7.3 no oil pressure - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-05-2011, 04:49 PM Thread Starter
7.3 no oil pressure
i have a 99 f450 i put a motor in from wrecked truck i bought it has no oil pressure at idle can rev up a little and it has oil pressure but instantly drops when i let of it also i very hard to start
zackery5446 is offline
post #2 of 5 (permalink) Old 11-05-2011, 06:15 PM
I'm not an expert here so i could be way off. Bad pump maybe? How high do you have to rev it to get it to normal oil pressure? Not exactly sure what the signs of a bad pump on these are but I've had a couple on old diesel tractors that acted that way when they started going out....
Redneckjake is offline
post #3 of 5 (permalink) Old 11-05-2011, 08:18 PM
RT
RT's Avatar
How and where are you measuring oil pressure? Like redneckjake said, the pump is one possibility. Others would be the bypass spring, excessive bearing clearances, or a bad pickup.
RT is offline
post #4 of 5 (permalink) Old 11-06-2011, 09:13 AM Thread Starter
i removed sending unit from top of front cover and installed pressure gauge there. i seen truck engine was pulled from it had to be running when wrecked engine doesnt have blow by or any misses it busted the oil cooler and i swapped it over from my old one i also swapped out oil pump on crankshaft. to get it to start i have to fill housing full of oil where hp oil pump mounts. otherwise it just cranks over.
post #5 of 5 (permalink) Old 11-06-2011, 08:21 PM
woodnthings8's Avatar
Pull the LPOP out and inspect it for wear. Use this HPOP Manual an look at page 5 for LPOP inspections. Also look at the cover for wear as it effects the pressure too.
Replace it with a Melling LPOP
Like mentioned before, if you have clearances that are larger than designed, the oil pressure will not build. A rocker that is off or broken can cause low oil pressure at idle.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
