7.3 Block coolant drain plugs - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-23-2007, 06:05 PM Thread Starter
I have some pictures of these but wanted to hear it from the members who know the locations. One pic shows one above the starter, accessed from below. Where exactly is the other one and best way to get to it? Thanks.
Truck #1 - 2001 F-350 Red Crew Cab Long Bed SRW Auto 3.73 gear, Walker BTM, Ford AIS. Cat ELC coolant, Pulling 30+ft Tag Hitch Fleetwood Terry Toy Hauler (very heavy), New Holland Skid Steer and Massey Fergason 231. Gauges,and DP tuner soon! Truck #2 Bought new - 1986 F250 4X4 460 V-8, C-6 auto (no overdrive!) 3:73 gears. THE LAST regular fuel vehicle from Ford. Bringing this one back to life .... as gas prices soar!
oakhillbill is offline
post #2 of 4 (permalink) Old 11-23-2007, 10:20 PM
SmokeyWren's Avatar
My Photos: (45)
Re: 7.3 Block coolant drain plugs
Surf to
http://www.dieselsite.com/index.asp?...PROD&ProdID=42
then scroll down until you see photos of both of those block drain plugs. Yeah, they're louzy photos, so maybe not worth all 1,000 words. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
SmokeyWren is offline
post #3 of 4 (permalink) Old 11-24-2007, 09:51 AM
My Photos: (5)
If you look under the 7.3 faq section, Gooch has a thread about proper coolant flush. If you scroll to the bottom, there are great pics of everything you need inlcuding the block plugs. I did this two weekends ago and it was easy.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 105,000 miles.
clydesdale is offline
post #4 of 4 (permalink) Old 11-24-2007, 05:06 PM Thread Starter
One thing I found that did help on putting the passenger side block drain in so many times was to stick a 1/4 to 3/8 drive adapter on that side as you can't see it and it's kinda hard to put that plug back in. This allows you to have something to hold on to spin it in. 3 flushes and Cat ELC and coolant filter installed today with distilled water, took about 3-4 hrs of non rushed work. Thanks to all for the info I get here.
