7.3 quits - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 02-01-2013, 07:42 PM Thread Starter
7.3 quits
7.3 D. 2000, 153,000 miles.
Pulling onto interstate after about 3 miles of surface roads and at about 55 mph.... the motor quit. No peddle position helped. Put in neutral, turned switch off and back on and cranked right up... no more issues.
Put in new fuel filter and cleaned (AirRaid) the air filter. Engine seemed happier.
Today, about 1 mile from house, the motor went to about 500 RPM- didnít quit like before. Would not take fuel. Pulled off, put in neutral and then the it would take throttle. No more issues for rest of day.
Only common denominator- <45 degree temperature both times.
Suggestions?
DRMAJOR is offline
post #2 of 15 (permalink) Old 02-01-2013, 07:45 PM
badbart's Avatar
I'm guessing the CPS(crankshaft position sensor). Get a new one and put it on. There may be a recall for it if it's never been replaced before. Call your local Ford dealer and give them your VIN.
2016 Dodge Ram 3500 Mega Cab Dually
1997 F350 XLT Crew Cab Dually
badbart is offline
post #3 of 15 (permalink) Old 02-01-2013, 07:49 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Re: 7.3 quits
If its registering rpms, its not the CPS. That us usually when it cuts completely out then comes back in a second like nothing happened. This is a new one on me but my first guess would be the TPS.
Sent from my DROID RAZR using AutoGuide App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #4 of 15 (permalink) Old 08-05-2013, 09:32 AM Thread Starter
Happening again.... at first thought this was a winter issue, i.e., sub- 50 degree. But it was 90 the other day and it dropped to low idle.
put in neutral, turned key off and restarted and it has been fine since.
Totally seems random.
DRMAJOR is offline
post #5 of 15 (permalink) Old 08-07-2013, 11:08 AM
tattoocharlie's Avatar
My Photos: (5)
this sounds stupid but check your oil level,if its really low you can intermittent running issues. I know a guy it happened to
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #6 of 15 (permalink) Old 08-07-2013, 06:37 PM
MWOOD's Avatar
Could be the 2 filters in the fuel sending unit inside the fuel tank are clogged. It happened on my 99 with 170xxx. Just a thought.
MWOOD is offline
post #7 of 15 (permalink) Old 08-07-2013, 10:20 PM
Like the previous post says....a fuel pressure check may be worth wile. If your running any kind of chip remove it....one of my chips are loaned out to a buddy that had the same problem with his old chip shutting his truck off at random times.
03 F250 4x4 Lariat 7.3 4 inch exaust Tymar PHP Phoenix chip WW2 banks big head 4 inch lift w/ 35's
Montgomery P-Stroke is offline
post #8 of 15 (permalink) Old 08-09-2013, 11:54 PM
Absolute's Avatar
my guess is you have a chip as well. Id say an edge chip. they are known for doing that. Mine did, edge replaced it with a newer model. Never done it since. Removing the chip will solve it. I did that until my new one came. Also could be the pedal itself. They pack it in too. The pedal is electronic, no cable, and it wears out, and the harnesses fail some times too. Can't remember how to test that, but you can find it here some were.
Absolute is offline
post #9 of 15 (permalink) Old 08-11-2013, 01:38 PM Thread Starter
No Chip. Used to have HperTech, but took it out long time ago.
Is there a way to trouble shoot the TPS on the pedal w/o replacing the pedal assembly?
DRMAJOR is offline
post #10 of 15 (permalink) Old 08-11-2013, 11:08 PM
Rich D's Avatar
The TPS, aka the APPS on the 7.3L is replaceable, and you can test it with a meter. I would also look at the IVS(micro switch) on the pedal assembly, it needs to click/function before the APPS reading is accepted by the PCM. You can unplug and unbolt the whole pedal assembly it's 3 10mm bolts.
Early 99 F250 XLT,White/Silver,4x4,SC,SB,A/T,PMT1,ARE LSII tonneau,Amp Research power steps,MB Razor's,295-60-20 Nitto Trail Grapplers,Rhino Liner,Rancho9000's,Bushwacker Street Flares,DP-Tuner F5,True-Cool Max,AFE modified-W.D.RamAir,5"Hypermax exhaust,Hypermax DP,Firestone Ride-Rites,2.5" front leveling leafs,AutoMeter-ProComps/triple pillar,heated TTT mirrors,DEI remote start,Amsoil enhanced.
Rich D is offline
post #11 of 15 (permalink) Old 08-12-2013, 01:41 PM Thread Starter
Thanks.
This is intermittent, so must be a slightly loose connector, corroded wire, and etc. I live on the coast.
Is there a suggested resistance I should get from what contacts?
DRMAJOR is offline
post #12 of 15 (permalink) Old 10-26-2013, 07:46 AM Thread Starter
7.3 quits
Actually, the 7.3 goes to low idle with no throttle response. Most of the time I can put in neutral and recrank. The other day, I had to pull over, stop, put in park, and then recrank.
I contacted Dorman and they say they do not now have the TPS for the 2000 7.3.
Any suggestions on where to get one????
Is there another sensor at the peddle?
Part number to purchase?
DRMAJOR is offline
post #13 of 15 (permalink) Old 10-26-2013, 02:15 PM
I was going to write a thread but clicked on this one and started reading.
I'm experiencing a similiar problem. It doesn't happen around town, only on the highway.....cruising at 50-60-70mph, when wanting to accelerate the throttle is unresponsive all the way down till I hit the kickdown switch for the trans, then it takes off. Gives no other symptoms.
2000 F350 4 X 4 non-DRW....DP tuner 4 pos. program, AFE stage II, BTM muffler, wicked wheel, EBPV delete housing and pedalstal
XFACTOR is offline
post #14 of 15 (permalink) Old 10-26-2013, 02:49 PM
klhansen's Avatar
My Photos: (180)
Your issue sounds like an accelerator pedal position sensor issue as well. It's a 3-wire potentiometer, so if you unplug it, you can check resistance between center and each of the outside pins, the resistance should change smoothly as you stroke the pedal.
), AIS,
regulated return,
klhansen is offline
post #15 of 15 (permalink) Old 10-27-2013, 12:03 PM
drove it last night, and tried something new when it was acting up, I used the cruise control to accelerate and it was fine. I think your right about the pedal sensor, thanks!
XFACTOR is offline
