7.3 No Fuel To Injectors - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 12-13-2009, 05:54 PM Thread Starter
I have fuel up to my fuel bowl, but no fuel getting into the motor because it is not smoking at all. The wires on my valve gasket have power to the glow plugs but that's it. The PCM has power I'm wonder if there is a fuse for the injectors. I am also getting good oil pressure. I do not have my owners manual so I have no idea if there is a fuse for the injectors. Help would be greatly appreciated.
01stroker73 is offline
post #2 of 9 (permalink) Old 12-13-2009, 06:09 PM
Excavator's Avatar
My Photos: (11)
the injectors will not get power for several reasons.
Most common is battery cranking voltage below 10.5
You should check fuse 30 MAXI as your fuel heater could have shorted which is common and that controls PCM
read here Blowing #30 fuse.
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #3 of 9 (permalink) Old 12-13-2009, 06:12 PM Thread Starter
Another ? if the injectors don't get power will they not fire and this #30 is under the hood but i don't have a number 30 mine goes up to 29?
Thanks for the quick response.
post #4 of 9 (permalink) Old 12-13-2009, 06:15 PM
Excavator's Avatar
My Photos: (11)
check my last post for link, it is under dash
no power means not working injector
Swamps,Tony Wildman
post #5 of 9 (permalink) Old 12-13-2009, 06:40 PM Thread Starter
Ok number 30 is good still no power up top. now there is no wts light.
post #6 of 9 (permalink) Old 12-13-2009, 06:45 PM
Excavator's Avatar
My Photos: (11)
i would check the number 30 with multi tester or replace it
Swamps,Tony Wildman
post #7 of 9 (permalink) Old 12-13-2009, 06:49 PM
Excavator's Avatar
My Photos: (11)
look at this other thread with same problem
http://www.thedieselstop.com/forums/...heater-242739/
Swamps,Tony Wildman
post #8 of 9 (permalink) Old 12-13-2009, 07:52 PM Thread Starter
What does fuse # 24 maxi do? It is blown.
post #9 of 9 (permalink) Old 12-13-2009, 09:16 PM Thread Starter
OK I have tested all fuses and replaced the one bad one #24 still no fuel wts light is on again over 10.5 volts when turning over still no start. Any more ideas?
