7.3 diesel trouble codes - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-24-2011, 01:27 AM Thread Starter
I decided to get the autoenginuity scan tool to check out my truck. The truck has been running well but seems a little underpowered when towing about 18000 fully loaded. Also seems to have some electrical issues like the door ajar sensor is always on even though I replaced all the door ajar sensors and it did not fix the problem. The radio only turns off after you leave the vehicle closed up for 5-10 minutes. Also the headlights don't buzz to let you know they are still on when you leave the vehicle. The dome light sometimes turns on when you get in and other times nothing until the key is turned. I am not able to program a new remote to unlock the doors.
Do I need A NEW vsm?
Truck is 2002 7.3l diesel dually 4.10 gears, 202k miles with ts performance 6 pos chip, afe stage 2, 4" turbo back exhaust. all problems listed above were present before adding mods. After the mods I have good power but high egt's. I just replaced the up pipes and it seems much better but I have not tried it fully loaded. Only ran with the camper in the back so about grossing about 12k lbs. fully loaded I tow a trailer also to get to 18000k.
Trouble codes found:
KOEO test found:
P0605 internal control module read only memory error
Buzz test
all cylinders sounded good
Diagnostic trouble Codes:
P1804 4 wheel drive high indicator circuit failure
P1828 transfer case counterclockwise shift relay circuit failure
P1139 water in fuel indicator circuit
B1352 ingnition key in circuit failure
U1950 ubp communications fault error
B2658 wait to start warning indicator circuit open
U1262 scp (j1850) communications bus fault
P1119 manifold air temp circuit high
P0381 glow plug/heater indicator circuit
P0603 internal control module keep alive memory (KAM) error
1999 F-250 extended cab, Boost, pyro, tranny, and diff gauge in 4 gauge pod, 4" exhaust w/3.5" downpipe and 5" tip, TC lock out mod, 2Lo mod, AFE stage 2, onboard CO2, Cobra CB, Rear diff cover, TS Performance 6 position chip
timo992001 is offline
post #2 of 6 (permalink) Old 03-24-2011, 09:14 AM
woodnthings8's Avatar
Sounds like a VSM issue.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 6 (permalink) Old 03-24-2011, 01:34 PM
Ok what is it?
I looked at the acronym link in your signature and VSM is not listed. What is a VSM?
Gary
2002 F250 XLT, Super Cab, Short Bed 4X4
Build Date: 10/1/2001
7.3 PSD, 6 Speed Manual Transmission
AIS Severe Duty Intake
20.1 MPG Average
Pine Junction, Colorado
rv6a is offline
post #4 of 6 (permalink) Old 03-24-2011, 04:49 PM
Vehicle Security Module
Ken
post #5 of 6 (permalink) Old 03-24-2011, 09:52 PM Thread Starter
is there a way to narrow down if it is pcm or vsm?
post #6 of 6 (permalink) Old 03-24-2011, 10:19 PM
It is not the PCM, the VSM controls all the stuff you mention problems with. Last I checked they ran around $100, but require the dealer to program it.
Ken
