7.3 engine timing - Diesel Forum - TheDieselStop.com
post #1 of 23 (permalink) Old 04-18-2005, 04:59 PM Thread Starter
kip
7.3 engine timing
I was reading a post on another board and they were talking about engine timing and by changing it from 9 degrees BTDC to 6 degrees BTDC he increased his milage. If this is possiable how do you check the timing ? What tools are needed ?
2011 F350 CREWCAB LB 4X4 6.7 DIESEL AUTO 3.55 AXLES
kip is offline
post #2 of 23 (permalink) Old 04-18-2005, 05:03 PM
My Photos: (11)
Re: 7.3 engine timing
All timing on these engines 94 and up are controled by software in the PCM based on various sensor readings is the main key input IMO is from the CPS. You can electronically fool some sensors such as the ICP and EOT to effect timing as you refer to it, but it's not like you're thinking of the timing on gassers.
Larry, keeper of the <font color="red"> New revised </font><font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font>
, BTS w/Schaeffer's ATF
, ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10 Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets"
, & a 1981 26' Prowler TT(26Y)
Larry M is offline
post #3 of 23 (permalink) Old 04-18-2005, 05:45 PM
As larry stated, cannot change timing on a DI. Maybe they were talking about changing timing on an old IDI?
djshum is offline
post #4 of 23 (permalink) Old 04-18-2005, 06:35 PM
You can to change timing on a DI diesel.
If you put a resistor across the engine oil temp sensor and make the computer think the engine is cold, it advanes the timing.
Cant really mess with the CPS signal without making a chip/tuner, but changes to timing are done to counter the effects of propane (which effectively advances the timing, leading to precombustion and blown rods).
The timing changes are really changing when the injectors fire. Too soon and you can send the rods thru the engine block. Too late and you lose power.
Ford_Forgotton is offline
post #5 of 23 (permalink) Old 04-18-2005, 07:52 PM
JimTJr's Avatar
My Photos: (20)
[/ QUOTE ] That is exactly the way I have always understood it. The fireing of the injector is just like the fireing of the spark plug...has to happen at a certain degree before TDC. Just like a gasser. And you can mess with it..but has to be a chip or programmer as stated above.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #6 of 23 (permalink) Old 04-18-2005, 08:11 PM
Understandable....but this is not the upgrade and aftermarket forum. You cannot change timing (using factory settings, ect) on a DI.
djshum is offline
post #7 of 23 (permalink) Old 04-18-2005, 09:18 PM
Oh come on, are you trying out for a moderator position on this site? Thats some screwed up post. The guy asked a simple question and we give him screwed up answers. Adjusting the timing is a perfectly acceptable quesion in the ENGINE forum. Once he was told that it requires an upgrade or aftermarket item, it could then get moved. But to tell him NO IT CANT BE DONE because he posted in the wrong forum is just boneheaded.
post #8 of 23 (permalink) Old 04-18-2005, 09:40 PM
Not boneheaded...just the facts. It cant be done without an aftermarket piece of hardware. This isn't the aftermarket forum. So I was stating that if he is looking in the service manual, he won't find the procedure because it isn't in there. No need to get huffy big shooter... [img]/ubbthreads/images/graemlins/smirk.gif[/img]
djshum is offline
post #9 of 23 (permalink) Old 04-19-2005, 04:20 AM
JimTJr's Avatar
My Photos: (20)
Well,, DJ that is the way I thought you came across to.. trying to be like a moderator..though nothing wrong with that if you are one. [img]/ubbthreads/images/graemlins/shrug.gif[/img] But even if you didnt intend your post to read that way,,it's the way it came across,,,, OK?
JimTJr is offline
post #10 of 23 (permalink) Old 05-13-2005, 06:16 AM
HOW COME EVERY TIME I GET ON A FORUM BE IT POWERSTROKES TO PAINTBALLS YOU ALWAYS HAVE PEOPLE ARGUEING OVER WHERE STUFF GOES? WHO THE HECK CARES!! WE ARE SUPPOSED TO BE HELPING EACH OTHER OUT WITH INFO AND IF IT SNEAKS IN THE WRONG TITLE I PROMISE YOUR ENGINE WONT EXPLODE. RELAX....
TRUCK-2000 F250,cc,sb,4x4,3"lift, 33"tires
MODS-Gauges,Ts 6 Pos,Afe2,HTT turbo, 5" Summit exhaust, Turbo master waste gate,Zoodad, Ccv mod to downpipe, Bypass filter, Amsoil throughout, overboost reg, Aih plug, Gutted ebpv/non-ebpv pedestal, Monster box, xternal trans filter, A/C mod. 300rwh with e-brake on (oops). 15.29 best 1/4 (Several mods ago).
THE4X4PIG is offline
post #11 of 23 (permalink) Old 05-13-2005, 09:01 AM
The question you ask is fraught with pitfalls.
On ANY of the HEUI engines, there are two very different values for "timing". The first is the electronic signal that TRIES to start the injection event. The computer tells the injector to fire, and then after some period of time, the fuel gets delivered to the chamber and then it actually DOES begin to burn. There is no hardware to communicate that event in real time (i.e. closed loop) to the PCM to let it know that it actually happened, so there can be some HUGE variation, and thus the one, big soft spot in HEUI technology. Add to that the split shot injectors from '99 on, that have even more mechanical assumptions to control injection.
Because of these things (we can only assume) the PSD is shipped with relatively late timing (to prevent some of the cackle and knock problems from getting out of hand). They usually benefit from increasing the lead of the injection signal.
You can change timing in a number of ways (all software related - even the EOT mod is just fooling the computer), but you could only know where it actually "fires" by measuring cylinder pressure vs. crank angle.
Hope that helps.
Pat
2000 F450 Lariat 4x4 tractor, rebuild at 200k in '12, Air Dog, Reg Mod, HX & HP all in hard SS lines, bypass filter, Banks Power Elbow w/3.5 dp, no intake heat, CCV mod, AIS (w/extra hole), some big Alliant single shots, GP indicator LED, custom 4" exhaust, 4" USG exhaust brake, custom alum. rear diff cover extension (dipstick & temp), Detroit locker, ESPAR D5 aux. heat, custom alum tow deck and fuel tanks, Bushwacker 1 1/2" flares, 9k winch, gin poles, JWSpeaker 8900 LED headlamps in XL grille, Lightforce 240GT (still Halogen, but VERY bright), Hella Micro DE HID fogs, KW = vision plus (Isspro) instruments, more to come & lots of other diesels
Pat Dolan is offline
post #12 of 23 (permalink) Old 05-13-2005, 09:33 PM
What size resistor ?? Can you use a potentiometer to vary the resistance and change the timing similar to the Distributor cap on an old gasser? If so, How can you tell when the timing might be getting too far advanced and potentially doing the "rod through the oil pan" trick as previously stated.... When you hear the load bang, and the metal strapnal hits your feet and ankles??
Bimbo is offline
post #13 of 23 (permalink) Old 05-13-2005, 10:33 PM
Does not change timing just richens up the fuel.
As a certified Ford Diesel Senior Master,I can tell you with all certainty....you cannot change the timing
Real trucks rattle!!
Ford Diesel Master Tech
dzltech is offline
post #14 of 23 (permalink) Old 05-13-2005, 11:03 PM
Well, I dont know how to put this politely, so I'll just post it as I found it:
EOT Engine Oil Temperature Sensor:
Strategy input; PCM uses this for determining glow plug on time, EPR actuation, idle speed, fuel delivery and injection timing and adjusts as temperature increases; 5.0 volts in, 4.37 volts@32F, 1.37 volts @ 176F, .96 volts @ 205F.
As you can see, even the FORD manual says CHANGES INJECTION TIMING.
Injection timing is the only timing we can change without pulling the motor apart.
The OTHER timing we could mess with (but dont) would be camshaft timing to adjust valves opening and closing. Like "degreeing" a cam on a gas burner.
I havnt seen a very large market for custom PSD cams, so cam/valve timing must be fairly good from the factory.
Also take a look at THIS OLD THREAD . Its from someone who played around with the EOT and his results.
Careful waiving those Certifications around, doesnt look like they are worth much.
post #15 of 23 (permalink) Old 05-21-2005, 10:36 PM
fourhatz's Avatar
I am posting this a little late but you can change the timing on these engines by installing a DT cam sensor. They have a smaller tip and will see the timing disk 2 degrees later than the Powerstroke sensor. At work when we get a bad running DT in cold weather we often install a Powerstroke Cam sensor to advance the timing and it will run better in the cold weather.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
fourhatz is offline
