7.3 vs 6.0 intercooler - Diesel Forum - TheDieselStop.com
Old 02-06-2008, 04:18 AM   #1 (permalink)
Just wondering the benifits of this swap and what the difference is... how hard is it
Y2K,PSD,Crew Cab,SWB,4x4,diy tymar intake,jenson indash dvd,nav,2 12" kenwood subs,4" silverline turbo back exaust,285/75/16 shoes,
climber417 is offline
Old 02-06-2008, 05:01 AM   #2 (permalink)
I just did the swap last week on my early 99 F350. It's an easy swap, at least on mine, it's a six speed. I've read that there may be a slight issue with clearance on the cooler lines for the automatics but apparently it's not a big deal. I've seen maybe a 50 degree egt decrease when getting on it. The most notable drop will be when towing, at least that's what I've been told, haven't towed with it yet. You'll need to purchase two new intercooler hoses. I put the links below. Be sure to measure the outlet on your intercooler. One side is 3 inches and the other may be either 3.25 inches or 3.5 inches depending on what year intercooler you have. You will not need to cut them to lenght. The eight inch hose will fit and give you plenty of extra for a tight seal. My 7.3 spring clamps worked but it was a tight fit.
Intercooler to tube connection transition hose 3" x 3.25" x 8"
3"x3"x8" Intercooler Hose Coupler
Early 1999 F350 SC XLT
2/98 Build
SRW, 4x4 ESOF, 6 Speed,
DP F5 Tuner 60 Tow, 80 Economy
Ford AIS, DiPricol Gauges
6.0 Intercooler
EBPV Delete
NCHornet's CCV Mod
ITP Fuel Tank/Pre Filter Kit
ITP Regulated Return Kit
KCM SS HPX Line
Power Slot Cryo Rotors
Hawk LTS Pads
4" MagnaFlow Stainless Exhaust
2004 Headlights/Corner Lights
Monroe Reflex Shocks
Michelin LTX/MS
B&W Turnover Ball Gooseneck
37Driver is offline
Old 02-06-2008, 09:49 AM   #3 (permalink)
My Photos: (5)
6.0L intercooler works great with stock injectors. If you plan on upgrading to larger sticks, then it's time to consider something bigger than the 6.0L IC.
Pocket is offline
