, Stage III's, tuning by power hungry.
00350 is offline
Old 11-09-2009, 07:07 AM   #2 (permalink)
I had the same problem with my 1999 F-350. I found a old post here on this site that helped alot. The problem is the GEM module had a problem with the software. The post said to pull fuse 15 and you take the power off that module and when you power it back by putting the fuse back it resets the module. You can replace that module but I am not sure what the cost is.Look
in the archives and you can find that old post. I just reset mine when quits and do not worry about it.I hope this helps you.
Charles Murphy
Bessemer City NC
1999 f-350 4x4
BTS transmission BTS Tune 6.0 cooler Issopro gauges
MBRP 4" 304 stainless exhaust K&N FIPK air intake.
reddgz is offline
Old 11-09-2009, 09:39 AM   #3 (permalink)
woodnthings8's Avatar
If you need a owners manual go to Motorcraft.com technical resources
Can you hear the transfer case motor shifting? You may have to crawl under the truck with it off and have someone cycle the switch.
Look at fuses 59 (30A), 27 (15A), & 34 (10A)
Also have you verified it is not engaging, or are you just relying on the light on the dash?
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is online now
Old 09-09-2011, 10:40 AM   #4 (permalink)
I have a 2000 f350 and the 4x4 light flashes as I'm going down the road. what could this be?? Also the same time this started the A/C started switching from Max A/C to defrost back and forth and will not cool the truck. How can I fix it????
nikkijax2003 is offline
Old 09-10-2011, 06:27 AM   #5 (permalink)
Sound like a vacuum pump problem.
2002 F250 7.3L PSD, bought new now at 195K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
