7.3L Best Coolant? - Diesel Forum - TheDieselStop.com
post #1 of 138 (permalink) Old 01-30-2008, 08:25 AM Thread Starter
7.3L Best Coolant?
What is the best brand of coolant to use in the 7.3L engine?
2003 F-350 King Ranch, Crew Cab, 4X2, DRW, Estate Green, 6.0L, 4:10 LS, Line-X, B & W Gooseneck hitch, UWS Toolbox - Sold, Got scared of it
2002 F-250 4X4 Off Road Lariat, SRW, Crew Cab, AT, Tlr Twg Pkg, 7.3L, 3.73 LS, B & W Gooseneck Hitch, 6.0L Trans. Cooler, Dieselsite Coolant and Trans. Filter, Severe Duty AIS, AIH Plug, HPX Line, 4WD Braided Vacumn Lines, 203* Thermostat, AL Billet Thermostat Housing, Speed Bleeders, Mag-Hytec Diff. Cover, BTS Valve Body, Autometer Gauges, DP-Tuner F5 - Stock, 40 HP, 60HP, 80 Econ, 120 Race, Power Slot Cryo Rotors, Hawk LTS Pads, UWS Toolbox, Husky Floor Liners
KingRancher is offline
post #2 of 138 (permalink) Old 01-30-2008, 09:32 AM
You might want to include the best brand of oil in your question.
There are many good brands. Do you have a favorite that you are wanting to know if it is ok to use? My favorite brand is Fleetguard. But there are many others that I would be satisfied with.
444-4D is offline
post #3 of 138 (permalink) Old 01-30-2008, 09:55 AM Thread Starter
The intent was for compatability. I've had several concerns on silicate issues and just wanted to make sure that I put the right type, not necessarely brand, as not to harm the engine.
post #4 of 138 (permalink) Old 01-30-2008, 10:04 AM
If you are flushing and refilling your cooling system there are many good choices. If you are adding to what is currently in there, you should use the same as what's in there. Your truck came with Ford Gold coolant. The same coolant can be purchased at auto parts stores. Look for G-05 on the jug.
As for silicate concerns, you will want a low silicate, less than 250 ppm, formulation. Most of the ELC coolants have no silicate.
444-4D is offline
post #5 of 138 (permalink) Old 01-30-2008, 10:30 AM
Im glad this topic came up as I am about to replace the coolant in all 4 of our PSD's. Also can someone tell me the benefit and the reason guys are installing coolant filters? And are they needed for an everyday driver?
2003 BLACK Excursion Limited 7.3 4x4 w/DVD entertainment center, rear captians chairs, 3.73 limited slip. 4" MBRB Stainless Exhaust, AFE stage II intake, DP F5 Tuner, 4.5" Donahue lift, Rolling on 18" Jesse James Lawless 8's wrapped by 35" Toyo Open Country Mud Terains and airbags, Prodigy brake controller.
2002 BLUE F350 XLT 7.3 4x4 Crew Cab short box, BTS Tranny, 6.0 tranny cooler, 4" Silverline Stainless exhaust, S&B intake, DP F6 Tuner with 9 tunes. Line X, B&W turnover ball, Prodigy brake controller.
1968 Chevy C-10 Short Bed PRO-STREET 500+CI BBC
1991 Honda CRX-SI (Black Also)
2002 John Deere Gator Diesel 6X6
2003 Limited edition Cannondale Cannibal- With colors that woulnt run, RED, WHITE and BLUE #0000016
Owner and Dad of Godspeed MX racing. #269
1BADF350 is offline
post #6 of 138 (permalink) Old 01-30-2008, 10:41 AM
I agree. I use Motorcraft Gold Coolant.
dfuser is offline
post #7 of 138 (permalink) Old 01-30-2008, 10:57 AM
Banned
Heavy Duty ELC's are what the manufacturer of the engine, International, recommends. My favorite brand is Chevron Delo ELC. But others including CAT ELC, Fleetrite ELC, Fleetguard ELC, Rotella ELC, Texaco ELC, Mobil 1 ELC, are excellent too.
These coolants are made specifically for diesels and meet the most strict coolant specifications in the industry, like EC-1. Unlike the G-05 and conventional coolants they are silicate-free to make your water pump happier. They are maintenance-free with operating lives and flush intervals many times that of conventional and G-05 coolants. They will provide significantly better heat transfer, and they contain a more robust cavitation and corrosion inhibitor, particularly as operating time adds up.
As mentioned, when adding to existing coolant, it's always best to be consistent. Mixing types of coolants is not recommended. There are thorough flush instructions listed at this site for a proper switch-over to a different coolant technology. Installing a coolant filter is always a good idea. Most all coolants are good, with some better than others. Properly maintaining them is the key, no matter which one. The choice is really yours, and how you define "best".
Gooch is offline
post #8 of 138 (permalink) Old 01-30-2008, 12:02 PM
Wow, they should take one of the previous versions of this topic and make it a sticky.
When the weather gets descent, I am going to the Chevron Delo ELC. It is the only one I could find in town that is not pre-diluted. It's not cheap at $21 gallon, but it has an 8 year life.
2014 F350 XLT, 6.7
2015 F350 C&C XL, 6.7, service truck (with 100 less HP than the standard 6.7!)
*SOLD (sad) * 2000 F350 7.3, Auto, Lariat. John Wood transmission, Airdog, ITP reg return, AC single shot injectors, DP Tuner, live tuned.
Scottz is offline
post #9 of 138 (permalink) Old 01-30-2008, 01:01 PM
Or maybe a list of acceptable brands sorted by type in the FAQ section.
444-4D is offline
post #10 of 138 (permalink) Old 01-30-2008, 01:11 PM
I would use either the factory fill of Motorcraft or I would use Amsoil. If you are changing coolants a flush would be recommended.
Jared
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 35x12.50-17 Mickey Thompson ATZ, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120), Adrenaline HPOP, Coolant Filter, Amsoil bypass filter, Ford rear sway bar, 6 1/2" spring arch.
2000 BMW 540i, 6 speed, sport package, daily driver.
jnyost is offline
post #11 of 138 (permalink) Old 01-30-2008, 01:43 PM
Jared
You have to ignore a lot of good coolants to get the list down to those two.
444-4D is offline
post #12 of 138 (permalink) Old 01-30-2008, 02:46 PM
High PSI's Avatar
My Photos: (18)
I got IH Fleetrite ELC concentrate for $12 a gallon this summer. Try to locate an International dealer nearby.
'02 Black F350srw,Lariat,CC,SB,OR. - BTS TRANS,Coated 1.00 BB TN-non EBP-6.0 Spearco IC-DP Tunes(stock,HI,60T,80E,120R)MAP maximizer-ITP reg ret.-AirDog-Fluidampr-BWD coated/ bellowed pipes-AFE2-4" Magnaflow-Dieselsite coolant filter&ESOF SS lines-Billet/203*stat-Fleetrite ELC-Bilsteins-Hawks&Cryo's-Centramatic-Billet-Extang-Husky box-Husky Liner-EGR-LineX-Alpine-Kicker-PIAA-Dynamat-Sirius-Viper-ES Poly's-BFG 315/75/16 AT's-DTS 4.56LS-31 row 6.0 Cooler-UltraLite trans,pyro,boost-DiPricol fuel-PML pan-Mag-Hytec cover-Powerslot-Hawk. Marinco,Snowman,Harpoon,AIH,CCV,foil,door ding,console mods.
High PSI is offline
post #13 of 138 (permalink) Old 01-30-2008, 03:09 PM
LOOSEWHEEL's Avatar
Check the local heavy truck service and parts suppliers. Look for the concentrated ELC's as they will be cheaper than using the pre-mix and you may luck out if they have a sale. I grabbed some Texaco ELC for CDN$16.
2001 F350 CC SWB 6spd WHITE 8.5" on 37's. Currently getting a complete makeover......stay tuned.
'Everything is possible if you don't know what you are talking about'
LOOSEWHEEL is offline
post #14 of 138 (permalink) Old 01-30-2008, 08:29 PM
Be sure to get the concentrated coolant, not the 50% prediluted, if you are going to flush and refill the coolant. There will be some water left in the engine after flushing. This water will dilute the coolant; so if you use 50% to start, the water in the engine will dilute it to less than 50%. You want 50% as the final concentration. Manuals & Warranties Result - Ford
The link above will give you the Scheduled Maintenance Guide, the Owner's Guide, and the Diesel Supplement. On page 36 of the Diesel Supplement, it says that your refill capacity for coolant is 32.75 quarts; so you will need about 16 quarts, or 4 gallons of the concentrate for the refill. Fill the rest with water.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 170,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
post #15 of 138 (permalink) Old 01-31-2008, 12:35 AM
tripleddd's Avatar
flush it, i used distilled water and delo elc. gooch method! gooch approved!
tripleddd is offline
Similar Threads
Coolant additive needed in 02' with orange coolant??? Weed '99 & up 7.3L Power Stroke Engine and Drivetrain 7 01-16-2007 03:05 PM
88f250 towing, coolant temp, evans coolant IDIABUSE Towing and Hauling 7 06-05-2006 08:02 AM
Just finished a coolant flush and my coolant was orange? pajohn '99 & up 7.3L Power Stroke Engine and Drivetrain 9 11-15-2005 11:18 AM
What coolant for 2000 Excursion with factory green coolant? DynoTom '99 & up 7.3L Power Stroke Engine and Drivetrain 26 09-14-2005 02:28 PM
Coolant additives with extended life coolant RealityCheck E-Series Vans 2 12-23-2003 04:31 AM
