6-speed manual vs. auto transmission - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-27-2006, 12:40 PM Thread Starter
Hello Board:
I just purchased a 2000 F250 PSD with the 6-speed manual transmission. I've done some snooping around but couldn't find any direct comparisons between the two. Seems like most trucks around here are automatics.
I've found that they 6-speeds have ~25 more horsepower/torque but that's about it. With my experience from previous manual vehicles I was just assuming it's slightly more reliable (less parts), lighter weight (less parts again), and gets slightly better fuel mileage.
Am I correct in my assumptions?
Thanks!
gtmotor is offline
post #2 of 6 (permalink) Old 09-27-2006, 12:47 PM
Re: 6-speed manual vs. auto transmission
As far as more durable, no doubt. Fuel mileage depends on how you drive it.
2001 F350 CC LB 4x4. GDS Ballbuster turbo, AFE Stage II intake, Banks Intercooler, Suncoast TC, MBRP stainless 4", DI 4 position chip(needs reburn), Autometer gauges, zoodad mod, HX oil line, blow-off valve, DR 4.5" lift, 35" bfg mud terrains.(R.I.P)
332hp and 785tq - 4/1/2006 at Performance Diesel (w/o Banks ic and AFE stage II intake)
2007 Dodge 2500 CC SB 4x4 5.9L picked up (5/01/07)
5" stainless magnaflow, cfm+, quad boost fooler, smarty SR, Silver 62, DTT Billet 48re, AD 165, Spearco CAC, KORE race suspension, 35" terra graps on 18" XD HOSS.
tx_silverstroke is offline
post #3 of 6 (permalink) Old 09-27-2006, 12:51 PM
klhansen's Avatar
My Photos: (180)
slightly more reliable (less parts) <font color="red"> Possibly, but they do fail. Pilot bearing has reportedly taken out the input shaft gears, and mine died when the OTW cooler failed an mixed coolant with the ATF. But I've heard of a lot more stock auto tranny's failing. </font>
lighter weight (less parts again) <font color="red"> Not necessarily. The ZF-6 is a BEAST, you sure won't be able to bench press it. </font>
and gets slightly better fuel mileage. <font color="red"> Maybe. I think that depends more on your driving style. It would be interesting to see a side-by-side comparison of otherwise identical trucks. </font>
I just like to DIY when it comes to shifting. You are right that there are LOTS more auto than "standard" trannys. More people either don't want to drive a stick, (or can't [img]/ubbthreads/images/graemlins/shrug.gif[/img]), and so auto's are what the manufacturer's build. I had to look pretty hard to find mine.
Welcome to TheDieselStop [img]/ubbthreads/images/graemlins/smile.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #4 of 6 (permalink) Old 09-27-2006, 05:49 PM
yup.
4 main complaints with 6 speeds.
the clutch puck will randomly toss its springs, meaning you can't get cltuch to disengage. When it goes, switch to southbend or Luk.
pilot bearings get chowed. when you replace the clutch, put a plastic pilot bushing in.
clutch pedal is hard to hold in. luk and southbend fix this.
clutch is a PITA in traffic. Nice on the road, great towing, but suck around town.
99.5 Superduty Crew 4x4 6 speed Smokewagon
Pizza cutter tires, Tymar, BTM, DP
If it don't run, chrome it.
drmiller100 is offline
post #5 of 6 (permalink) Old 09-28-2006, 11:43 AM
I thought about getting a hand shaker when shopping for a PSD.
I wound up with an auto. The only auto I own.
I love having just 2 pedals! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
LatahF250PSD is offline
post #6 of 6 (permalink) Old 09-28-2006, 07:49 PM
If MPG is important, the 6 speed rules. All else being equal, the 6 speed will get an additional 2 MPG over the automatic.
'00 F-350, 4x2, 6 Speed AIC 210,000 miles
3.08:1 Gears
Fuel tank mods: MaroonHarpoon, Pre-Pump,
Evans, 203 degree thermostat, Poor Man's Tymar, 4" Single SS Exhaust, Rugged Air Dam
225-75x16E tires in front 235-85x16Es in back, tires aired up to 100 psi, Lowered 4" in front and 6" in back, "Fastback" bed fairing
21.3 MPG before mods
27.0 MPG tested with mods
Dave Whitmer is offline
