7.3 Liter Coolant Capacity - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 07-13-2007, 02:59 PM Thread Starter
Anybody know the total cooling capacity (including radiator, hoses, etc) of a 2002 7.3?
2002 F350 XLT Supercab 8' Bed, Single Rear Wheel, 6 Speed Trans, Firestone Ride Rites, Superhitch, Tork Lift Camper Tie-Downs, Custom Built Aluminum Headache Rack, Pro-Tech Tool Box, 295/70R17 Toyos on Allieds, Bilsteins, Tuff Country 3.5" Kit, Gauges, Banks PowerPack, AFE intake w/ ProGuard 7
Wiley75 is offline
post #2 of 5 (permalink) Old 07-13-2007, 02:59 PM
haul_n_horses2's Avatar
My Photos: (17)
Re: 7.3 Liter Coolant Capacity
8 gallons
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #3 of 5 (permalink) Old 07-13-2007, 03:54 PM
JimTJr's Avatar
My Photos: (20)
8 gallons
If your doing a flush, make sure you do NOT "Pre mix" it, pour in 4 gallons of straight AF, then top off with the distilled. (That way all the distilled left in the block, will make up the rest of your 50% mix.)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #4 of 5 (permalink) Old 07-13-2007, 07:30 PM
JeepPuller's Avatar
My owners manual says 32.75 quarts. I am going to change coolant soon and plan on putting in 4.5 gallons of concentrate and topping off with distilled water as prefer slightly more then 50/50 mix.
I suppose the aftermarket coolant filter assembly has a small amount of capacity too.
2002 F350 Lariat,4x4,CC,SRW,LB,PSD/Auto, Isspro guages and TTM, Garrett BB Turbo, Turbo Master W/G controller, BTS transmission, Banks Monster exhaust, Banks Brake, Tymar, AIC, X springs, Bilsteins, coolant filter, 6.0 cooler, ordered new, 73,000 miles
JeepPuller is offline
post #5 of 5 (permalink) Old 07-14-2007, 12:17 PM
BroncoGlenn's Avatar
The capacity is 8.2 gallons, with 4.1 gallons of concentrate giving a 50/50 mixture and 4.9 gallons giving a 60/40 mix. I went with 4.5 gallons of concentrate as it was easier to measure out and left me with enough to make a gallon of 50/50 mix.
Glenn
2002 F-350/XLT/PSD/SRW/CC/LB/4x4OR/Auto 210k miles
Ford AIS, Edge Insight CTS2, ceramic coated International bellowed up-pipes, RiffRaff billet wheel, EBPV delete pedestal/outlet, RiffRaff boot set, Turbo Master mechanical waste gate actuator.
BroncoGlenn is offline
