5th wheel/gooseneck tow rating - Diesel Forum - TheDieselStop.com
Old 03-10-2007, 10:42 AM   #1 (permalink)
lari2001's Avatar
What is the allowable rated trailer weight for an F350 (01)? I know the towbar rating is 10,000 lbs but I've constantly exceeded that with pretty much every truck I've ever owned.
2008 lariat F350 4X4 6.4, 8' bed, 20" wheels, everything except Nav....job 3
2008 GMC 3500 D-Max crew cab 8' bed 4X4 (work truck, not by choice)
2001 F350 lariat crew cab 4x4 srw sb 7.3...traded in for 08
2004 F350 lariat crew cab 4x4 drw lb 6.0...make believe diesel mechanic toasted it
1997 F350 xlt crew cab 4x4 off rd srw lb 7.3 sold
1978 custom Bronco lifted 460 bb bored .030
lari2001 is offline   Reply With Quote
Old 03-10-2007, 08:35 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Re: 5th wheel/gooseneck tow rating
Weigh the truck after you fill it with diesel, including driver, passenger(s), toolbox full of tools and extra fluids, cooler full of cool, and whatever is normally in the pickup when on the road. Subtract that weight from 20,000 pounds GCWR and that is the max gross weight of any trailer you can tow without exceeding the GCWR of the tow vehicle.
But if you are talking about a bumper-pull trailer, the receiver hitch is often the limiter. The receiver has a weight-carrying (WC) and a weight-distributed (WD) rating stamped on the receiver. For an '01 it was probably 500/5,000 WC and 1,000/10,000 WD. (The first number is the max hitch weight and the second number is the max gross weight of the trailer.
If your F-350 has single rear wheels (SRW), then your limiter for a gooseneck or 5er trailer is probably GVWR. Your GVWR is 9,700 or 9,900. Subtract the weight of the wet and loaded tow vehicle (including installed hitch) from the GVWR, and that will tell you the max hitch weight you can tow without exceeding the GVWR of the tow vehicle.
If your F-350 has dual rear wheels (DRW), then you don't need to worry about exceding the GVWR, so just watch the GCWR for a 5er or goose, or the receiver rating for a tag trailer.
The Ford tow rating for a conventional (tag or bumper-pull) trailer is limited by the Ford receiver. You can get rid of that limit by replacing the factory receiver with a Reese TowBeast Class 5 hitch that is rated for a lot more weight. So then the GCWR or maybe the GVWR becomes the limiter for a tag trailer
SmokeyWren is offline   Reply With Quote
