7.3 power stroke stalls when cold - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 10-01-2007, 06:43 PM Thread Starter
I have a 2000 f350 that is now stalling when cold. Changed the fuel filter and air filter (it was over due). Also found the Glow Plug Relay was cracked so replaced that.
Symptom is when below operating temp on dash it will stall after driving a block or two then not be able to idle. after a few tries to get it started again, you have to hold the pedal down some till it calms down. withing 10 minutes it returns to normal operation but can stall again until it completely warmed up.
Any thoughts?
SpongeBobSP is offline
post #2 of 6 (permalink) Old 10-01-2007, 06:56 PM
Re: 7.3 power stroke stalls when cold
mine has been stallinn too lately, on cold start ups, it starts right up in morn. after say 1 mile or so it craps out, or gives a hick up. it starts right up after and drives normal. iam thinkinn its the cps on mine, its the original one in there, 73,000 miles.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
rws444psd is offline
post #3 of 6 (permalink) Old 10-01-2007, 09:41 PM
Have you checked the oil?....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #4 of 6 (permalink) Old 10-02-2007, 05:45 PM Thread Starter
I hope it is and istn this simple......
Oil was low, so far so good.
post #5 of 6 (permalink) Old 10-02-2007, 06:29 PM
how much low?
post #6 of 6 (permalink) Old 10-02-2007, 07:06 PM Thread Starter
3/4 of a gallon container, it was on a sloap so less than that, just to play it safe I put in enough to cover the stick on non level ground
