7.3 serpentine belt replacement - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 03-20-2009, 03:42 PM Thread Starter
My 1999 7.3 has 104,000 miles on it and am pretty sure the serpentine belt has never been changed. There are no visible cracks in it but wondering if I should change it to be safe. I am not really sure how to do this and would appreciate any help.
scorpio19367 is offline
post #2 of 16 (permalink) Old 03-20-2009, 08:37 PM
woodnthings8's Avatar
The belt is around $35 at my local online ford dealer. Easy to change, just take the tension off the belt by the tensioner, take the old one out and route the new one. Get it all routed and crank the tensioner back over, slide the belt on and you are done. Your 99 should have the old style upper radiator hose that routes behind the belt at the alternator, if not you will have to remove the hose off the radiator to do this. Run it and make sure everything looks good. You are now done have a cold one!
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 16 (permalink) Old 03-20-2009, 09:41 PM
Tallavana's Avatar
My Photos: (14)
and if you happen to have the newer style radiator hose that routes through the belt, you can replace the hose with the older or dual alternator styhle hose that goes around the belt.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
2002 F250 Lariat 4x4 Crewcab PSD Shadow Grey/Black
BD X-Monitor, BD Pressure-Loc, SCMT(80),AFE Magnum, 2.5"leveling and 4" block, Bilsteins, Retrax, LineX, Oilguard, MBRP 4" SS, Moto Metal 950 18x9, Toyo A/T 325/60/18, 05 front end w/Harleys, KC 05 light kit w/3 driving lights.
Tallavana is offline
post #4 of 16 (permalink) Old 03-21-2009, 09:27 AM
locknload223's Avatar
Keep your old belt in the truck as a 'highway spare', you never know what could happen on the road.
'00 Excursion Limited- 4" lift, Vcodes/F350 block, 315/75/16's, airbags, ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80tow, Drive-Thru, 80econo, 120race, 4" MBRP, 6637, 6.0 I/C, AIH delete, Foil delete, Auto Enginuity .
locknload223 is offline
post #5 of 16 (permalink) Old 04-09-2009, 02:19 PM
mlcgruhlke's Avatar
I'm having a trial just trying to loosen the tension on the tensioner. What is the best practice???
1996 Ford F250 2 W/D A/T 7.3L Turbo Powerstroke extended cab, Banks Stinger Plus with gauges, competition 8" lift, 35" mudders with aluminum rims
mlcgruhlke is offline
post #6 of 16 (permalink) Old 04-09-2009, 02:29 PM
fddriver2's Avatar
On my 2002 I just stick a 1/2in drive breaker bar in the relief and pull or push till the belt loosens, I also have my son help, an extra set of hands helps.........
I also like to use Goodyear Gatorbacks belts......
I have a philosophy? Who knew. Ok, where's the beer?
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 Transmission cooler
fddriver2 is offline
post #7 of 16 (permalink) Old 04-09-2009, 02:34 PM
Not for sure on a 1996 but the 99-03 you just insert a 1/2" breaker bar into the tensioner and crank opposite of the belt. (CCW) IIRC. They are usually a little tight but a good 18-24" bar is enough to allow you to overcome the spring tension from the tensioner. Then slide the belt off of any one of the pulleys you can reach while holding the breaker bar. Much easier with a third hand.
Ken
post #8 of 16 (permalink) Old 04-09-2009, 05:39 PM
Pull the breaker bar towards the passenger side to release the pressure on the belt, then just slide it off the pulleys. To install, get it on everywhere else, then pull again and wrap around the pulley and tensioner, and release. Then make sure it's on all the wheels straight, especially the grooved ones, and you're done.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
post #9 of 16 (permalink) Old 04-10-2009, 10:31 AM
mlcgruhlke's Avatar
Thanks everyone, I hadn't attempted this before and the instructions with my Ford CD shop manual gave me a different impression. I used the breaker bar with 15mm socket on the relief pulley and pushed to the passenger side of the truck and what do you know, it worked! Thanks a bunch!
post #10 of 16 (permalink) Old 04-10-2009, 02:55 PM
Touchette's Avatar
Send a message via Skype™ to Touchette
Note the Tensioner has a 1/2 inch drive hole that allows a breaker bar to remove the tension off the belt. Also on the tensioner is a small stamped steel bar about an inch long with a spring that allows you to latch the tensioner to the loose belt postition. It is on the bottom of the tensioner and as you pull the breaker bar you can slide this tensioner catch into position to hold that tension. This makes replacing the Serpentine belt much easier. Once you have routed the new belt properly take your 1/2 inch breaker bar and apply leverage as you did originally and the stamped steel retainer will spring load off the catch. Relieve the tension slowly with the breaker bar and the job should be complete.
2002 F-350 CRW DRW PSD Larriat, 4" Down Pipe 5" Airlow Inc Pipe and shorty muffler, autometer full pillar guages, AFE 2 Magnum intake, DI six pos chip, DI Fuel Reg Mod, #8 Inj AD, Front and Rear Hitches, Suv Lights harnesses, White Night backup lights, P&E Tonneau, Tail Gate Guard, Husky mats splash guards and burl dash set, Mag hyTec trans pan diff covers, TTM, Oil Pan Heater, Oil Guard Bypass filter, Several Brite Lyte mods, On Board Air Comp, Optima Batteries, PW Harness, Heater mod and Bob Riley Diesel stuff throughout.
New decals and Badges, Sonnax Valve/Tricumulator Springs, Dahl Fuel Filter, Fuel tank mods. Ball Bearing Turbo. NON-EBV Pedestal, Gutted EBV Outlet, Difuser Doggle, Intake Heater Delete with that little wire and diode thingy, Ceramic Coated Bellowed UpPipes, RiffRaff Diesel Intake Manifold Inserts, F-650 Lower Dashboard. Thinking of putting Solar Panels on the cab roof and calling it a Hybrid.
Touchette is offline
post #11 of 16 (permalink) Old 03-08-2010, 03:23 PM
When I replaced my alternator(ridiculously easy) I just pulled out on the belt and removed it off the alternator by hand. Was surprisingly easy to do.
Single alternator btw.
-2000 7.3L Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags. 225,000 miles.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
DR.billZ is offline
post #12 of 16 (permalink) Old 03-08-2010, 03:46 PM
klhansen's Avatar
My Photos: (180)
You might want to check your tensioner. I've found that trying to pull on the belt like that usually results in pinched fingers. Sounds to me like your tensioner has lost it's tension.
), AIS,
regulated return,
klhansen is offline
post #13 of 16 (permalink) Old 03-08-2010, 03:58 PM
acer2428's Avatar
Agreed. If you can pull it off over the lip by hand with DESTROYING either the belt or your hands, there's not enough tension there.
'01 CC SB 4x4 97k miles, 6-pos mystery chip, S&B, 4" straight, and an insane amount of replacement parts.
acer2428 is offline
post #14 of 16 (permalink) Old 03-08-2010, 04:38 PM
69mach1377's Avatar
billz, maybe the alternator was fine, just not enough tension on the belt to turn it?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Super Zoodad, SC tuner, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, Billet compressor wheel with ported shroud.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #15 of 16 (permalink) Old 03-08-2010, 08:58 PM
I just replaced my alternator at 120,000 miles. While I was at it, I replaced the belt tensioner, the idler pulley and the serpentine belt. I put the old tensioner and idler and belt in the back as road spares.
Bill J., Lexington, KY
2000 Excursion Ltd 7.3 PSD
2000 E350 Super Duty 7.3 PSD
whjco is offline
