7.3 Oil leak - Diesel Forum - TheDieselStop.com
Old 02-28-2007, 12:41 PM   #1 (permalink)
7.3 Oil leak
This is my first post here. I found this forum while looking for information on oil leaks on my 2002 F350 7.3L Power stroke. I have been working out of town for several weeks now and last night my wife called me and told me oil was pouring out of the engine. I had her open the hood and she said the oil was come from the top of the engine and that the valley between the heads was filled with oil. She could not see where the oil was coming from. Any ideas? Could this be an oil line to the Turbo or maybe a broken Turbo? Any help would be great. Thanks
2002 F350 LB 4x4, 4" lift, Bushwacker cutouts, 37x 13.5 DC fun country, 6 gun tuner, 4" exhaust, MEM cold air intake.
bushwacker4x4 is offline
Old 02-28-2007, 01:21 PM   #2 (permalink)
Re: 7.3 Oil leak
i had oil in the valley, i took it to dealer under warrinty, it was the turbo pedestal 0 rings. i just had a little puddle in the valley, hope this helps you.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
Old 02-28-2007, 01:29 PM   #3 (permalink)
JimTJr's Avatar
My Photos: (20)
Re: 7.3 Oil leak
Definately sounds like HPOP leak, Turbo wouldnt leak THAT bad I doubt. And seldom fills the whole valley, HPOP is in front, so it does.
Sounds like a HPOP Line, or plug leaking. Not a hard fix, but hard enough if your out of town!
WELCOME TO TDS,, and not to sound chauvanistic, but KUDOS to the wife, for knowing to look up there, and how to explain it!
On edit I was posting at the same time as the above poster, NOT intending to sound like I was dissin his Diagnosis,, about turbo. Just that to me it sounded more like HPOP at first guess,, Had not even read the other reply yet then!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 02-28-2007, 02:52 PM   #4 (permalink)
Re: 7.3 Oil leak
Thanks I will check that. I was kinda hoping it was the Turbo so I could justify to my wife the cost of a Bad Boy Turbo! LOL [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 02-28-2007, 07:12 PM   #5 (permalink)
Re: 7.3 Oil leak
sure its not diesel fuel!
squeek417 is offline
Old 02-28-2007, 07:24 PM   #6 (permalink)
Re: 7.3 Oil leak
Yeah had the same thing, dealer said it was a non-servicable leak on the hpop. They replaced the whole oil pump. Then 3 weeks later had oil leaking again, got it back yesterday they said that I had a line that was loose...guess we'll see! Hope you get it fixed up!
2002 F-350 CC SB
Equipped w/ triple DiProcol Trans/EGT/Boost
DP 4-pos, BTS Valvebody
Straight Pipe w/5" Custom Stainless Tip
2" Leveling Kit, 315/75-16 BFG-AT's
Limo Tint, Vent Visors, GPS w/ Custom Mount, XM-Satellite Radio,
Tran4mer Push bar complete w/ winch
plate and MileMarker 12K lb. electric winch
Tymar Intake, CB w/ dual antennas
doemaster is offline
Old 02-28-2007, 07:45 PM   #7 (permalink)
olddieseldude's Avatar
My Photos: (16)
Re: 7.3 Oil leak
Welcome to the site and enjoy your new-to-you diesel. This is my first also and I love it! You might want to extend your oil change intervals to 5K miles, it's 15qts oil and an expensive filter every time, and IMHO is well within reason for the engine.
Here's my thread when my High Pres Oil Pump plug was leaking...
A few other leak posts...
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline
Old 02-28-2007, 08:48 PM   #8 (permalink)
Re: 7.3 Oil leak
Yep she says it is black and my buddy who is a race car guy came over and looked at and also said it was engine oil.
Old 02-28-2007, 09:47 PM   #9 (permalink)
Re: 7.3 Oil leak
[img]/ubbthreads/images/graemlins/tongue.gif[/img] pump coupler o-ring blown out for sure. they are the one thing that will most likely run alot of oil out the back, replaced many. theres a kit w/ 3 o-rings in it w/ also some sealer thread compound. one other place is the upper couplers on the heads. there all easily seen when leaking. if it had been diesel you would have smelled it. diesel can be black also if theres alot of grease in the upper valley. you can take it to a car wash & apply some of that eng. degreaser then let it set for about 5 minutes then use the wand on it, but stay about 2 ft from the sensors then turn the trigger off & stick it down in the valley & wash it out. stay away from the glow plug controller though, cause the thing is hot all the time on the red lead post. i use a steam cleaner on all the ones that come in, in this kind of shape. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 02-28-2007, 09:48 PM   #10 (permalink)
calico5string's Avatar
My Photos: (14)
Re: 7.3 Oil leak
A very common place for oil leaks is at the plug at the back of the HPOP, or the HP lines to the heads. The fittings and plugs are sealed with an o-ring. The ring can leak quite a bit of oil when they go bad. Usually the oil runs down the valley and out through a drain hole at the top of the bellhousing flange. It might appear to be a main-seal leak (from underneath the truck), as the oil comes out from between the trans and engine.
I've done a bunch of them...It's not a hard fix, the parts are fairly cheap. If your at all mechanically inclined, you should be able to DIY.
HERE's a link to a Navistar HPOP manual, so you get an idea about what you're dealing with.
Good luck!
On Edit: Just noticed your new (6 posts), so WELCOME!
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline
Old 03-01-2007, 01:22 AM   #11 (permalink)
Re: 7.3 Oil leak
Thanks that does not sound so bad. I only get to come home for 1 1/2 days so I hope I can get the parts on Saturday.
Old 03-01-2007, 01:29 AM   #12 (permalink)
Re: 7.3 Oil leak
Thanks. I am I can fix just about everything. I just do not have allot of experience with Diesels. I build custom Rock crawler stuff on the side, Axels, transfer cases and rock slider stuff so fixing it will not be a problem. It had me a bit spooked when my wife calls and says my truck just dumped a bunch of oil on the ground!
Old 03-01-2007, 02:27 AM   #13 (permalink)
Re: 7.3 Oil leak
Welcome to the site, you will find the site a wealth of knowleadge when it comes time to try to figure out DIY fixes on your truck.
Owning three this site has saved me tons of money!!!
Now I may know why the F350 is leaking.
Been changing oil on the F250 from 40K miles to 236K miles every 7-10K miles with conventional diesel oil. Motor sound better than the other two with way less miles. May switch to synthetic oil in the F250 and change it every 20K like the Excursion.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod
00 BMW 328CI 2dr silver fully loaded
65 Mustang 289 V8 4brl
69 GTO 400 4spd
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 03-04-2007, 11:31 AM   #14 (permalink)
Re: 7.3 Oil leak
Well I replaced those 3 O-rings and it still leaks. Looks like it is coming from under the HPOP. It only leaks when the Truck is running so I think it is most likly coming from the pressure requlator. There is another o-ring for that but the HPOP has to be pulled to replace it. It there anything I need to becarfull of when I pull it? Thanks.
Old 03-07-2007, 09:36 PM   #15 (permalink)
Re: 7.3 Oil leak
Let us know what you find. Mine is leaving a puddle every time I park it.
2001 F250 Lariat, -SOLD-
460/950 Corrected Prior To Water Injection and Spearco IC.
13.974 @ 95.65mph
2008 Cummins Truck Fest 4WD Diesel Champion
'07 Duramax Classic, Leather, Sunroof, Bone Stock.
DZacc is offline
